Question about Toshiba Satellite A55-S326 Notebook
Can't see HDD on boot BIOS does not see any HDD. only wants to boot from a networked sys to get os. How can I change the BIOS to recognize a drive with XP installed on it, without a boot disk. Pg. 2 in BIOS says Built-in = No Drive
    President:
  • 2,653 Answers
If the BIOS doesn't recognize the drive then there's a problem with the drive itself.
You'll need to swap it out with a new one. I'd recommend hooking up the old drive to a usb enclosure to double check whether the drive works or not.
OR you can just swap it out with the new one and reinstall the os.
Let me know if you have any questions, I specialize in data recovery ;)
Posted on Oct 14, 2010
Bios does not see secondary hdd
If you are trying to boot from this drive you have to go into bios and change the boot order.
Jun 30, 2014 | Seagate Barracuda 7200.7 160 GB Hard Drive
PXE-E61 media failure when i start up my computer
The PXE-E61 failure is a failure to boot to the network card, this generally indicates a problem with the hard disk drive.
  1. Boot to the BIOS and reset the defaults
  2. Reseat the hard drive
  3. Boot to Windows CD and run CHKDSK /R on HDD
If the system will not boot to the HDD, but it is seen in BIOS, then the HDD may have an OS issue, if not detected in BIOS HDD likely has failed.
Mar 02, 2010 | Acer Aspire 5315 Notebook
Medion akoya e1210 notebook. failure to boot pxe
Failure to boot PXE 061 is a BIOS message that indicates 2 things:
  1. System failed to boot to the hard drive
  2. System failed to boot to a network connection
The apparent problem is failure to boot to the hard disk. If the system was running yesterday and there have been no hardware changes to the system, then most likely failures are:
  1. HDD failure (Replace the HDD, reinstall OS and applications) I hope you have information backed up.
  2. HDD not being detected by the motherboard due to connection issue (Remove HDD and reseat it, then see if seen in BIOS) If no change replace hard drive, if new drive not seen, replace motherboard
Jan 11, 2010 | Computers & Internet
New HDD not recognising on laptop
what size capacity is the new hard drive - and what is the bios on your laptop able to recognise ?
is it an upto date laptop ?
some old bios's unable to see newer larger drives....
try updating the bios of your laptop
or use a hdd prep programme
Oct 11, 2009 | Computers & Internet
Just replaced the HDD in my Toshiba Satellite M55-S329 from a 100GB to a 320GB after the old HDD failed. Now after replacing the HDD, it does recognize the hDD but I get the error message "pxe-e61 media...
You have to change to boot order in the bios settings, it is currently trying to boot from a network drive, it needs to be set to the HDD you just installed.
Jul 27, 2009 | Toshiba Satellite M55-S329 Notebook
I'm getting a PXE-061: Media test failure, check cable. message what do I do?
That message means that the machine can't find any OS on the local drive, so it's trying to boot from the network, and no network cable is attached.
The most obvious possiblities are:
1) There is no OS on the HDD
2) The HDD is not installed or not installed correctly
3) The BIOS boot order has the network boot before the HDD
Jul 04, 2009 | Computers & Internet
Sata HDD set in primary master in Bios
Try considering these:
1. DOS disk doesn't recognize SATA, that's the truth
2. You're going to have a problem if you install OS in your computer (solution: do not select SATA in HDD type but rather IDE)
3. For your SATA HDD to become primary (boot first) try to select your SATA HDD as devic first to boot..
Jan 04, 2009 | Maxtor Hard Drive
Drive has power but fails to come on
hi if try bios setting then setup it..
Open your hdd Drive change your jumper .....restart your pc put in Any OS Xp Driver...press ok enter 5 times if it boot then format & setup it....
Jun 29, 2008 | Western Digital Caviar (wd800lb) 80 GB...
Dell Latitude will not boot
Reseat the hard drive and then get into bios and check if the hdd is detected ,if not you need to replace the hdd ,if detected reinstall the OS.
Apr 03, 2008 | Dell Latitude C600 Notebook
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Feb 11, 2008 | Computers & Internet
Toshiba Satellite A55-S326 Notebook Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
