Question about Acer AL1916W 19" LCD Monitor
Acer AL1916W flickers, all connections are tight, how do I resolve this problem
  • 11,361 Answers
It is flickering may be caused by unstable DC power due to bad DC filter caps, that will be he first palce to check.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 14, 2010
We have had this monitor for about a year and it just started flickering with dark colours. How can we fix it?
If it is less than one year, then contact ACER, and exercise the "warranty" to get it repaired/replaced at _minimal_ cost to you.
Mar 06, 2011 | Acer AL1916W 19" LCD Monitor
My acer AL1916W displaying vertical lines and images or flickering any help
ITS POWER SECTION'S CAPACITOR HAD BECOME WEAK MANAGE TO REPLACE IT.
Feb 04, 2011 | Acer AL1916W 19" LCD Monitor
Acer 1916W flickers which started 2 days ago. Can this be corrected?
Borrow replacement monitor and if good, not usually untill a part is replaced.
If the same, then fault is in the PC.
May 10, 2010 | Acer AL1916W 19" LCD Monitor
Flickering screen
take it back its a known issue and acer isnt telling anyone
May 08, 2010 | Acer AL1916W 19" LCD Monitor
Monitor color
all button found at front, try check also if vga cable connector properly tight, lost connection can also cause color discrepancy.
Mar 25, 2010 | Acer AL1916W 19" LCD Monitor
Acer AL1916W Widescreen flickers
check the data cables.also check if there are power fluctuations. if you do have power fluctuations, try buying a power stabilizer or no-break. if you're under warranty coverage, ask for a replacement (this is the most simple way), if not do what i told you before. the data cables may be malfunctioning. also check your video board. try to plug your monitor into another computer. if the problem persists with a different machine, then the cause is definitively in the monitor.
Feb 06, 2010 | Acer AL1916W 19" LCD Monitor
Acer X193HQ Screen Flickering
this means their is some conflicts between the graphics card drivers or the drivers are not installed properly. so re-install the graphics card drivers.
Oct 23, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor '' no power''
I'm having the same problem and it turns out to be the main board.This Service guide is for Version 1.0 but turned out to be helpful
http://www.abcelectronique.com/forum/attachment.php?attachmentid=12292
Feb 28, 2008 | Acer AL1916W 19" LCD Monitor
Back ground screen flickering
If it flicker continually that may well be either the video card (hopefully not part of the motherboard) or the monitor. Your best bet is to tt on someone else's machine. If it does not flicker then you probably have a bad (or soon to be very bad) video card. If, your video card is built into your machine, don't give up....you can buy a video card and install it....they are not expensive if you are not a big time gamer. Price ranges are anywhere from $8-20 if you are a normal PC user. Pricewatch.com can give you some insight. You will need to know what type of slot you have available....presumably AGP (but PCI, if you have an open slot on the motherboard, will also work....AGP is faster.)
Jan 20, 2008 | Acer AL1916W 19" LCD Monitor
Flickers
how about more higher rate for that then confirm the cable or any unusual soudn from the monitor?
Oct 25, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
250 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
