Question about 1600XP Security/Remote Start System
Hey all! I have absolutely no fuel pressure registering at the fuel track on an 85 Firebird, 2.8 ltr automatic with an aftermarket Python 1600xp alarm system. This may be an out of this world question but I started thinking about an alarm system I had installed in 2004, it is a python 1600xp system and the only item I never had activated on it was the power window feature (obviously because I do not have power windows) I was thinking about when the car died and would not start. When it quit running (my wife was driving it), I remember going outside and I noticed that the car kept trying to start automatically (it has remote start) which was very odd seeing how she had put the key in the ignition, placed it in gear and started driving. I went out to the car tonight and checked on resetting the valet function, when I did that it seemed as though the car wanted to start but still wouldn't. I also noticed tonight that during the entire time that I tried to start the car I heard the fuel pump priming. I had not heard it trying to prime while I have turned the key until I reset the valet feature. Could there be an issue with the alarm system keeping the car from starting? If so, how would I correct that? Thank you for your expertise and patience!
blueextc3221
  • 15935 Answers
SOURCE: i have a python sst car alarm
usually a combination of 2 buttons so the car doesnt start accidentally.
Depending on the number of output channels - the installer could have installed on any of the channels and that would dictate which buttons to press.
if it is not set on the AUX (output 2) button, then try...
  1. Lock + unlock at the same time - output 3
  2. * + AUX at the same time - output 4
  3. Lock + Aux at the same time - output 5
  4. Lock + * at the same time - output 6
You have not given the model # of the unit - so these are viper's STANDARD remote controm configurations.
CLICK HERE to enter your correct model # and Download your instruction manual.
Hope this helps.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Posted on Mar 01, 2009
  • 55 Answers
SOURCE: i can't find a valet switch for my python 460hp?
you can find the "brain" by tracing the wire from the LED blinking light to the brain than look for a grey and black wire which is the valet switch. Don't look for a toggle switch either, your looking for a little black button not a silver toggle but a little black button. Depending what vehicle you have also matters, for instance if you have a GM truck look in the side dash fuse panel or look BEHIND the hood latch handle. It's a ***** to find sometime but essential that you know both where it is and what it does and how it works.
Posted on Aug 08, 2009
sir fixalot
  • 146 Answers
SOURCE: My Python 1400XP remote start is killing my
Installation Guide: http://www.abt.com/images/products/BDP%20images/N562P_6-03.pdf
Owners Guide: http://www.directeddealers.com/manuals/og/python/G562P_07-05.pdf
Posted on Oct 18, 2009
Testimonial: "Been looking all over the internet for help with wiring for my remote start. Finally got the answers. Thank you so very much!!!"
str8gooods
  • 13 Answers
SOURCE: one of my remotes will no longer operate my Python
This is a common problem on these and the equivalent viper models. We sent all our units back to viper and they have now re-released the units. We had installed these units into customers vehicles and about 50% had the same issue your having. Even after they were reprogrammed, many returned with the problem again. My advice is to contact python and have the unit replaced.
Posted on Mar 08, 2010
SOURCE: I need to program a new remote for a python 460HP.
i bought a remote on ebay and im try to program it its a python 474p
Posted on Aug 21, 2011
Where is maf in 1987 olds. calais 2.5 ltr engine
Jimmy, 1987 Olds. call it a MAP. Standing in front of car with hood up, the map sensor is beside breather(below) on the left, has electrical plug and a few rubber (vacuum) lines running into it.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Test the Manifold Absolute Pressure MAP Sensor GM 2 2L
1987 oldsmobile 2 5 ltr engine Manifold Absolute Pressure sensor location...
Apr 02, 2016 | Zynga Mafia Wars Game
1995 Firebird 3.4 LTR, Automatic. Car had a coolant smell and was dying at stop signs.
if the coolant level is going down you may have an intake or head gasket leaking coolant into the cylinders pressure test the coolant system
Mar 16, 2014 | Pontiac Firebird Cars & Trucks
The vehicle starts but runs only for about 1 minute, then it goes off
you need to re-program your factory alarm bypass module. if you haven't used on then you will need to find out which one you need for the vehicle and install it. Check the Viper/DEI Website for details.
If your module is in, check the Can Hi and Low connections to be sure they are to the correct wires.
Jan 06, 2011 | 1600XP Security/Remote Start System
Python 1600 XP Remote Starter my car starts at 1 pm daily automatically. How do I remove this timer on this remote starter
You have the 24 hr timer on and you just have to press the lock and remote start buttons at the same time.
Dec 23, 2010 | 1600XP Security/Remote Start System
I started my 85 firebird I just changed the fuel filter and pump it started and we went around the block two times then I parked it for a few min then I tried starting it again but it boged out what do I...
I would ck for fuel pressure at carb, if it has pressure then i would suspect the needle and seat are leaking causing to flood with fuel when trying to start up., if the carb is the issue then repl needle and seat in carb.
Aug 11, 2010 | 1985 Pontiac Firebird
How do I re-program the remote start system
what kind of remote start system are U installing?
Dec 14, 2009 | 1600XP Security/Remote Start System
One of the bikes are broken want to buy just bikes for race track
well.okay go to google and look for best bikes for race tracks
Jul 03, 2009 | Chicco Ducati R/C Motorcycle Red
1600XP Security/Remote Start System Logo
55 people viewed this question
Top Python Vehicle Parts & Accessories Experts
Kevin Daniels
richie46
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
