Question about Sylvania LV448HG VCR
VCR tape won't eject - Sylvania LV448HG VCR
  • 597 Answers
The reason your tape wont eject is either because, it is stuck or the tape run loose inside of it.
To remove the tape, unplug the VCR, then unscrew it open, you will have direct access to the tape, so try to plug it back and press eject, when it gets stuck, apply a little force in pushing the tape up, to the height where it is to pass out, and it will eject your tape.
If you are not familiar with such activities, i will advice you get a repairman to get this done for you, in order for you not to damage any other part inside the VCR.
Take cacre and good luck
Posted on Oct 14, 2010
SOURCE: SONY VCR: Keeps ejecting video tape
may be machnical stuck in playback mode. remove the cover and see the loading arms are near the video head , if not try to release the arm rotating caption wheel smmothly . don't push more force to rotate the wheel.
Posted on Jan 15, 2009
Shuttle83
  • 1139 Answers
SOURCE: MAGNVOX MWR20V6 VCR WON,T ACCEPT TAPE EJECTS WONT LOAD UP
Hello alhertel,
The old idler wheel has been replaced with gears (cheaper and last longer then the old rubber wheel). What you need to do is to gain access to the loader motor and turn it until the carriage begins to move, once the carriage gets to the top and moves outward you should be able to eject the tape with no problem.
Believe it or not VCRs are throw away technology, since it costs as much to repair one as it does to buy a new one. However, there are a lot of people who still hold on to their VCRs.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 12, 2008
  • 139 Answers
SOURCE: VCR tape won't eject
The flap on the door stays open until the tape is ejected. There are two possible ways to remove the tape. First, with the power off, try to locate the drive pulley or gear on the side of the tape housing. It may be possible to turn it with your finger and cause the tape to eject. The eject mechanism will move VERY slowly when you use this technique.
The second way to do it should normally be done by an experienced technician, because it involves taking it even farther apart...and it may be difficult to reassemble. There are typically four screws that hold the tape mechanism in place...two near the top front and two near the back. It should be possible to remove those screws and pull the entire mechanism out of the VCR. Then you can more easily rotate the eject pulley (or gear) and remove the tape. If this sounds a little scary, I would definitely recommend placing the top back on and acting like nothing happened!
Posted on Mar 17, 2008
  • 52 Answers
SOURCE: Panasonic 7350 VCR Keep ejecting tapes just seconds after loading
This happens when he strings are worn out or broken. It will not hurt to replace the strings of the VCR after some while.
Posted on Feb 09, 2009
radar001
  • 1051 Answers
SOURCE: VCR tape is stuck - will not rewind or eject.
There schould be a release buuton on the rear of the machine. It's usually recessed and may be difficult to see. Press this with the yip if a ballpoint pen and extract the tape. If the tape is wrapped around the record/playback heads your only option is to remove the top cover and manually remove the tape. Sounds difficult but if you take your time it's not too bad a job.
Posted on Mar 08, 2010
Testimonial: "Thank you! - no button - took the top off. I depressed a lever next to the tape switched the VCR back on and pressed the eject button - it worked!"
VCR won't eject tape
unplug VCR take the top off about 4 screws or more I would say you willmbe able to see that tape is wound round inside you should be able to remove it .
Mar 16, 2013 | Heating & Cooling
VCR won't record, just ejects tape
You have not mentioned the make and model number of the vcr. Any way the problem is due to end sensor or related circuit. End sensors are photo diods which you can check the shorting with a multy meter.
Jan 13, 2013 | Emerson Televison & Video
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
VHS tape won't eject
Hello
Check for any borken drive belt in the mechanism.
Feb 13, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
When putting in a video the VCR has a tendency eject the tape and then shuts off. Then there are times it works fine. What seems to be the problem?
Apr 07, 2009 | Panasonic DOLBY DIG. 850w HOME THEATER...
VCR continually tries to eject the tape after it is inserted
If you have cleaned the head with a good head cleaner and you are still having a problem...the belt is probably worn. A good head clean should fix the problem.
Mar 18, 2009 | Zenith VR4127 VCR
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
VCR TAPE IS STICK IN VCR PLAYER.
if you can't get the tape out enough to pull it very carefully out by hand, you'll have to bring it to a repair shop. the tape is probably twisted up inside and jammed.
Nov 08, 2007 | Philips CCB092AT 9 in. TV/VCR Combo
Televison & Video Logo
735 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
