Question about HP DesignJet 5000 Printer
Installed new Hard drive on my HP Designjet 5000, getting BOOT ERROR. From what I can gather there is an operating firmware that needs to be on the disk. Unsure where to go from here. Any advice?
mellomania
  • 121 Answers
SOURCE: HP Compaq nc6320 Boot Disk
in case you can get a non boot disk , u can install it by using a start up floppy disk for win9x
Posted on Nov 15, 2007
SOURCE: HP product assistant
I have problem with my hp laptop, when ever i restart the system it is asking insert the hp product assistant disc and then click ok to install, i dont have any other disc other than the one which comes along with printer. please kindly let me how to solve this........
thanks
kishore
Posted on Sep 20, 2008
  • 3 Answers
SOURCE: HP DesignJet 450c driver for windows vista
THIS SOLUTION IM ABOUT TO TELL YOU IS IN MY EXPERIENCE THE EASIEST ONE JUST DOWNLOAD THE WINDOWS XP DRIVER FOR THE HP DESIGNJET 450C PRINTER AND INSTALL IT INTO THE WINDOWS PRINTER PLATTFORM, YOU MAY SEE SOME ANOUNCEMENTS FROM YOUR COMPUTER TELLING YOU THAT THE PROGRAM YOUR TRYING TO INSTALL MAY NOT BE COMPATIBLE "DONT LISTEN TO THEM" JUST CONTINUE YOUR INSTALLATION AND PRESTO YOUR DESIGNJET PRINTER WILL WORK PERFECTLY
Posted on Nov 26, 2008
ziraffa
  • 827 Answers
SOURCE: change boot sequence for HP L2000
You need to enter BIOS at startup. The correct key to press will be displayed at the bottom of the black screen when you bootup. Usually, F10, F8 or F11 or Del. Mash them all on booting up.
Now navigate the Bios settings with the arrow buttons and select cdrom as 1st boot device with the enter button. Then Save and Exit.
Fixya!
Chris (ziraffa)
Posted on Jan 10, 2009
SOURCE: New HDD inserted into Pavilion ZD7000 - will not boot from XP CD
Try your old HDD in it and see if that works. If it does work then nothing is damaged except your DVD drive/Controller. Try putting the new HDD in another computer, installing windows then putting it back in the HP. If all else fails then flash the bios with an updated image and see if that rectifies the problem.
Posted on Feb 01, 2009
The printer does not have a hard drive. Will it work when I plug a new hard drive into the formatter and turn the printer on? Can the driver or firmware be loaded on a blank hard drive?
The answer is.... NO. The hard drive must have an Operating System on it to recognize the printer's firmware first to identify it and then software to make it work for you.
Apr 10, 2015 | HP q6659a - Designjet Z3100 44-in Photo...
Installing a new blank hard drive in a DesignJet
The hard drive is the formatter in the T610.
HP has a special operating system software loaded on the hard drive, so you can't just format a blank one and install it.
The whole formatter assembly will need to be replaced.
Mar 15, 2014 | HP Designjet T610 InkJet Printer
Installing a new blank hard drive in a DesignJet T1100,T610
The T610 hard drive is the formatter and has a special operating system software installed on if from HP. You can't format a hard drive and install it...so the whole formatter assembly needs to be replaced when the hard drive goes bad...
Hp designjet t1100 blank hard drive installation
Unfortunately I had a similar issue with an HP A0 printer. The Hp 'Engineer' could not fix it. The hard drive had failed and there is a complete new hard drive with software loaded available but only through Hp.
Feb 27, 2014 | HP Designjet T1100ps Printer
Red light comes on nothing ells
The Designjet 1050C Plus does not need the hard disk drive to boot. When only the red light comes on, the firmware ROM is probably missing. Open the small panel on the back of the plotter to access the memory and ROM slots. If the FW ROM and memory are missing, you will need to buy them to make the plotter boot. They can be purchased at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Oct 01, 2013 | HP DesignJet 1050c plus InkJet Printer
How to install New firm ware in new hard disk printer hp designjet T1100Ps
When you installed the new hard drive, was it purchased from HP as the hard drive for the T1100ps, or did you install a generic hard drive like for a laptop?
HP uses a special formatting on their hard drive with its own operating system with the latest firmware already installed (not windows o/s), so just installing new firmware will not work...the plotter must be on and in a ready state to receive the firmware update.
Sep 24, 2013 | HP Designjet T1100ps Printer
I have problem with plotter hp designjet 500 ps, error 79 : 04, error with blue ink...
A 79 error most often indicates that you have a problem with the firmware for the printer. Go here and download the firmware update that corresponds to the operating system that you have installed on the computer. Follow the directions that download with the file and you should be printing again.
Aug 23, 2011 | HP DesignJet 500ps (42 in.) InkJet Printer
HP Designjet 1050C Pluss - Error Code Question
Hi there only can try.
This is a firmware error, meaning your f/w simm is probably bad. You can try reseating the simm. It is behind the small panel in the back of the plotter, that is held on by 4 torq screws. Reseat all the simms that are present and see if that helps. If not, you probably need to purchase a new firmware simm.
Also try looking at
pulling the JetDirect card and then re booting it
Feb 10, 2010 | HP DesignJet 1050c InkJet Printer
HP DesignJet 5000 Printer Logo
81 people viewed this question
Seeker5211
Seeker5211
