Question about Kitchen Ranges
I have a frigidaire gallery self-cleaning convection oven and not sure how to use the self-cleaning option. When I hit the clean button and time the word "door" shows up on the screen and I have no idea on how to lock it. There is no manual lever. There was no manual left for the stove when I moved into my home.
  • 868 Answers
You have to select the level (usually 3 choices)of heat.If you dont it will wait for the command and then do nothing.Is there a shield that you have to pull up to block the window??
Posted on Jun 02, 2008
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
Accidentally hit clean button on a Frigidaire Gallery Oven. Hit Cancel button. Oven door won't open.
I appreciate your post, C Maury!
From my understanding your hit the clean button on your Frigidaire wall oven and now the door will not open. I would hold down the cancel button for at least ten seconds, this should unlock the door. If that does not help I would recommend disconnecting power from your wall oven by flipping the household circuit breaker for ten minutes. I hope this information was helpful to some degree. -Matt
Nov 20, 2014 | Frigidaire 30 in. Electric Gallery Series...
Lost manual for Frigidaire gallery gas oven. need to know how to use convection baking
What model Frigidaire oven do you have? Most Frigidaire manuals are available from the manufacturer's site: http://b2b.frigidaire.com/support/manuals.asp or http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/ . Note: these manuals are in the PDF format; you will need Adobe Reader or a similar program to read them.
For example the User's manual for the FGGF3054MW range (with convection oven) is available at http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316901218en.pdf .
I hope this helps.
Apr 13, 2013 | Frigidaire Gallery 30" Self-Cleaning...
How do i fix the light socket to my Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range
Hi michell51238 - From what you are describing it sounds like the range may possibly have a faulty light switch or wiring failure that only a professional can repair. I personally recommend consulting a certified technician for a proper diagnosis and to move forward accurately.
Feb 22, 2013 | Frigidaire Gallery 30" Self-Cleaning...
What is the bake speed button used for?
Hello Loretta Skourn - Generally speaking, the bake speed option uses the inside heat and convection feature a little more to increase the cooking time.
Dec 11, 2012 | Frigidaire Gallery 30" Self-Cleaning...
How do I begin to clean the self cleaning gallery convection oven? I pushed "clean" but the oven door did not lock.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 25, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Self cleaning feature does not start.
heatman101
Sep 04, 2010 | Frigidaire Gallery 30" Self-Cleaning...
Can't turn self cleaning oven off.. baby pressed button by accident
Here is a tip that I wrote about the self cleaning feature that also gives some things to try when it does not turn off...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 05, 2010 | Frigidaire Gallery 30" Self-Cleaning...
How do I self clean my gallery series fridgidaire?
Some of the self cleaning ranges require that the door be locked before the self-cleaning cycle will work. If your oven door has a manual locking lever then make sure it is completely latchedthen press the self-clean button. Also make sure the dooris completely closed because if there is not a manual latch then it will be a auto latching system. If not then there could be a problem with the button on the control panel for the self cleaning option.
Jan 14, 2010 | Kitchen Ranges
Frigidaire Gallery Stainless steel convection oven professional series
i have a frigidare gellery oven i cleaned it and now my broiler an oven wont work
Jul 04, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kitchen Ranges Logo
160 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
