I have a 106cm AWA plasma tv which is about 6 years old. Turned it on this morning, and it made a popping noise. Screen is now fuzzy and distorted
  • 1 more comment
  • donna_olney Oct 14, 2010
    I don't have electrical experience, so am loathe to open back. If this is in fact the problem, is it costly to get it fixed ?
    not sure if you got my previous response.
    I was asking if it would be expensive to get someone to fix, as I don't have electrical experience myself.
    cheers
  • donna_olney Oct 15, 2010
    due to the age of the television, do you think it is worth getting fixed ? When they get to a certain age, is there other things that are likely to go wrong ? It would be frustrating to fix it and then have another component mess up.
    cheers
  • 11,800 Answers
Popping noise = an electrolytic capacitor has literally exploded - something to be expected on a tv of that age. Shut down the tv immediately - allowing the tv to work in this condition will only make the situation worse, by overstressing other components. Then you must open the tv, locate the failed capacitor and replace it.
To prevent this from happening again , as a precautionary measure, you should replace all the other capacitors, their condition is surely not far from the failed one.
Posted on Oct 15, 2010
  • 12,061 Answers
Hmmm poping noises in my workshop are NEVER good... one thing positive though, usually the "Blown" part is easy to find, the CAUSE as to why it was destroyed, is another. usually again though, it will be something to do with overcurrent, and or overvoltage, of course the first place to check, is always the Power Supply Unit, and then the Higher Voltage sections in the screen drive circuits.
So if you wish to DIY, or are simply interested to know whats happened, see if you can locate the "Popped" component, and identify it.. then you will have to ascertain as to WHY this component "Blew" in the first place as components seldom spontaneously fail, unless they are in the High Power and Power supply sections. Low voltage components should almost NEVER spontaneously fail.
Also you need to obtain a service manual for your exact make and model set. This then will show you how to troubleshoot, it will have the schematics, and also the parts numbers and values too, essential to service a set like this.
However if you do not wish to DIY then please contact a local or head office from AWA and ask them for a referral to an authorised service center, when they attend to the unit, ask them for a 'Quote" before proceeding with any repair. This way you can make an informed decision as to repair or replace as often seemingly simple problems can escalate into a major expensive job.
Posted on Oct 14, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The pop noise is caused by a blown/burned capacitor. From what you have described it seems to be an issue with Y board however, Z and the logic board should also be checked. These boards are located on the right side of the unit and to check them you'll have to open the back of the unit. Once you have opened the back also check for any blown/bulged capacitors. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when in off position.Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Oct 14, 2010
    The cost will be around $200-$300 depending on the parts that are replaced.
Instruction Manual For AWA 106cm HD LCD TV Model CP42PDH10S
what sound system can i put in to my 106 cm awa lcd tv
Feb 05, 2011 | Televison & Video
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
LG plasma TV turned off, after the picture very light
I think you have a defective power board. the pop sound in coming from the board and giving you a low output voltage. do it yourself price about two hundred for parts.
Feb 18, 2010 | LG 42PC5D Television
Black haze covering picture after "pop" noise
That's a very old model to be only 1 year old?
It needs a Z-Sustain PCB anyway.
Thanks.
Sep 08, 2009 | LG DU-50PZ60 50 in. Plasma Television
How do you connect AWA plasma TV to AWA surround sound
Hi Map33_bm
It appears that your TV set is 2 channel stereo, so as there is no surround signal coded into the TV audio channels, thesurround sound does not process it.
I've posted a PDF in 'manuals' which you can check out.
Did this info help at all?
Regards, Clive.
Oct 28, 2017 | Televison & Video
Sony plasma picture is blurry and makes a popping noise
Hello MDay02,
Your problem maybe your X board which is the same as PCB X sustain. Changing the fuse in this case may NOT solved your problem. If you are handy, you may be able to change the board yourself. We have most Sony X board in stock. If you purchase the board from us, we will walk you through the installation process for FREE over the phone.
Mar 17, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
Colour distorting
Sounds to me like your digital board is bad.
May 13, 2007 | JVC GD-V4211PCE 42 in. Plasma Television
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
