Question about IBM ThinkCentre S51 Intel Desktop PC - Intel P4 3.2GHz, 1GB DDR, 40GB HDD, CD-ROM, XP Pr
Computer would not come on when you press the power button and nothing works.
  • IBM Master
  • 5,660 Answers
Bad Power On switch, or bad Power Supply.
(Weak voltage power rail)
The Power On switch is located inside the plastic Power On button.
This is an example of a generic ATX power on switch,
http://www.directron.com/atxswitch.html
One that I have found fits many desktop computers.
There is a test to see if the problem is the Power On switch, or the Power Supply.
The test requires using a jumper wire on the ATX main power cable's connector.
Jump the Soft Power On wire (PS_ON) to ANY ground wire.
This is Lenovo Support, ThinkCentre S51 desktop computer, User Manuals, and the link to download the HMM.
Hardware Maintenance Manual.
Left-click on the top blue file listed.
Starts with - Hardware Maintenance Manual (HMM) (March 2009) Thinkcenter A51........and ends with S51 (type 8098, 8171, 8172, 8173)
Date to the right is 2009-08-05
On the next page look under the heading - File link, and click on -
19r0486.pdf in blue.
This is a PDF file. It may take as much as 30 seconds before you see the first page. Additional time may be required to fully download. Let the file download all the way before looking through it.
(Took 4 seconds to see the first page, and over 3 minutes to fully download just now. Medium speed DSL connection)
With this HMM you can follow along with illustrations, and details, as I detail how to perform the above test, on your IBM ThinkCentre.
(FRU = Field Replacement Unit)
S51 is the Product Model.
There are several Types.
Page 98 details how to open the ThinkCentre S51 desktop computer. ('Pizza-box' computer case)
(Types 8095, 8141, 8142, 8145, 8420, 8421)
Page 123 details how to open the ThinkCenter desktop Tower computer case.
(Types 8143, 8144, 8146, 8422, 8423, 8427)
Page 145 details how to open another 'Pizza-box' style computer case.
(Types 8098, 8171, 8172, 8173, 8424, 8425)
Computer unplugged from power, observe Anti-Static Precautions, BEFORE you reach inside.
Anti-Static Precautions:
Your body carries Static electricity.
Static will fry out (Short Circuit) the hardware components inside a computer.
Computer unplugged from power, TOUCH the metal frame of the open computer case. Touch an unpainted surface.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
With the flat desktop models, ('Pizza-box') you may have to release the lock, and tilt the Harddrive, and optical drive up. (CD/DVD drive)
This will allow viewing the motherboard.
With the desktop tower model you may have to ease a few cables over to view the motherboard.
You are looking for the 20, or 24-pin ATX main power cable.
(Don't know if your model uses a 20-pin, or a 24-pin.
This is what you're looking for,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Scroll down to see the 24-pin ATX main power cable.
Look at the photo to the far right.
The Green wire is the Soft Power On wire.
ANY Black wire is a Ground wire.
With the ATX power cable plugged into the motherboard, as shown in the photo to the far right, you are going to insert a jumper wire down into the socket holes.
The jumper wire goes down in the socket hole, Right next to the wire that is in the hole.
It goes down in far enough to touch a metal terminal, that is at the end of the wire.
(Approximately 1/2 inch)
The jumper wire of choice is a paper clip straightened out, then bent into a U-shape.
The middle of the U is wrapped a few times with black plastic electrical tape.
(Trivia: One wrap of black plastic electrical tape is enough for 600 Volts DC)
The voltage you will be dealing with is 5 Volts DC.
Two D cell flashlight batteries produce 3 Volts DC.
You may wish to wear a glove on the hand that holds the jumper wire. There may be a small spark.
The Power Supply, (Computer), is plugged into power.
One end of the U-shaped jumper wire, is inserted down into the socket hole with a Green wire. (Right next to the wire)
The other end is inserted down into a socket hole with ANY Black wire.
The contact made is no more than 2 seconds. (1001, 1002)
If the computer comes on, (Power Supply actually), the Power On switch is bad.
If the computer does not come on (Power Supply), the Power Supply is bad.
It's an ATX power supply, probably a generic model made by Bestec, HiPro, Delta, or another low quality power supply manufacturer.
The Wattage is probably stated at Maximum 225 watts.
An ATX style Power Supply is used by over 80 percent of desktop computers out there. You can buy a decent one for around $30 US.
(Power Supply case size is approximately 6 inches Wide, 5.5 inches Long, and 3-1/2 inches Tall)
You can use a 300, or 400, or 500 Watt power supply.
Doesn't matter. Won't hurt the computer.
A computer ONLY uses the power it needs, and no more
Post questions in a Comment.
Regards,
joecoolvette
Posted on Oct 14, 2010
Testimonial: "Very good job your test worked was able to solve my problem. Thanks a million."
  • joecoolvette
    joecoolvette Oct 17, 2010
    You are Most Kind allen_nsr. Thank you for the rating, and the kind words!
G4apple power boot boot up problem
If nothing happens when you press the power button then the computer is most likely out of power - plug a charger in and it should work. If it still doesn't you might want to get it checked at a service provider. If something happens when you press the power button but the computer doesn't turn on, then please provide more information, explaining exactly what happens so that I can help you.
Dec 02, 2013 | Computers & Internet
No power to my desktop computer HP A1330N and no green light in the back of the power supply
You replaced power supply and your made sure you plugged everything back into the motherboard snuggly and in it's proper place? If so it might be your motherboard is bad.
Make sure you have the new power supply turned on. Sometimes there's a O/I switch on the back of the power supply. Flip it and try to boot and see what happens. You might have another bad power supply.
If so your motherboard might be burning them out.
Try removing the power cord for 30 seconds and press and hold the power button. After 30 seconds put the power cord back in and press the power button to see what happens.
Do your fans work when you press the power button? Do you hear any fans running?
Mar 23, 2012 | Computers & Internet
Computer is not working
The computer may be in hibernate or standby. Try pressing the space bar, and then wait a moment. See if anything happens. If nothing happens, press the power button for one second and wait a moment and see if anything happens. If nothing occurs, you may need to force a restart.
To force a restart, hold in the power button for approximately 15-20 seconds, this should force the computer to turn off all the way. If holding the power button doesn't do the trick - you can unplug the computer from the wall and take out the laptop battery as a last resort.
Once you are sure the computer is off all the way, press the power button and see if anything at all shows on the screen. If you are not able to see any information on the screen, it is possible that the Laptops screen has gone bad. If you have an external monitor you can try to plug into it and see if anything shows. If nothing shows, it is possible the video card/motherboard is gone bad.
To fully diagnose a bad motherboard or video card - you would need to take it to a qualified computer technician.
Nov 15, 2011 | HP Compaq Presario C306US Notebook
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
I have a Compaq CQ50 laptop, there seems to be a short or bad connection somewhere just under the power button or keyboard. I say this because the power button is not working, I press the botton and...
I was working in a computer with the same problem, when you remove the keyboard and the keyboard cover at the right side of the power button you can see an small plastic cap with two wires, is the num lock led, when the wires are under the top cover and the screws of the keyboard or the cover are too tight the wire is damage and make contac with the earth shuting down the power supply, check the wires, repair if broken and take care that its not under the top cover when you assembly.
Sep 24, 2009 | HP Compaq Presario CQ50-110US Laptop
How to turn off burn-in mode if botton on Monitor
I didn't have the monitor connected to the computer, and that's why the power button was unresponsive. After connecting it, the solution above worked for me.(My KVM switch was set to a computer that was turned off)
Oct 07, 2008 | Sceptre DCL9a
Computer failure
well there is a power button on the back of your computer
make sure that this button is on
and make sure that the power cable is firmly connected and maybe u can try to change the power socket also
if nothing is working then its the front panel is not working anymore and needs to be replaced
if u have any warranty on the computer then contact the warranty ppl to change it for u
cheers
Sep 04, 2008 | Acer Aspire L100 PC Desktop
IBM ThinkCentre S51 Intel Desktop PC  - Intel P4 3.2GHz, 1GB DDR, 40GB HDD, CD-ROM, XP Pr  Logo
469 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
