Question about Dryers
The clothes are picking up brown streaks especially noticeable on light clothes. It can be washed out but then it has to be dried again. The perforated screen at the back of the drum appears to have it's finish worn off. Can that be the source of the problem? If so can it be remedied, painted or covered? Thank you for your time and effort. Pam Troje
  • 66 Answers
SOURCE: clothes dryer brown marks problem
if that mark is comming from the dryer .the drum has a rust. and you cant paint it or the seal of the drum is bad that seal is around the drum.
Posted on Feb 18, 2008
SOURCE: brown streaks on clothes
Are the streaks on smaller pieces of clothing (socks, etc.)? If so, the clothing item might be getting caught inside the rubber gasket around the door, and getting the streak from there. Try cleaning inside the fold of the rubber gasket very well, and often and see if it keeps happening.
-Ellie
Posted on Feb 12, 2009
  • 530 Answers
SOURCE: Brown streaks on white clothing in front loading washing machine
more than likly it is coming from the dryer. get a paper towel or a towel and run it between the inside of the drum and the front where they come together. stick it through the slot and run around the drum. do the front then do the back see if you see the same streaks. and let me know thanks
Posted on Jun 02, 2009
venexcsd
  • 1185 Answers
SOURCE: Dirty steaks on clothes at end of wash cycle.
Make up a couple of liters of a strong solution of hot water and Soda Crystals, pour that mix into the machine without any laundry in it and do couple of very hot washes
Change your soap powder to one of the old fashioned ones for a month or so and see how you get on.
Cold washing tends to leave body fats and other greases inside the machinea s there is little to break them down in "Modern" powders
Posted on Jun 19, 2009
kel1guy2002
  • 3740 Answers
SOURCE: brown streaks on flat, thin items like pillow
Hi Witt and welcome to FixYa. I am Kelly.
The brown streaks are most likely rust. There are drum seal replacement kits you can buy to start anew. The streak source need to be identified. If the drum is rusted your going to have to sand and paint it with an enamel appliance paint. However.... if it is the back of the cabinet that is the source of the rust in the felt seal rub area if you do not allow the paint to dry well before reassembly it will end up flaking off on your clothes.
Here is the drum seal with adhesive:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Rear-drum-felt-seal-with-adhesive--red-thread--item-number-AP3094149.aspx
Once you in there I would replace the belt and inspect the drum rollers.
Belt:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Whirlpool-Dryer-Belt-item-number-AP2946843.aspx
Rollers:
http://www.appliancepartspros.com/part_details.aspx?part_id=3098345
The belt I would replace... Just make sure if you attempt repair that you NOTE the routing of the dryer belt through the idle pulley to the motor pulley.
If the rollers rotate freely with no teetering froward or aft and do not have any flat spots you do not have to replace them.
Appliance paint by color needed:
http://www.appliancepartspros.com/Appliance-Parts/?keyword=Appliance+paint
Thanks for using FixYa
Kelly
Posted on Mar 14, 2010
Testimonial: "Thanks Kelly. I really appreciate your help."
Lg washer leaving black greasy marks on clothes
This is usually to do with fabric softener. Dilute it with more water. The fabric softener makes clots, and these make the marks on your clothing.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM2077CW XL Front Load Stackable Washer...
Same thing
Liquid fabric softners usually cause spots and/or marks on light colored clothing . If you rewash the clothing and the marks dissapear , then try using dryer sheets instead . However , if you have an older dryer , then clothing could be getting rubbed between the rear drum seal and panel , but that would cause streaks but no spotting .
Jul 26, 2009 | Washing Machines
Whirlpool Duet Washer/Dryer get brown streaks on clothing
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Brown streaks on clothes
do you have the matching dryer on the earlier models they didn't use a seal on the drum and once the paint rubbed off they left brown rusty looking marks on the clothes
Jun 29, 2009 | Frigidaire ATF6000ES Front Load Washer
Jun 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Brown streak on clothes
It could be from scorching due to getting too hot. This may be the start of a problem for you.
It is best to judge how long clothes need drying for before drying them. If they are left too long, sometimes the heat builds up.
Try a smaller load in there, and if you can reduce the temperature any then do.
Often it's just overloading is the issue.
Hope this is a solution for you, If so, Please rate as Fixya! Thanks.
Jun 18, 2008 | Kenmore Elite HE4 Electric Dryer
-Ellie
Jan 30, 2008 | Frigidaire GLTF1670A Front Load Washer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
