Home | Kenmore | 54351 Dehumidifier | No 120v to fan motor
Kenmore 54351 Dehumidifier
Problem for Kenmore 54351 Dehumidifier
By Bert55 on Jun 02, 2008
Do not have 120 v from fan relay to fan motor, can not tell if relay is closed, no test point available from top of board. Everything else appears to work!
Comments:
Jun 02, 2008
- I should have stated that the compressor comes on and stays on. I dont know what pulls in the low voltage fan relay. Fan never turns on because it's not getting 120 V from the fan relay.
Thanks, Bert55
Best Solution
posted on Jun 02, 2008
Helpful)
Illeagle
Rank: Guru
Rating: 88%, 459 votes
It sounds as if this may have electronic controls on it. If so, the problem could be related to too low of an ambient temperature or too low humidity in the air. If this design has a temperature sensor built into it, you may be experiencing "hibernation mode", where the unit will appear to be dead, when it is actually awaiting the proper temperature to employ itself.
The following statement is a parameter for all dehumidifiers and some of the control issues may vary, but the theory is the same.
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Comments:
Jun 03, 2008
- The control board sends the power to the relay, so if you have no low voltage to the relay then the circuit board will need to be replaced.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Kenmore 54351 Dehumidifier
Questions and Unsolved Problems for Kenmore 54351 Dehumidifier
Do you recommend Kenmore 54351 Dehumidifier?
Answer
Answer
Dehumidifier fan runs lights turn on but only get about a cup of water after all day running.... (More)
Answer
Mine has stopped running because it has reset itself to 01% from 50%. But you can't manually change... (More)
Answer
i have a kenmore and it frost over all the time when it running.
Answer
Kenmore dehumidifier model 580-54351400- replaced fan motor but overheaqts and does not collect... (More)
Answer
ran fine for a couple of weeks. emptied bucket several times. Then would not start for several days.... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 54351 Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
