Question about Tag Heuer Carrera Auto CV2113.FC6180 Wrist Watch
I have a Tag Heuer Grand Carrera. It worked perfectly for a year. But now, it doesnt work. When I shake the watch, it starts and then stops again after few minutes. I was told to wind it. But I dont know which key. Please help.
    President:
  • 2,501 Answers
If your watch is "automatic" then would I be right in thinking you took it off for a few days and it stopped?
If this is the case (since most of the Carrera range are automatic, then the spring will have run down and needs re-winding.
You were correct in thinking that shaking it will re- start it but to keep it going you need to shake it gently from side to side for some time. (One supplier quoted 500 times!) be patient and keep wearing it.
Posted on Oct 14, 2010
I have had my Grand Carrera for 7 months and I don't always wear it every day. Recently, I noticed the hands quit moving, usually a light shake would restart them. There is also a noise when I move the...
This sounds to me as the Oscillating weight is getting loose and touching the movement. There could be a loose screw as well. That's why your watch is stopping (not enough power to fully auto-wind the spring). There is nothing you can do, I'm afraid, but to show watch to the watchmaker for proper inspection. The longer you'll wear it as it is - the more damage will be done.
Feb 26, 2011 | Tag Heuer Grand Carrera 17 RS CAV511B...
My watch stops very often its tag heuer grand carrera calibre 17 rs2 automatic one what do i need to do for continuous running of my watch
It rather depends what you mean by "very often".
An automatic watch will run for 2-3 days before stoping if it is not used.
These watches thrive on being used and are best used every day.
It could be that your watch needs cleaning (I had one that was like that when I bought it and I had it cleaned and it ran for years after that).
Jan 21, 2011 | Tag Heuer Grand Carrera 17 RS CAV511B...
My tag heuer carrera stop watch doesnt reset properly, when u reset the stopwatch it goes one minute behind and doesnt reset to zero. how do i fix this. it never resets to zero and the red hands on the sub...
Try this.
Pull the winder out fully. Then press the top right chronograph button to move the centre seconds hand on. Then push the winder back in.
on some models you should only pull the winder half way out.
good luck
Sep 23, 2010 | Tag Heuer Carrera Tachymetre CV2013.FC6206...
Hi.i just boughta tag heuer grand carrera xx007344.immediately i got home,it stopped working.so,after abit of winding it starta working.but if i just drop for a minute or two,it stops working.even when...
Automatic watches will generally run for 2-3 days before the spring is fully unwound, so you are likely to have bought the watch in the unwound condition.
It can be wound by gently shaking the watch from side to side (for about 100-200 times). This should give it sufficent engergy to operate and thereafter normal use will keep it wound up.
If it stops working when the watch is rotated out of the face up position, then it may be that the watch is faulty. (If the watch has been dropped in transit, it may have been damaged).
If normal operation is not achieved, then send it back to get it repaired under warranty.
May 04, 2010 | Tag Heuer WAF2110.BA0806 Aquaracer...
Hi my tag heuer monaco has stopped working but when i wind it to the correct time it starts again for a while, what is wrong with it
I'm sure its an automatic - next time it stops do not set time just shake it and see it if starts again - automatics need to be worn most of the day to last during the night
Mar 04, 2010 | Tag Heuer Watches
I have a TAG HEUER Grand Carrera and the second has stopped
Are you aware that these are automatic watches and need to be moved to keep the watch going, kinetic energy winds up the movement which allows it to keep going, if it is left off your wrist and in a drawer or sat stationary it will stop. Shake it violently (without dropping it) and it will restart.
Aug 26, 2009 | Watches
Tag heuer automatic series, how do you start the watch after purchasing?
push the crown in if it is in the adjust position .then shake the watch around the auto mechanism sould start the watch
Aug 23, 2009 | Tag Heuer Automatic Chronograph Series...
Tag automatic watch = stopped working
Stop shaking it!
You could try wearing it and it should wind itself with your body motion or...
your could manually wind it (setting 1)
Jan 22, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Tag heuer link automatic
exact same problem, no one seems to know
Oct 26, 2008 | Tag Heuer Link Automatic Chronometer...
Tag heuer carrera automatic wv211a
Your watch is a automatic. All automatics need to wind-up before being worn at first , or if not worn all the time. Automatics will work with-out being wound ,but will not keep time. Wind your watch at least 50 turns (using the crown) or shake about 150 times , and then try it . Automatics need that back-up power to insure it's accuracy.
Jun 19, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Open Questions:
See all Tag Heuer Carrera Auto CV2113.FC6180 Wrist Watch Questions
Tag Heuer Carrera Auto CV2113.FC6180 Wrist Watch Logo
1,214 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
