Encoding error when rending menu - Computers & Internet
  • 1 more comment
  • brooster1982 Oct 14, 2010
    Im trying to burn pictures but Im having encoding errors
    Im trying to burn somr pictures and Im having encoding errors
    Movie edit pro 16 hd
    President:
  • 2,047 Answers
When encoding error comes up while rending the menu this is always as a result of either an improper installation of the driver or incomplete copying if the information to be redered.
Posted on Oct 14, 2010
  • 4,737 Answers
Please clarify with more details, it seems you are talking about some particular program, if so, please let me know the name of the program, operating system installed on your computer, etc...
Thanks and awaiting.
  • 13,433 Answers
Hello, could you be a little more spesific? what is this about?
  • Ekse Oct 14, 2010
    could you provide us with a bit of background information, what program are you using to burn and what are the errors exactly? I can't see them from here!
Magnetic encoding error
try to update firmware. check if driver can read the encoder from a used card.
Feb 19, 2014 | Zebra Office Equipment & Supplies
When i was replace the trailing cable my plotter writing the system error:86:01 how to solve
86:01 fatal error code resetable with power cycle- error is down to encoder not reading/ blockage on media path - encoder strip missing
1. clean and clear accuride rails ( long silver bar )
2. Clean or replace encoder strip
3. clean or replace encoder sensor
if all else fails contact Belmonte.co.uk for fast response
Jan 02, 2013 | HP DESIGNJET 800 42IN 1200DPI 96MB PAR USB...
White card keeping jamming in the middle everythine
Hi gigi_airambu,
The card jam, often caused by cards are jamming on or at the flipper table. Here are additional steps that you can apply to resolve this issue.
1. Verify that the Card Feed Roller on the Flipper table is not running backwards. (Note: Having an Encoder installed in the Printer will determine the direction that the Card Feed Roller on the Flipper Table will rotate.)
2. Open the Top Cover and remove any cards that are jammed inside the Printer.
3. Reset power on the Printer to clear any error messages that are on the LCD.
4. Press the MENU button on the LCD.
5. Press the Down Arrow button and select PRINTER SETUP.
6. Scroll through the menu and select ENCODER SETUP.
7. Ensure that the appropriate Encoders settings are set to Installed or None, based on the options that are installed in the Printer.
8. Press the Save button to save any changes that have been changed.
For additional information about your machine, please visit this link.
Hope it helps.
Thank you for using FixYa.
Apr 13, 2011 | Fargo DTC510 Card Printer
How do i set the clock for this cd player
You can get the manual on the link below. Page 6
http://a248.e.akamai.net/pix.crutchfield.com/manuals/500/500cda9851.pdf
1 Press MENU to select SETUP.
2 Press or > to select the CLOCK mode.
3 Turn the Rotary encoder to adjust the hours.
4 When the hour has been adjusted, press the
Rotary encoder.
5 Turn the Rotary encoder to adjust the minutes.
6 When the minute has been adjusted, press the
Rotary encoder.
7 When the setting has been completed, press
MENU to select RETURN.
The unit returns to normal mode.
Pressing and holding MENU for at least 2 seconds will
return to normal mode.
Feb 06, 2011 | Alpine CDA-9851 CD Player
Error code 5100
Error code 5100 indicates that Carriage Return (CR) error occurs. This error rise when carriage unit (the part that function as cartridge housing) does not move properly. Here are some possibilities of the problem:
  1. Carriage unit is faulty so that it cannot 'read' film timing **** strip (film encoder) properly
  2. Film encoder is dirty. Film encoder functions as a guide for carriage unit to move to the correct position it should be. Carriage unit 'read' the encoder by flashing a light from a LED. Dirty encoder sometimes make the light direction is deviated.
  3. Foreign material blocking carriage unit path. Please check inside the printer and remove it if any.
If carriage unit is faulty, you need bring the printer to the service center to get part replacement. For dirty film encoder,sometimes you can still clean it by using moistened cloth. I hope this will HELP you. Thanks.
Get printer troubleshooting only at: Printer Clinic
Jan 09, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I have a brother MFC - 490CW... There is a printing error that reads Unable to print 70
There are several issues that can cause an Unable to Print message. Try the following in succession until the printer works.
1) Get a lint free cloth and clean the encoder strip. Lift the scanner unit until it locks open and slide the print head to the right if it isn't there. The encoder strip is in front of the white vinyl band. There is a warning to not touch the encoder strip - this applies to touching it with your hands. Grab the encoder strip (both sides) with the cloth. Wipe vigorously from one end to the other and return at least three times (left to right then right to left each time).
2) Check for any foreign objects (paper or anything else) in the print head path. Use a flashlight to check the corners of the unit. Check under the print head (including that right hand side where it rests during the cleaning of the encoder strip). Move it to the left to check if you moved it to the right.
3) Open the back Jam Clear Cover and check for any jammed paper. Remove anything you find that doesn't belong. Close the Jam Clear Cover.
4) Now close the scanner unit. (If you do this before opening and closing the Jam Clear Cover, the error will not reset at all.) If the error is not cleared, clean the encoder strip again.
5) If the error continues to persist, cycle the power by unplugging the printer for at least two seconds. Then plug it back in.
6) When the error message is gone, run a test by printing the Help List. Press Menu and select Print Reports > Help List and then press Black Start.
7) If the report prints, you have fixed the printer. If it doesn't print and you have cycled the power, the unit needs service. If it is under warranty contact Brother. Before having the unit serviced transfer any faxes in memory to another fax machine if you can. To do this you need to have set a Station ID for this printer (before the error message). If you do have this set, press Menu and go to Service > Data Transfer > Fax Transfer. If you are prompted to enter a fax number, you have faxes in memory. Enter the fax number of the unit that can store the faxes and press Black Start. (If No Data appears, there are no stored faxes. Press Black Start to exit the menu.)
I hope this helps.
Oct 11, 2010 | Brother MFC 490cw Color Inkjet...
Any one help my brother display error 48, init unable 48, what are the things that i have to do?
There are several issues that pertain to this code, including a service update. If your printer is still under warranty – visit your local ASC, find one here, this issue is covered! First off, the Service Update, the encoder strip needs to be cleaned with a lint free cloth. The encoder strip is responsible for relaying the position of the print head to the main pcb. If the encoder strip gets dirty, many different problems can occur. The encoder strip is exposed, which allows grease, paper dust, finger prints, ink, etc. to get onto the encoder strip. (The white strip when you lift the scanner cover)
If the machine still errors, the encoder strip needs to be replaced – Part Number LS4467001
If the machine still errors, replace the carriage PCB assembly – Part Number LS6543001
If the machine still errors, replace the Printhead – Part Number LK3211001
If the machine still errors, replace the Main PCB assembly – Part Number LT0284011
THANK YOU FOR USING FIXYA! – DON’T FORGET TO RATE OUR SERVICE!
Jan 21, 2010 | Brother DCP 165C Compact Color Inkjet...
Code error 5800 has come up and printer will no longer work
Error 5B00 tells you that the ink absorber is full and needs changing. Canon makes this shut down printing so that ink doesn't leak on your furniture and blame them. You can change the absorbers but you need access to diagnostic functions to reset the count and clear the error code.
Jun 23, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Printing problem
No mag encoder means you're trying to send encoding data to the printer but the printer isn't configured with an encoder. A mag encoder writes data to the magnetic stripe you see on the back of some cards, like credit cards. Most likely, the printer doesn't have an encoder installed, but if it does, it may be turned off in the printer settings.
If you're sure that it does have an encoder, you can check/change the setting by going into the menu on the printer. Go to Menu -> Setup Printer -> Change Parameter -> Encoder Settings -> Mag. It will say none or installed. Note that this can be changed to one or the other whether or not the encoder is physically installed or not. This only turns it on if the encoder is there.
Hope this helps.
Jun 13, 2008 | Fargo DTC510 Card Printer
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
