Question about CyberPower Office Power 585AVR (obcps585avr_1) UPS System
On/of button I believe we had a power surge while out of town, as the on/off button to the 585avr continues to click/pulsate approx every 5 seconds.  Our computer is plugged into the unit and is working fine.  We have disconnected/reconnected the unit; however, it continues to click/pulsate.
    Problem Solver:
  • 31 Answers
Check the fuse on the ups
Posted on Jun 05, 2008
Own a dc59 it surges dyson said need new filter. They sent one. Put it in vac still surges
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it maybe due to a battery of the unit. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc59
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 28, 2016 | Dyson Vacuums
Dyson v6 surges on and off
There are a number of things you need to do that may solve the issue you're having with your vacuum. First, make sure that your battery is charging and working. Second, check the MAX button. If the MAX button lights up and flashes when your Dyson cordless vacuum keeps pulsating on and off, hold the power button and depress the MAX button to turn off that function. You may have to try a few times to get the hang of it. And lastly, look for any blockages in attachments because the pulsating is caused by a lack of airflow as the motor is protecting itself by pulsating and then ultimately cutting out.
You can check this video tutorial which will teach you on how you may fix it:
https://www.thinkcrucial.com/search?type=product&q=dyson
Ava B.
Sep 18, 2016 | Dyson V6 Motorhead Bagless Cordless Stick...
2003 Chrysler town & country limited
First try and change the fuel filter. this also happened on a van i worked on. I cahnged the filter and it runs fine now.
Nov 16, 2011 | 2003 Chrysler Town & Country
585avr isn't working w/vista OS,
While the 585AVR is not designed for Vista, it should work. You will need to use the CyberPower serial to USB cable, and the most recent version of PowerPanel Personal Edition software. You can download the latest software @ http://www.cyberpowersystems.com/software/PPPE_V_1.2.2_Setup.exe
If you have any questions, or need the CyberPower serial to USB cable, please contact CyberPower Systems Technical Support at 877-297-6937, M-F, 8-5 Central.
Oct 31, 2008 | CyberPower Office Power 585AVR...
TV Zoom mode
Change the batteries on the remote, point the remote at the Sony, and hold in the power button for 5-7 seconds. Then depress and re-press the power button - see if you can get the tv remote to respond again.
Then, always try the quick reset:
How to perform a power reset on a Sony® television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
May 16, 2008 | Sony KV-32FS13 TV
Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
Oct 17, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Pulsating power LED. No picture. No sound
Either the main smoothing capacitor or the voltage regulator are faulty. You may find that the power LED will stay on after pulsating for several minutes, at which time you can switch the TV on.
Aug 08, 2007 | Hitachi C25-RF35S 25" TV
CyberPower Office Power 585AVR (obcps585avr_1) UPS System Logo
104 people viewed this question
Top CyberPower Computers & Internet Experts
George Nalley
Level 1 Expert
Paul Bade
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
