Question about Frigidaire ATF6000ES Front Load Washer
When u turn washer on it humms and no water comes on...checked everything and its all working?
  • 1,557 Answers
Normaly humming is due to no water from the hose make sure the tap is on if so then i would have the water inlet valves looked at
Posted on Oct 14, 2010
Testimonial: "thanks"
I have a frigid afire gallery series washer lights up and just humms, won't fill with water. I checked water pump and motor,not ether one of those humming
I WOULD CHECK MY WATER INLET VALVE, DO U HAVE WATER FROM THE HOUSE WATER OUTLET TO THE WASHER WORKING? NOTE" A BAD CONTROL BOARD CAN SEND A WRONG MESSAGE TO THE INLET VALVE? POSSIBLY IF NOT THE VALVE ITSELF, CHECK IT WITH A METER FOR CONTINUITY
May 13, 2014 | Frigidaire Washing Machines
Water not pumping out of machine-zanusi aquarius wf000
1. Check that the water tube is properly fixed
2. The tap is on
3. The program is on
If you hear a humm sound without water means that the valve is open but is closed before that.
If no humm is heard then the valve could be broken.
Apr 02, 2014 | Hotpoint Aquarius WF000 Front Load Washer
I replaced the hot & cold water valves on my LG Washer/Dryer .Now it just humms and no water goes into the washer..What can cause this problem?
have you tried both the cold and hot?hot only has one solenoid while the cold has three.just because it is a new part dose not mean it is not mean it is a good part.try this,turn off the cold and hot water,remove the cold hose from the washer and put it in a bucket and turn it on at the hose bib.if you do not get water,you may have a screen in the hose bib end of the hose.if no screen on that end you may have a metal fitting rusted up just under the hose bib.check the hot side also.hope this helps,if not repost and i will try to dig deeper.thanks
Mar 15, 2014 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
I just moved into a new apartment and used a moving company to help me with my move. that included my washing machine. i just went to turn it on to do a load and it won't start. i hear a humm noise but...
Hi
Make sure the water taps are turned on. The humming sound is most likely from your inlet solenoids.
Check both the hot and cold water inlet hoses going to the back of your machine. Make sure they are connected properly and that the water is turned on.
If still no joy let me know and I will guide you through more trouble shooting items.
Ash
Sep 02, 2011 | Whirlpool LSR5132PQ Top Load Washer
Dryer will not start, just humms
sounds like the drum belt maybe broken or worn out.
May 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
Water authority turned off water & washer not working now
Disturbing the water supply caused sediment to flow in and block the inlet screen(s) on your washer. Take the supply hoses off and look inside the part they screwed off of to find screens. Remove the screens and clean. Reinstall. Check that there are not filter style hose washers in either end of the supply hoses which may need to be cleaned out.
Jan 06, 2009 | GE Energy Star WCVH6260F Front Load Washer
Won't fill
check to see if the water is turned on? do you hear a light buzzing or humm noise?
Jul 26, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire ATF6000ES Front Load Washer Logo
261 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
