Question about Compaq PS115 Computer Speakers
Theres no sound, its all plugged in correctly and still no results
  • Compaq Master
  • 27,725 Answers
Control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Posted on Oct 14, 2010
    Problem Solver:
  • 10 Answers
Go to Start --> Run, and type in services.msc.
A window will pop up with a list of services. Scroll down to Windows Audio. Right-click
and click on Properties.
Make sure that "Startup type" is set to automatic. Also, make sure, under "Service
status," start is selected.
If that does not work, let me know.
When i turn on my 04 taurus. It starts makin knock sound , i replaced my lower intake n i think i missplaced the spark plug wiring
If the spark plug wiring is not correct, the engine will misfire and that will create erratic combustion, which is a shock to the cylinder, which results in a load harsh noise. Locate the number 1 spark plug wire on the distributor cap and trace each wire to the spark plugs. The firing order will be listed on the intake manifold. Make the correct wire to spark plugs attachments as needed.
Oct 11, 2016 | 2004 Ford Taurus
The sound from my tv will not play through my surround sound.
Make sure that you have your receivers input selector to the correct input that you plugged your tv into. Try plugging the tv output into the working input that you have for the dvd. If the tv still does not work, and you are using a working input, then clearly, there is no workable signal going into the receiver. In tv menu check the audio output format.
Some tv sets output their audio signal in digital format. If you plug that into a receiver with an analog audio input it will result in silence.
Apr 02, 2014 | Audio Players & Recorders
CANT GET 5.1 SURROND SOUND TO WPORK
I'm not familiar with this system, but I can suggest the following:
Make sure the speaker jacks are plugged into the correct holes.
Make sure (in the control panel) that the sounds are correctly configured. If you tell the computer that there are only 2 speakers, then you'll have a problem. Be sure you subwoofer is powered up and connected correctly.
Most all problems are caused by "operator error." This usually results from an improper connection.
Apr 20, 2012 | E-Machines eMachines Desktop PC
ISight microphone unresponsive on MacMini 10.5.7
Reinstall the driver or is there a device type management > might help in might be the correct direction
Jul 31, 2009 | Apple iSight Webcam
No sounds on my speakers
1. Power to the speakers (make sure they are plugged in!)
2. Make sure the speaker line is plugged into the correct port on your sound card. The connector should be green and possible the port will be green to.
3. Double click the little speaker in the bottom right of the screen (assuming you are using XP/VISTA) and make sure nothing is muted.
Post back with your results.
Jun 03, 2009 | Logitech R-10 Computer Speakers
My 500GB LaCie will not power up
that is an external drive correct. It should run just off the usb. is the drive recognized ?
Robert
Aug 27, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
No sound
Check the Power to the speakers, and that they are correctly plugged into the PC. Sometimes a cord gets bumped and you don't realize it. If both of those are good, then go to System Devices and make sure the sound card is showing that it is working properly. Try head phones and let me know what results you get from that. Thanks!
Jul 19, 2008 | Packard Bell Computers & Internet
Sound
Check the control panel and see what your default sound device is set for.
Do you have a third party sound card like a sound blaster plugged into here?
Jun 10, 2008 | Dell Dimension 4600 PC Desktop
Only one speaker works
if you have plugged correctly without any losse contact it should work if not o think your speaker configration is not correctly set go to the control panel->sounds and audio devices->device volume->advanced there u set that balance slider to middle of all volume control,wave,sw synth,line in etc.. then go to speaker settings in the same window of sounds and audio drivers there in speaker settings click on advanced you get another window in that drop down box specify your speaker configration wether is desktop speakers laptop mono speakers or stereo headphones etc specify the right one you have then ok after this in speaker settings click on speaker volume and keep left and right speakers to maximum then apply ok this will work check it out if stil not worked tell me what ws the result ill solve that for u
May 07, 2008 | Cyber Acoustics CA-3550 Computer Speakers
Sony CDP-CX455
did you have any luck with swapping the channels to determine if which is bad, cd or system?
regards
Graeme
Mar 28, 2008 | Sony CDP-CX210 200-Disc CD Changer
Compaq PS115 Computer Speakers Logo
56 people viewed this question
Top Compaq Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you a Compaq Audio Player and Recorder Expert? Answer questions, earn points and help others
