Question about Sony Playstation 3 (PS3) Console
My PS3 does not turn on ,..the yellow and red light blinks
  • 597 Answers
The reason you have the yellow and red light blinking is because thereis a system error. It mainly is a hardware problem that is why it isnot coming on.
You will have to troubleshoot the playstation before you will be able to enjoy it once again.
To troubleshoot it, you will also have to dismantle it and clean up itscomponents and reconnect it properly, then reassemble it back together.
To dismantle it, follow the steps below:
1. Pull the warranty sticker off of the bottom of the PS3.This will void your warranty, so make sure that the problem you are addressingis not covered by your warranty. Note that taking your PS3 to be repaired by someoneother than Sony will still void your warranty. You are not losing anything bytaking apart your PS3 yourself. Under the sticker will be a small piece ofrubber that hides a single screw. Remove the rubber piece and unscrew thescrew. 2. Slide the faceplate off of thePlayStation 3. After the faceplate is removed, you can now separate the twohalves of the plastic covering. Remove and set aside the top piece of theplastic case to expose the internal components of the PS3. On the underside of thetop plastic covering, there will be a memory card slot at the bottom-rightcorner. 3. Locate and remove the Bluetoothcircuit board. Remove the four screws to lift the Bluetooth board free. This islocated at the bottom-left corner of the main body of the PS3 if you have thesystem flat on its side instead of standing up straight. This will look like agreen rectangle with a tan metal covering. 4. Locate the small circuit board that controlsthe power and eject functions of the PlayStation 3. Remove the fourPhillips-head screws in order to separate this piece from the body of thesystem. This is located at the bottom-right corner of the PS3, directly infront of the disc box. 5. Locate and remove theBlu-Ray/PS3 player. This is the large tan metal box that is located in the topright corner of the PS3. Unscrew the player and flip it upside down to exposethe circuit board that controls it. If you want to remove the circuit board,there are five small screws that hold it in place. 6. Remove the power supply fromthe inside of the gaming system. This is located at the top-left corner insidethe PS3. To remove this component, there will be two telephone-like plugs thathave to be unplugged, one at the top and one at the bottom of the power supply.Additionally, there will be 13 screws that hold the power supply in place. Theback and front plastic coverings of the PS3's shell will now easily slide free. 7. Removethe final internal component, which is the PS3's motherboard. In order to dothis, remove the metal covering the rests on top of the motherboard. There willbe 11 screws that border the metal covering as well as four screws in the verycenter, two from each of the rectangular center pieces. Once the screws areremoved, the metal covering will lift off and the motherboard will be able tobe removed.
When you are to reassemble the ps back, secure it is properly connected.
Posted on Oct 14, 2010
  • Toyosi  Sarumi
    Toyosi Sarumi Oct 14, 2010
    If you are not familiar with such technical activities, i will strongly advice you seek professional assistance from a game technician.
    Also check if you are still under the warranty period or purchase, to be able to take it back to the dealer that supplied it to you for better assistance.
    Take care and good luck
    President:
  • 2,653 Answers
You've got the YLOD.
Here's a DIY tutorial on how to fix but I recommend getting it fixed by Sony direct!
5 Suggested Answers
  • 207 Answers
SOURCE: Playstation 3- described as the
Ok here is what I have for you
The Red light is due to the HDD (hard drive).
There is one of 2 problems:
1. The connection is loose or
2. The HDD is just bad.
This was an issue that has been discussed over in the Playstation forums and it seems that re-seating
(removing & reinstalling) the HDD has solved the problem for many but some people have just
received bad hard drives period.
If you reinstall the HDD & it still beeps 3 times & gives you the red light, then you will have to replace
your HDD.
The good news is you can pick up a hd fairly cheap, go to the electronics store and ask.. if you need step by step directions let me know I can help you out there as well!
Posted on May 27, 2008
  • 161 Answers
SOURCE: ps3 won't power up!!
the Yellow Light of Death has hit your console. you must have the unit repaired...or replace it.
Posted on Jun 11, 2009
  • 64 Answers
SOURCE: light turns on, light turns yellow, light turns red and blinks.
Your ps3 has overheated. This is the equivilent to the red ring of death for xbox 360. The ps3 problem is called "yellow light of death" this means your ps3 has died due to the console being overheated. The solution to this problem is either getting a new playstation or take it to a shop in the UK and they could help you fix it for a price around £30-£50 GBP.
Posted on Aug 15, 2009
  • 10 Answers
SOURCE: blinking red light
you got whats called the red ring of dealth is happens if u leave it on for a while and the only thiung to do is send it back to the factory to get it fixed or buy a new one witch i wouldent so just call 1-800-4my-xbox
Posted on Feb 04, 2010
Why wont my ps3 turn on
its got the yellow light of death
Nov 25, 2011 | Sony Playstation 3 (PS3) Console
Light blinks red then turn on and blinks yellow once and back to blinking red
YLOD (yellow light of death) Replace your power supply inside the unit. Can pay Sony $150.00 USD or spend $40.00 USD on E-Bay. Very easy to install. Google PS3 YLOD Repair for indepth instructions.
Oct 03, 2010 | Sony Playstation 3 (PS3) Console
PS3 wont turn on
PS3 red indicator light flashes with yellow means hardware errors and need some maintenance. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only such yellow light flashing problem, you can repair other red and yellow light related issues as well.After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
Jul 19, 2010 | Sony Playstation 3 (PS3) Console
Green, yellow & red light. blinking light. does not turn on.
Sorry to give you the bad news but their is nothing you can do for it... Need to call sony and have them fix it.. if you ps3 is older then a year .. you will pay about $100 .. but i would tell them its not that old and you want them to fix it for free.. it worked for me... oo and all your data .. its lost .. lost forever... sorry
May 10, 2010 | Sony Playstation 3 (PS3) Console
It's blinking and the light won't stop blinking the it turns off by its self
sorry but its called the yellow light of death..look on youtube or google ylod or yellow light of death solutions...its called this bc when u turn on ps3..the light is green for a moment, then yellow, and finally blinks red...sony charges $150 to fix...google and youtube will show you how to do it....youll need some electronic skills
Nov 07, 2009 | Sony Playstation 3 (PS3) Console
Light turns on, light turns yellow, light turns red and blinks.
Aug 06, 2009 | Sony Playstation 3 (PS3) Console
Ps3 won't power up!!
Jun 11, 2009 | Sony Playstation 3 (PS3) Console
Bar light turns from green to yellow to blinking red
this is similar to the red blinking lights on the xbox360...it seems your cell processor has overheated resulting in a cold solder joint or worse bridged solder involving the BGA array...I have had some sucess in fixing these albeit limited. sony charges 150 plus state tax and sends you a refurbished unit.
Nov 11, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
177 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
