Question about Amphion Mediaworks T342 System
My T342 has decided that there is no dvd in the tray and it will not open the tray. The display reads load then after a while it read no dvd and so you push the open/eject then it reads open and you can hear a whizzing sound but no tray. Help it has the master and only copy of my daughters wedding in it. Don't care if it never works again just need me DVD
3 Suggested Answers
  • 125 Answers
SOURCE: wrong region
i used this same procedure^on a different model. The number is entered via remote control pointing to the unit. after entering the right code, there should be a secret menu that will appear when you press setup , mine appeared as preference. On this menu, you can find the region. You can fiddle around, you cannot destroy the unit. The info is here: http://www.videohelp.com/dvdhacks/amw-v99/3349 maybe you can read what the other people have done.
Posted on May 15, 2007
SOURCE: DVD Player S99
just use yelloew out and red white for sound left right those red whites are into tv input on back 1 or 2 yellow in yellw for video red in red for right sound white for left sound then turn on dvd player use tvs remote select input 1 or 2 thats it hit play
Posted on Mar 13, 2008
It's displaying "TRAY ERROR", why can't I open trays. Thanks
Maybe the time to load the disc is not made fast enough , bad timing because of a bad drive belt that will load the tray but there is also a microswitch that will be activate somewhere on the tray if its closed the laser if disc was loaded that will activate the focussing of the laser to read table of contents . a little suggestion comes here .
How to Fix stuck CD Tray
Mar 13, 2016 | Televison & Video
Have a panosonic dmr-ez485v dvd recorder that cycles 5/6x when tray is closed with/without a dvd, and get "no read' message.
1.The DVD Drive makes two-three times noise than stop spin the media CD
or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray,
close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Feb 01, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
How can I stop a dvd player from reading non-stop with no disc in player---player is not on lock but refuses to open.
Power off, then disconnect from the wall plug.This resets the dvd. after five ninutes, reconnect the power and start the combo. Should have 'load' on the display, then open the tray of the dvd.When you close the tray, it will try to 'read' a dvd again.
Aug 16, 2010 | Philips Magnavox DVD/VCR Dual Player
Tray not opening
that is probly the loading belt;try open it removed manuallly the disk and open the tirror
and replaced the belt..and by the clean the laser lens
hope that will help
May 04, 2010 | Koss KD250 DVD Player
The xbox can't read the unscratched and clean discs
yeah, you can keep opening and closing it till it works or you can send it in to get it repaired. i tried every way possible to fix it, but i couldnt. something in the dvd drive has gone out and won't read discs the same anymore.
Dec 17, 2009 | Microsoft Xbox 360 Console
Cds fine; dvds won't load
Most likely the DVD laser lens is dirty. Unplug the CH-DVD 300 from the wall outlet, wait 5 minutes, then remove the top cover. Next, remove the rectangular metal plate which covers the area where the CD or DVD disc would be when in the player's tray. Underneath the rectangular plate you should see two small lenses. Gently clean these lenses using ear swabs moistened with isopropyl alcohol. Reassemble the CH-DVD 300 in the reverse order that you disassembled it, plug it back into power, and now it should read your DVD discs just fine.
Aug 13, 2009 | Cyberhome CH-DVD 300 DVD Player
Sanyo dvw 6000 dvd/vcr player
DVD loading mechanism doesn't load completely that's why opens after attempt of loading.
You need to open top cover of unit and inspect loading belt might be lose, tray timing can be out of phase, some wire got stuck with tray while loading etc.
Oct 02, 2008 | Sanyo DVW-6100 DVD Player/VCR
When a disc is loaded, it reads "no disc".
Okay, so I had this problem a few days ago and started watching movies on my X-box 360. Then my X-Box came up with the same error as my DVD player. After reading countless reviews and e-mailing Samsung, I read somewhere that someone had pummeled their X-Box until it adjusted the laser back.
So, I pummeled my DVD and X-Box into oblivion and oddly enough both of them are working. Don't go crazy smacking it but give it some sturdy hits right above the CD tray as you are putting CD's in and opening the tray. Worked for me and hope it helps...
Aug 17, 2008 | Samsung DVD-HD850 DVD Player
DVD will no eject
This is not helpful. The power is on and display is on, but no response.
Jun 20, 2007 | Zenith XBV443 DVD Player/VCR
Can not open the dvd tray
My DVD Drawer was stuck to.
Thanks; I hit both the top and bottom of the DVD player and lo and behold the drawer popped right open!
Jan 22, 2007 | Gateway AR-230 DVD Recorder
Amphion Mediaworks T342 System Logo
Top Amphion Mediaworks Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Amphion Mediaworks Audio Player and Recorder Expert? Answer questions, earn points and help others
