Question about Microwave Ovens
Hi On a Whirlpool trash compactor model# SHC850002--it will run as long as start knob is held.I,ve never had to service a compactor but if circuit is much like a dryer I would be picking on the motor. I had same thing happen on a Kenmore compact dryer-the one time thermal fuse on blower housing blew.Do compactors have any thermal fuses in motor circuit? Rene
  • Rene Matz Oct 14, 2010
    Heading to the house this morning to repair their dishwasher--
    will take a look at trash compactor.
    Thanks again. Rene
  • 3,247 Answers
Not sure how your compactor problem ended up in the Microwave category.
Does your model have an on/off switch? Normally you can only operate the start knob if the on/off switch is in the on position. This is a safety system. You can have a look at the assembly diagram for different sections.
I don't think there is any resemblence with the dryer but the unit is highly mechanical with chain drivers and power screws.
You should check out the start switch and the on/off switch for operation.
Hope this helps you find the reason for the problem. Please rate the solution to help fixya serve you better in future.
Posted on Oct 14, 2010
Kitchenaid trash compactor bought in 2000; no model/serial number found. Compactor was stuck in partial down position; worked the drawer out and found cotton fibers wadded/stuck at top of the up/down...
at the top, above the ram, there are two switches. One is the reversing switch (should have 4 wires), the other is the stop switch (2 wires). I suspect that the switch arm is bent, due to what you just described, and fails to activate the switch to stop the motor when the ram is at the top position.
May 24, 2011 | KitchenAid Microwave Ovens
Need new timer dial knobs for whirlpool microwave model no avm 515, purchased in South Africa, but now in Australia?
Have you tried Whirlpool Australia? Or call 1300 363 344?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 18, 2008 | Whirlpool Microwave Ovens
The trash compactor won't open and it locked shut. When the dial is on the "ON" position, the unit just hums.
Check the mechanism for the door failure as the link could be caught up . open the top cover and find this out.
The hum could be the failure of the capacitor which could be short.
The microwave will not work then, so replace and check this out.
Aug 21, 2010 | Microwave Ovens
Microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 15, 2010 | Whirlpool MH7140XF Microwave Oven
My Jenn Aire Trash Compactor Model TC507B1 does not turn. When I turn the start knob to on position, the compactor makes humming sound, but it does not seem that the ram is moving. I have checked the...
Sounds like the motor that turns the reduction gears which ultimately pushes the ram could be seized up. If an object was jammed inside which was to much for the motor to handle it could cause it to draw too much current seize up the motor.
Jan 24, 2010 | Microwave Ovens
My Jenn Aire Trash Compactor Model TC507B1 does not turn. When I turn the start knob to on position, the compactor makes humming sound, but it does not seem that the ram is moving. Now, I can't even open...
We had the very same problem. Pull the compactor out and unplug the unit. Lay it on its side and remove the bottom. This will expose the chain and gears. On our unit, the plastic sprocket was broken. This part turns the chain to make the ram go up and down. When I called about a local location to buy a new part, I was given 1-800-688-9900 to phone for help. Tell the automated service you want "parts" and you will get an operator. I described the part and she said that is was no longer made in plastic -- it's now metal. The part number she gave me was #675370. I could've ordered the part through them and would receive it in 3 business days. With our zip code, she was able to give me two locations in our area to get the part. One place had the plastic part -- no thanks. The other place was able to get the part in the next day. Hope this helps more than solutions 1-3.
Jan 23, 2010 | Microwave Ovens
Whirlpool mircowave will not heat
HI, the high voltage capacitor is unstable and, it has damaged the Magnetron. you will need to replace the Magnetron. it will run you about $191.30. this will restore the heating action in your microwave unit.
May 27, 2009 | Whirlpool MH6130XEB/Q Microwave Oven
I locked my whirlpool microwave and i dont know how to unlock it
I have a Whirlpool toom which states in manual: -- To lock/Unlock....Touch and hold START?ENTER for 5 second until 2 tones sound and "L" appears on dsplay. Repeat the same if you lock or unlock. Hope this helps.
Mar 21, 2009 | Whirlpool MH7140XF Microwave Oven
Need stirrer cover for microwave
THAT MUST BE A GOOD MICROWAVE. I'M SO SORRY I COULD HAVE GIVEN YOU MY MICROWAVE.I JUST TRASH MINE IT WAS A WHIRLPOOL TOO BUT IT WAS A 2002 WELL TRY HHGREG GOOD LUCK!!!!!!!!!!!!!!
Jul 14, 2007 | Whirlpool GT4185SK Microwave Oven
Microwave Ovens Logo
78 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
