CF-18 hard drive
Maanita,
Thank you for the quick response and the info. Will this work for a new licensed OS? I do not have the original OS and will want to install a new version of XP pro (not a tablet version).
Thanks again for your help......................Tony
  • 611 Answers
Give me the your address i send to you win xpro cd to you but you have to send the some buss
Posted on Jun 04, 2008
How do you obtain the hard drive serial numbers for CF-30 and CF-31
Try this freeware program, SPECCY at: http://filehippo.com/search?q=speccy Install and start, look at the HARD DRIVE section. You will find useful info to ID your Laptop's hardware/software OS.
Aug 24, 2013 | Panasonic Toughbook CF-29 Notebook
Operating system not found
No, you won't get the OS to automatically install on the new drive. The OS is not stored in the BIOS chip (or a similar permanent location inside the computer). You will need an OS install disc (not an upgrade disc). Windows Vista Home Premium or Basic was the original OS on most of the Acer Aspire 4530 series. Acer appears to have drivers for the system for XP through Windows 7 to get the hardware to work. You will need to have these most of these ready before you install your OS. Put them on a flash drive or optical disc using another computer.
This computer may work with Unix as well. However, driver issues may be a factor. You can try most versions of Unix from a CD (LiveCD) to test it out.
When you get a new hard drive, install it into the laptop. Then put the OS disk in the optical drive bay. Boot to the optical drive. Follow the directions for formatting the hard drive and installing the OS. (Of course you will need a drive that doesn't have a higher capacity than the BIOS supports.) The motherboard needs to recognize the drive.
If you find a member of a Windows User Group, they may have Windows install discs available. The license number on the label of your computer will probably work as your license key. (The key for a computer like this is locked to the CPU and motherboard; unless someone upgraded the OS to Windows 7 or downgraded to XP, this should be the key you need.) Use the information on the label to obtain the correct version of Vista (the Basic install disc may not work for installing Home Premium). You also need to match the 32-bit or 64-bit install disc (and the service pack you need).
I hope this helps.
(An Acer recovery disc wouldn't help you. Most of those are completely locked to the original hardware (including hard drive) and look for the recovery partition that was on that hard drive.)
Dec 05, 2012 | Computers & Internet
Bought used toughbook on ebay, no hard drive or OS. using my old hard drive from broken one. get to bios screen, but will not boot up into windows. I'm guessing some drivers may be jacking me up, how do I...
reformat the had drive and install a fresh copy of OS from the compact disc.... once the installation is complete, boot up the computer again... if it works, then every thing is perfect....you can go ahead and install the drivers for your devices in the compter...
please clarify if you have any further troubles in installing the OS in your computer...
May 07, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Toughbook cf-18 cannot boot thru window. it come out with a start using safemode, then go into window , then blue screen with "a problem has been detected and windows has been shut down to prevent damage...
Yu possibly have a virus
You will need to format the hard drive and reload Windows if this doesn't work you will need a new hard drive.
Try to "defragment the hard drive 1st. check the disk for errors.
Apr 27, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Eeepc 701 won't restart after reinstalling OS. reinstalled original oS software, dis an apt-get update, updates continued for quite a time, then had to reboot. But since then, nothing, eeepc will not even...
you probably have the solid state hard drive (4gb)... its not big enough to hold all the updates .. unfortunately the operating system comes with "auto update" turned on ... it will download updates until the drive is full then will crash .. one way to resolve this is to kill the internet so it cant log on ... you can disconnect or turn off your wifi or if you are fast enough you can use Fn F2 (turns off wifi) .. just watch the wifi light to make sure its off at boot .. there is a lag in response so its a bit tricky ...now once booted you can turn off "auto update" ...then you can turn your wifi or internet back on .. manually update only things you know you have room for .. if your 701 has a CF card slot (like my eeepc 900a . then that can be used as additional hard drive space ... during installation i made that the boot drive (advanced) (of course you cant remove it after that).. the new eeebuntu4 beta is a wonderful upgrade for the system .. but i could only get it working by using thhe CF drive as above.. if you havent already done so you can make a bootable USB jump drive .. you can run Ubuntu off that as well as install from that ...change the boot order in cmos ..to boot first from the Jump dirve ...
Apr 02, 2010 | ASUS Eee 4G Notebook
Can I install windows 7 on a panasonic toughbook cf-18 tablet
I don't thank they have it out for tablet yet. Wait a bit and they should.
Nov 11, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Need a new hard drive
Will not work. the OS is in a partition on the original HDD....you best bet is to send it in for a repair call 1-800-289-9100 24/7 to get a RA #
Mar 04, 2009 | Pelco DX1000
Cf-18 toughbook
The BIOS may not support the larger drive at all; I suggest you look for a Toughbook forum and repost there and check Panasonic's site for a manual download and possibly a BIOS upgrade if the unit is equipped with a flash BIOS.
Aug 27, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Cf-18
Do a clean reinstall to the infected harddrive as it will be wiped off when you will reinstall the os follow the steps with the following website step by step : Enjoy
www.windowsreinstall.com
May 30, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Computers & Internet Logo
David Payne
David Payne
