Question about Samsung Cell Phones
Using it with a Samsung SPH-R540. It does not support PBAP, but I cannot manually upload selected contacts. When I press/hold the mute/contact button on the T325, it just makes a single beep instead of informing me its ready to receive vcard. If I try sending a contact on my phone and select the T325, I'm asked if I want to disconnect device. If I turn off the T325, my phone will at least allow me to attempt to send the contact, but than of course fails because the T325 is off. What's up with this?
5 Suggested Answers
SOURCE: Sony Ericsson T303
As regards the ringtones, have you just put the volume down, as I did this unintentionally and couldn't hear the ringtones until my son turned the volume back up for me - by pressing the up button while ringtone is playing.
Posted on Nov 03, 2008
SOURCE: samsung sph a740 with bell canada: can't send texts or store new numbers
I had the same problem when I went to send a text. Phone would lock then power cycle. Did manage to fix it though. In the menu go to settings, then security. It will ask you for your security code. If you know it put it in if you don't know it should be the last four digits of your phone # or possibly 0000. once in go to reset phone navigate to yes twice and it should reset after a minute and power cycle. You will not lose your contacts, pictures or schedules. You will have to reprogram your personal settings. like display and ringers.
Posted on Feb 05, 2009
maniando
  • 129 Answers
SOURCE: My phone won't allow me to send Multimedia Messages
hi there,
You need to set the message center number correctly contact your operator helpline or try deleting the messages in your outbox and saved items. please vote me if i had helped.
Posted on Aug 20, 2009
VinayT
  • 1884 Answers
SOURCE: I am planning to share contacts from my L7i to another phone
If the other phone is a Motorola too, then there should be no problem. But if the other phone is not Motorola then you will have problems. The reason is that they both have different formats of Contacts. What you can do is copy as many (max of 250) on the SIM and then insert this SIM into the other phone and copy them there on the phone's memory. Then remove SIM from new phone and insert it back into the original phone. Delete all contacts from the SIM and copy the balance to the SIM. Remove SIM from here and insert it into the new phone and copy all contacts to the new phone's memory. The best and the fastest way to copy contacts from one phone to another where the data does not match.
Posted on Nov 30, 2009
User manual
first power off your phone
second hold vol up + home + power button after 10 second you are in recovery mode than select the wipe data / factory reset using vol- and than press power button.
Than select wipe cache..... and press power button
Your phone contact and msg Must be lost but lock will be ok
Jun 13, 2013 | Samsung Galaxy S GTI9000 Smartphone
I need the manual for the samsung sph-m540
You can download and print the instruction manual in PDF format by clicking this link:
http://www.cellphones.ca/upload/manuals/samsung-m540-rant-manual.pdf
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Thanks for using FixYa.
Sep 27, 2011 | Samsung UpStage SPH-m620 Cellular Phone
I am trying to program my "Direct TV" remote to my Samsung LCD TV Series 5 and can not find the 5 digit code needed to do so.
If you have a DIRECTV white remote, press "menu" then "settings," "setup," "remote", and follow the on-screen instructions.
If using a gray or black remote,
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9911, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
  • Sep 07, 2011 | Televison & Video
    Need to do hard reset on samsung sph m910
    Follow these simple steps to reset the phone
    [hold the vol down button and call button press Same time and then release the power button]
    and then menu appear, it work for sprint samsung intercept
    Step one, Turn the power off. You need to pull the battery out and reinsert it if your phone gets frozen
    Step two, Hold the Volume Down button
    Step three, Press and release the Power button
    Step four, a menu appears that allows for Fastbook, Recovery, Clear Storage, and Simlock
    Step five, press the Volume Down button to Select Clear Storage
    Step six, Press and release the Power button
    Step seven, make your decision by touching one of the two options: Volume Up for YES and Volume Down for NO
    If you selected YES, all data will be deleted from the phone including third-party applications. The Samsung Intercept will reboot to its original data.
    Source:
    http://samsung-phones-apps.com/how-to-hard-reset-samsung-intercept-sph-m910-to-factory-default-settings.html
    Aug 16, 2011 | Samsung Cell Phones
    Canton use skype
    Reinstall Skype. It should take about 3 or 4 minutes.
    May 15, 2011 | Skype IM
    How do i mute incoming call on samsung s7220
    Hello Sir In Idle mode, press and hold # to silence or unsilence your phone.
    And To change Your Ringtone follow these steps ! Change your ringtone Phone ? Settings 1. In Menu mode, select profiles . 2. Scroll to the profile you are using. > Voice call ringtone ? Edit
    May 05, 2011 | Samsung Cell Phones
    How to put cell phone to speakerphone mode
    Manual:
    http://www.cellphones.ca/upload/manuals/samsung-sph-m300-manual.pdf
    From Page 39 of the manual:
    Selecting Options (right softkey) during a call displays a list of
    features you may use during the course of a call. To select an
    option, press the corresponding keypad number or highlight
    the option and press . The following options are available
    through the Options menu:
     (1) Key Mute/Unmute allows you to mute the microphone
    on your phone so the caller is unable to hear any sound.
     (2) Turn Speaker On enables the speakerphone feature.
     (3) Set Whisper increases the microphone to its maximum
    level. During a call turn on Set Whisper when speaking
    softly or when the caller cannot hear your voice clearly.
    This mode is useful in meetings or public places.
     (4) Call History checks your call log for Outgoing, Incoming,
    Missed, and Recent calls. You can also erase the logs from
    this menu.
     (5) Contacts accesses the Contacts menu.
     (6) 3-Way Call allows you to talk to two different people at
    the same time. (For more information, see “Making a
    Three-Way Call” on page 189.)
     (7) Messaging accesses the Messaging menu options.
     (8) Voice Memo allows you to record incoming audio from
    your conversation. (For more information, see “Managing
    Voice Memos” on page 135.)
     (9) Tools accesses the Tools menu options.
    Manual:
    Mar 21, 2009 | Samsung SPH-M300 Cellular Phone
    I hate this phone!
    The "end" key on your phone works as power button as well. Press and hold that button to switch it on/off.
    Feb 02, 2009 | Samsung UpStage SPH-m620 Cellular Phone
    21095GE2-a user manual
    I have the manual and can scan or fax pages if you want. Contact me if you still need this at: twoeyes4you@yahoo.com
    My system just quit allowing me to listen to messages and all three batteries quit. I'll probably have to get a new phone system.
    Let me know if you need handsets and cradles too, I have 3!
    Judy
    Aug 26, 2008 | GE 21095GE2 Cordless Phone
    Blackberry 7100g
    About fixed dialing
    If you enable fixed dialing number (FDN) mode, your device only makes calls to contacts on your FDN list. Your device can dial emergency numbers in FDN mode, even if the numbers are not in the FDN list. If your service provider plan includes SMS, you can also send SMS messages to contacts on your FDN list
    so if you have this enabled chances are you have to turn it off.
    this is how you turn it on so you should be able to use it as a guide to turn it off.
    Turn on fixed dialing
    1. In the phone options, click FDN Phone List.
    2. Click the trackwheel.
    3. Click Enable FDN mode.
    4. Type the PIN2 code provided by your service provider.
    5. Click the trackwheel.
    or if you wanna keep it on and add friends to the fdn
    Add contacts to the FDN list
    3. Click New.
    6. Type a name and a phone number.
    7. Click the trackwheel.
    8. Click Save.
    and finally some shortcut keys:
    To open the phone, press the Send key.
    To end a call, press the End key.
    To call a selected contact or phone number, press the Send key. To call a speed dial number, hold the assigned key.
    To add an extension to a phone number, press the X key. Type the extension number.
    To call your voice mail access number, hold 1.
    To type a letter in a number field, hold the Alt key.
    To type the first letter on a key, press the letter key once.
    To type the second letter on a key, press the letter key twice.
    To turn on or turn off mute using the Mute button, press the Mute button.
    To turn on or turn off mute using the keypad, press the exclamation point (!) key.
    To turn speakerphone on and off during a call, press the period (.) key.
    To change the volume during a call, roll the trackwheel.
    Aug 02, 2008 | RIM BlackBerry 7100G Smartphone
    Cell Phones Logo
    221 people viewed this question
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
