I have a black in the upper right hand side of my lap top screen which doesn't go away. Sometimes the screen has lines that go across the screen that that roll then stop. The line in the cornerdoesn't go away.
    President:
  • 2,653 Answers
Your lcd is failing. The easiest and cheapest way to fix it is to take the lcd housing apart and find the model number of the lcd itself. Usually it's something like LQ15245-L03
Go on ebay, find a matching one, YES the "-L03" or whatever number your laptop has matters, and just swap it out.
If you provide me the model number of your laptop I might be able to dig up a tutorial on the whole process too.
Hope this info helps!
Posted on Oct 14, 2010
Black line inch thick right hand side
Get rid of it! I started out with the small black smoky line, went to two horizontal line, , , , I now have a 10 " line half way across the screen in two places and the rest of the line is 4-6". Contact Samsung three times on line and they responded with " we do not understand the problem, please explain. Oh yeah, TV was 2.5 years old. Never will buy Samsung again.
Mar 08, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
The screen on my lap top has had 3 very thin lines across the screen but if you tilt it they go now sometimes they screen fades away and i have to move the screen again this is getting worse could it be...
I'm a laptop repair technician, and in my experience the very thin horizontal or vertical lines are usually caused by malfunction in the display panel and the entire screen has to be replaced. If might be worth a shot for you to try and reseat the LCD cable though, but I doubt that it will work.
Sep 23, 2011 | Packard Bell EASYNOTE R1004 COMPATIBLE...
I have a Samsung LN46A650 LCD TV and recently I started getting a white line across the top of the screen. Sometimes the white line is thicker on the left side of the screen. Sometimes after the white...
Yes, it's the t-con board, a well know problem in this tv. Here it is
http://www.partstore.com/Part/Samsung/Samsung/LN46A650/Samsung/Samsung/BN8101697A/New.aspx
Sep 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
Upper third of Sony Reader 600 is corrupted. Black vertical lines and some missing horizontal lines which cut across words making them unreadable.
Those lines of pixels aren't commanded properly. Dismantle the unit completely and reseat the cable that goes top the screen - if that doesn't fixes it then the screen itself is damaged, it will have to be replaced.
If your reader is less than one year old take it back to the dealer - it's still under warranty and they will fix it for free.
Sep 10, 2011 | Computers & Internet
Verticle lines across my dell lap top
Put your screen saver to black..let the screen saver come on if lines are there you need a new lcd.....if lines are not there uninstalll all graphics drivers reboot your laptop and reinstall this will fix it if not your lcd screen is on its way out.....NEVER CLOSE YOUR LAPTOP AND STAND ON IT THAT IS JUST SILLY THINK ABOUT IT PEOPLE I MEAN COME ON HOW STUPID CAN YOU GET YES PUTTING PRESSURE ON THE LCD WILL REMOVE THE LINES FOR A WHILE BUT THEY WILL COME BACK.
Aug 22, 2009 | Compaq Presario M2000 Notebook
Vertical Line on Lap Top
One or both of the following:
Your signal processor is failing OR the lcd display panel itself is failing. When one fails it's prudent to replace both.
Jun 04, 2009 | Compaq Presario M2000 Notebook
Blue line down right hand side of screen
If you are confident enough to open screen bezel and take out screen , then the second strap from right of your screen has a bad connection. theses cannot be repaired but as a tempory measure some duct tape across the connections will cure it, else replace the screen.
Mar 16, 2009 | Acer Aspire 9500 Notebook
MacBook opening screen leaves a one inch black strip on both sides.
use the gray bar on top to move the screen to the upper left hand corner.  Then click and drag the bottom right portion of the screen to the size that you want it be.
Mar 21, 2008 | Apple MacBook PC Notebook
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
