Question about Frigidaire FRS6R5ESB
Freezer ok frigde not cold - Frigidaire FRS6R5ESB
My Frigde stopped being cold
Maybe check thermostat??
Nov 30, 2013 | Refrigerators
Refrigerator section not cold. Light is on inside the refrigerator but temperature is not working. Freezer bottom is functioning. Purchased the frigde less then a year.
I would start by checking to see if the evaporator fanis running . It moves the cold air from the freezer up into the refrigerator compartment
Jun 22, 2011 | LG 24.7 Cu. Ft. Side-by-Side Refrigerator...
My fridge/freezer defrost itself last night and the freezing and frigde temperatures went low and my frozen food was all thawed
manually rotate your defrost timer maybe it stuck up and the contact was on the defrost heater. adjust your thermostat setting to coldness then observe unit.
Mar 05, 2011 | Refrigerators
The frigde is turned dow but still freezing all
your cold temperature control is bad, not shutting the unit down when the temperature is correct. needs to be replaced.
Mar 23, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Refrig not cold but freezer is ok
theres is blocking the flow vent you have to thaw the freezer best bet unplug for couple of hours the you should be good if freezer temp is set too low ice builds up behind the back panel and blocks vent to frigde part
Aug 27, 2009 | Kenmore Refrigerators
My freezers works but my refrigerator
make sure all your fans are turning. maybe try to remove the knobs and see if you can turn them without the knobs, possibly they could be stripped.
Apr 22, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Frigde freezer
Sound like door seal is not closing tightly allowing moisture to be drawn in and freeze the contents. Below is a link with Q&A and solutions. Try this link and get back with us to help you get this fixed. Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Feb 01, 2009 | Thetford N641
Frigde not cooling bottom freezer all frozen up on back plate
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2008 | Fisher and Paykel E522BLX Bottom Freezer...
Frigidaire FRS6R5ESB Logo
53 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
