Question about Kodak Office Equipment & Supplies
Broken parts at bottom of ESP 7 printer. Damage occured when paper fed back under main paper tray and was pulled out without removing metal framework to release it. Would need parts list to effeciently identify one of the parts. The other is part of the gear assemly which moves the paper trays: on the end of a transverse shaft beneath the main paper tray. one of two spring loaded "flags" to the shaft side of the gears is disengaged and the spring bent. The entire shaft and gear assembly may have to be replaced as a single part.
  • zayton Oct 16, 2010
    Should solve problem!
I was not able to locate a parts list and Kodak said they don't offer replacement parts but can "service" the printer if you send it in so I would suggest buying this used ESP 7 and then using the parts out of it to fix your printer. Click on the link below to view:
http://cgi.ebay.com/Kodak-ESP-7-All-In-One-InkJet-Printer-Parts-/130422844642?pt=COMP_Printers&hash=item1e5dceace2
http://selfservice.kodak.com/external/en/urg/urg_00976/GLB_en_urg_00976_manual_ATG/urg00976c10s14.html
Posted on Oct 14, 2010
On the laser printer HP 3600n it says it needs paper in tray 2. where is tray 2?
The printer comes with one main tray which is referred to as tray 2. The bypass tray is labelled as tray 1.
Jun 01, 2014 | HP Laserjet P3015X Printer
ESP5200printer,new,paper jam message
Hi slicknick58,
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Hope it helps.
Thank you for using FixYa.
Apr 20, 2011 | Kodak ESP 5 Printer
Only prints from the MP feeder and not through tray 1 anymore
if your printer only prints from the mp tray this is saying that it no longer recognizes tray one.
the first thing to check is the paper size fingers on the side of the tray. pull the paper tray all of the way out of the printer. there is a snap in plate on the left side of the tray. for letter size paper 2 fingers should be sticking out. if the fingers are present and not broken off. look into the opening that the tray was removed c
from on the left side half way back there will be 4 metal tabs make sure these are even and straight. if both of these are not damaged.remove the logic pack (metal cage behind the left side cover. loosen the 6 screws and remove the out cover. on the inside of this box remove the screw located upper right hand corner, remove the screw in the lower right corner, and the screw from the upper left corner. now one more screw on the back of this box lower left corner remove this screww then pull up on the box and set it aside. at this point you will see the main motor drive in the middle of this side dierictly under the motor you will see a small pcb that is attached with 2 screws ramove these and rfeplace this board it is the paper size select pcb and it needs replaced
Jan 06, 2011 | Lexmark Optra T610 Laser Printer
Tray is not feeding paper properly. Its making a weird clicking noise when paper is being fed. Paper gets jammed on most attempts.
Remove the paper tray and try to see some paper jammed somewhere around it. When pulling off paper jam. Just pull gently and slowly so that you can remove all and nothing left behind and doesn't damage the part when removing unwanted paper jam. Maybe it is the cartridge just repalce new cartridge if not the fuser drum maybe damage.
Dec 08, 2010 | Brother MFC-7820N Printer
Paper jam
You are receiving this error message because there is a paper jam or the top (photo) tray is not securely in position and the printer cannot initialize. This error message can appear for an ESP 7, ESP 9, ESP 7250, or ESP 9250 all-in-one printer.
To resolve a paper jam, we have an easy Step-by-Step Solutions and Repair tool. Within the tool, select All-in-one printer, then Paper jam.
When you clear the paper jam:
  1. Make sure you open the paper output tray and inspect the top tray for photo paper that could be jammed inside or that remains in the nip at the entrance.
  2. Pull out the bottom paper tray and clear any paper jams.
  3. Remove the duplexer from the back of the printer and clear any paper jam.
NOTE: Curled photo paper could induce a paper jam. To prevent curling:
  • Store un-printed paper in a tightly closed plastic bag or in its original packaging.
  • Store sealed packages of paper flat, and not on
  • When you are ready to print, take only the paper intend to use immediately.
To remove curl in photo paper:
  1. Place the paper in a plastic bag or in its original packaging.
  2. Gently bend the paper in the opposite direction of the curl, then insert it into a tube-a paper towel tube works well.
    NOTE: The tube should be larger than 1.5 in. (4 cm) in diameter.
  3. After a few minutes, remove the paper from the tube.
  4. Remove the paper from the plastic bag or packaging.
  5. Verify that the curl has been removed from the paper. Repeat the steps above if necessary.
If the top paper tray is not securely in position and the printer cannot initialize (you may hear a grinding noise, and the top paper tray will not open), contact Kodak.
Nov 02, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper from Tray doesn't load.
put paper in the upper slot (known as the MP), pull all paper from lower tray, send document to print and see if it prints ok - if it does, the problem may be with the lower print drawer - there is a spring under metal pad that lifts paper so it's grabbed by the printer paper transport. the spring may have broken or become dislodged so separation pad (the metal plate holding paper up) remains down - the transport "thinks" there is no paper
Jul 08, 2010 | Brother MFC-8460N Laser Printer
Paper jamming in printer. Pulling one side before the other causing it to jam... Brand new, bought Sunday
Answer:
Fixing a printer paper jam
When working with any printer it's inevitable that you'll encounter a paper jam. Below are the steps you'll want to follow when this occurs.
1.Turn off the printer.
2.Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
3.Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
4.Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
5.Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and we suggest contacting the printer manufacturer for additional assistance and/or repair.
* To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
Preventing a printer paper jam
As mentioned earlier it is inevitable that you will encounter at least one paper jam during the life of your printer. However, if you're encountering frequent paper jams following the below steps can help prevent paper jams from occurring.
•If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams reduce the amount of paper you place in the tray each time it is filled.
•Make sure you or the tray feeding the paper into the printer is aligned properly and/or the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
•Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what type of paper you should use with your printer your printer documentation will list the types of paper compatible with your printer.
•Do not mix the types of paper you're feeding into the printer at one time. If you need to change the type of paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
•Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
Jun 24, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
HP Deskjet3845
To remove the jammed sheet of paper :
1. Open the upper front door.
2. Grasping the print cartridge by the hand grip, pull it towards you and slightly up to lift it out of the holder.
3. Then pull the cartridge straight out towards you.
4. Locate the feed roller release lever and gently push it back to release the pressure on the paper.
5. Pull the paper out. CAUTION! The paper may be covered with unfused toner, which can stain garments.
6. If you see no paper jammed under the cartridge, remove paper tray 1. The paper may not have fed all of the way into the printer.
7. Reinstall the paper tray and the toner cartridge.
8. Close the upper front door.
Mar 11, 2009 | HP Deskjet 3845 InkJet Printer
Paper jam on Brother HL-1270N
Title:
How do I clear paper jams?
Description:
If a paper jam occurs, the Paper LED will flash as shown below.
c_panel_cover_open.gif Caution
    After you have used the printer, some parts inside the printer are extremely hot. When you open the front cover or face-up output tray of the printer, never touch the shaded parts shown below.
  1. Remove the paper tray from the printer.
  1. Pull the jammed paper up and out of the printer.
  1. Open the front cover.
  1. Pull out the drum unit and toner cartridge assembly slowly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
c_hl20_03221.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the back cover.
  1. Pull the tab toward you to open the rear chute cover.
  1. Pull the jammed paper out of the fuser unit. If the jammed paper cannot be pulled out easily, push down the tab with one hand as you gently pull the paper out with other.
  1. Close the back cover.
  1. Push the lock lever down and take the toner cartridge out of the drum unit. Take out the jammed paper if there is any inside the drum unit.
  1. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
c_hl20_025121.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit and toner cartridge assembly back in the printer.
  1. Put the paper tray firmly back in the printer.
  1. Close the front cover.
    Make sure that the Paper LED is now off and the printer is ready.
Feb 23, 2009 | Brother HL-2040 Laser Printer
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
214 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
