Question about LG DLG5988 Gas Dryer
Unit powers up, check filter light flashes until you turn main control knob to any setting (e.g 'normal'). Press start, unit runs, but no heat. Checked output of vent outside, plenty of cool air is flowing through. Gas is on, power is good, lint screen is clean and I vacuumed inside of lint screen area as well. Vent hose is not kinked.
  • LG Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 15, 2010
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
Tip
How to Reset Your Air Purifier Filter Light
<span style="font-weight: bold;">Airgle Air Purifier:</span><br /> <ol> <li>Turn off and unplug the unit </li> <li>Press the light button to the "on" position </li> <li>Plug in the unit, and then release the button after the Filter-check starts</li> <li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li> <li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li> <li>This time, the system should report an accurate result. </li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br /> <ol> <li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li> <li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br /> <ol> <li>Units which have an indicator light must be reset once the HEPA filter has been replaced. Reset indicator by inserting a small object (such as a pin or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br /> <ol> <li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br /> <ol> <li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br /> <ol> <li>Change the filter and/or pre-filter.</li> <li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li> <li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br /> <ol> <li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li> <li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li> <li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li> <li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br /> <ol> <li>Press the FUNCTION and OFF TIMER buttons at the same time for five seconds. The CHANGE FILTER INDICATOR will flash five times and turn off </li></ol>
on Jun 17, 2011 | Air Purifiers
My delay light has come on and I cant get the dishwasher to start. The delay light goes out after the time has expired but if you try to move it to the start position the light comes on again
The Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). The Control will flash the Clean LED 7 times repeatedly and will disable the Start/Resume key until cleared.
To clear and reset the control press in this order: Heated Dry ? Normal ? Heated Dry ? Normal and then let the unit run for 1-2 minutes and then press Cancel and let the dishwasher complete the cancel cycle. The dishwasher should operate normally again unless it does not detect a temperature rise in the main wash cycle.
It could be caused by a Heater circuit problem if it continues to stop and flash the Clean light.
It could have one of the following failures:
Open in heater.
Open connection or component in heater circuit.
Faulty heater drive circuit on control.
It can also be caused by the wash pump not pumping water past the heater efficiently.
Oct 11, 2016 | Kenmore Dishwashers
My Panasonic split air conditioner has stopped cooling - model:CU-W18DKR. The internal unit and internal fan operate normally. The external unit fan does not run like normal and no compressor sounds f
Sounds like a faulty outdoor controller board. If you are in Australia, call Prime Electronics or Statewide Appliances for spares.
Part number: NPCWA743383
• To make a diagnosis
1. Timer LED start to blink and the unit automatically stops the operation.
2. Press the CHECK button on the remote controller continuously for 5 seconds.
4. Press the "TIMER" or button on the remote controller. The code "H00" (no abnormality) will be displayed and signal will be transmitted to the main unit.
5. Every press of the button (up or down) will increase abnormality numbers and transmit abnormality code signal to the main unit.
6. When the latest abnormality code on the main unit and code transmitted from the remote controller are matched, power LED will light up for 30 seconds and a beep sound (continuously for 4 seconds) will be heard. If no codes are matched, power LED will light up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by pressing the CHECK button continuously for 5 seconds or without any operation the remote control for 30 seconds.
8. The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
Or better yet, get a tech to check first.
Feb 10, 2015 | Panasonic Single Split System - Wall...
Lennox ac stops working after normal shutoff untill i shut off power to air handler turn power back on ac runs till nornal temp reached shuts off will not come back on untill i kill power to air handler...
The 13HPX is a Heat Pump. It has a control board in the outside unit that will lock out after a few trips from one of the controls, such as a low or high pressure switch tripping. Turning the power off is making this board reset. Take the door off next time. to the outside unit and look at the lights on the control board. There should a sticker on the inside the door that you have to remove that describes why the unit is hard locking out according to the light configuration.
Oct 24, 2017 | Heating & Cooling
No sign of life to our 5 year old D/W except flashing "CLEAN" L.E.D.
7-1 heating circuit problem control programmed to shut down machine when no rise in water temp during heat cycle, you either have an open heating element or wire burnt a shorted thermistor or a bad control not outputing 120VAC to the heater you can reset the control by placing the machine into diagnostic hit cancel button to turn off all the lights press heated dry-normal, heated dry- normal within 6 seconds lights should come on press cancel unit should start it will run till same part of cycle reached and lock out again if it has not been removed the little black panel below the door remove should have the tech sheet in a plastic pouch which explains how to check the components mentioned earlier,
Apr 03, 2014 | Whirlpool GU2800XTV Dishwasher
I have SC-PT750 Wireless system with SH-FX65T and SE-FX65, the wireless does not work and the screen flashes W1 to W2 and the SE-FX65 red light stays on
1 Turn on SE-FX65 2 While pressing [>>/>>'] ] press the numbered button [3] on the remote control until "P" lights in the home theater unit's display The indicator on SE-FX65 turns green. 3 While "P" is displayed, press [I/D SET] 4While pressing [>>/>>'} press the numbered button [3] on the remote control.
This worked for me. I moved and lost the FX65A, and Had to buy a replacement off ebay,
Used this manual http://www.specsserver.com/CACHE/FRQUJVMNXTYS.PDF but I have to give mosyzlak props, cause he gave me the idea to look for it.
Nov 28, 2010 | Panasonic Home Theater System System
How do you set the clock on a Pioneer DEH-1600?
To set the clock, please follow the following steps
#1
Press and hold the "SRC/OFF" button on your Pioneer car CD player until the unit powers down. Note that the "SRC/OFF" button is located on the top left of the Pioneer car CD player.
#2
Press and hold the multi-control knob, located on the left side of the CD player. Hold the multi-control knob until the words "Clock Set" appear on the CD player's display.
#3
Turn the multi-control knob until the words "Clock Set" are highlighted. Press the multi-control knob on your Pioneer car CD player to enter the clock setting mode.
#4
Turn the multi-control knob to highlight the "Hours" option. Press and hold the multi-control knob until the hours-place digits begin to flash. Rotate the multi-control knob until the desired value is displayed. Press the multi-control knob on your Pioneer car CD player to save your changes.
#5
Turn the multi-control knob to highlight the "Minutes" option. Hold the multi-control knob until the minutes-place digits begin to flash. Rotate the multi-control knob until the desired minutes value is displayed. Press the multi-control knob to save your changes and end the clock-setting process.
Hope this might help
Thanks
Oct 07, 2010 | Pioneer DEH-1600 CD Player
Blinking red light above the lowest setting on filter queen defender air purifier.
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Sep 23, 2010 | Filter Queen Defender Air Purifier
Hi my hoover 6612 dishwasher does its pre-wash but then when the light for wash comes on it does nothing. I wondered if it might be a capacitor which needed replacing but I can't find one - any ideas??
Check the float switch inside the tub, it should move freely up and down.
Check the harness to the motor
Check start capacitor on the left side of the wash motor
Mar 13, 2009 | Dishwashers
LG DLG5988 Gas Dryer Logo
309 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
