Question about Dishwashers
Hello: My Maytag Bravo 300 quiet series is filling with water at the start of the cycle, however it does not spin. The agitator is free and moves completly around manually. The code f-51 comes up... I would appreciate any help you could offer me! Thanks, Maria
  • mariaalex433 Oct 14, 2010
    Hello again: I explained yesterday about the problem with my clothes washer and you asked for the model number... it is MVW8700VQD and the washer is the Bravos quiet series 300.. I hope this info. is helpful... I really appreciate your input and the time you are spending on the solution to my problem!! Thanks, Maria
  • Dishwashers Master
  • 3,247 Answers
It would help if you are able to provide the actual model number of your dishwasher.
Bravo 300 has several models and the structure of the machine can vary.
Generally f51 error comes when the wash motor rotor is having some problems.
The problem could be in the electricals.
Happy to provide more details if you post the model no.
Posted on Oct 14, 2010
  • Sam Oct 15, 2010
    You may have not realised this but the problem with your clothes washer is included in the dishwasher category and hence my confusion.
    Thanks for providing the model no. However I am assuming the model no. is MVWB700VQ as the 8 could be a B.
    If you do not have a user manual for this you can dowload it from this site. As you will notice on page 13 the "F##" codes are malfunction codes and if it does not go away after pressing Power/ Cancel you have to call Maytag support.
    However, having said that the problem is linked to the rotary position sensor (RPS) which you can see in this diagram on page 5. Part no. 20.
    People have had to replace this to get rid of the F51 error. I am not sure if you are going to replace it yourself. The part looks like this.
    I hope all this helps you with the solution. Please rate the solution if useful otherwise post a comment and I will try to help further if I can.
    Thankyou for using fixya.com.
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Sep 05, 2010 | Washing Machines
Maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
John
Jan 15, 2010 | Maytag Washing Machines
Maytag quiet series 300 leaks from front
check the float switch on the righthand side on the bottom in the corner it should click and move freely
Dec 16, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Washer won't advance from cycle to cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 16, 2008 | Danby DDW1805W Designer Series...
I have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. I can manually hit the start button twice and it will go...
Hi jeffwirch,
I'm Harvey the Master Plumber.
Your problem is: You have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. You can manually hit the start button twice and it will go through a 2 minute cycle and pump out the water. You have cleaned the filter inside the dishwasher where it drains and have checked the hose to the disposal and it pumps out fine. It just doen't pump itself at the end of the cycle.
It sounds like a bad control board. It's in the top of the door panel. I don't recomend this repair to the average homeowner. You might consider the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Maytag Dishwashers
Maytag MDB7600 issues
reach inside your d/w and jiggle the mushroom shaped float switch located on floor of d/w. should move freely up and down if its stuck up(or something lodged under it your unit wont fill with water
Mar 20, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Dishwashers Logo
107 people viewed this question
Top Dishwashers Experts
Owen Barnes
