Question about Samsung ML-2551N Laser Printer
How do you fix Samsung ML-2551N Laser Printer Internal Error TSKroot 1115
Interal error tsknic2 0091
Posted on Dec 21, 2012
SOURCE: Paper Jam when using duplex function - Samsung ML-2551N
Check underneath printer.
Posted on Nov 10, 2009
APremkumar
  • 564 Answers
SOURCE: printer has ''internal error''
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on Mar 12, 2009
  • 15 Answers
SOURCE: Driver Samsung Laser Printer ML-1210
Need driver for Samsung Laser Printer ML-1210
Posted on Sep 23, 2008
alfi819
  • 65 Answers
SOURCE: samsung printer ml-2551 internal error
Make a service request here or contact Samsung here
Posted on Mar 27, 2009
SOURCE: internal error mdlcrum 0094 in samsung printer ml-2550
ki desgraça eu n consigo axar o real defeito dessa impressora....pohaaa
Posted on Mar 08, 2010
Samsung ml 2551 Engine hsync error
Dear The problem is with LSU (laser scanning unit) unit. If you are experience open the lsu clean all optical path and test. This may operate .Replace the LSU unit.Thanks.
Oct 13, 2014 | Samsung ML-2551N Laser Printer
Samsung printer ml-2551 internal error
Mar 27, 2009 | Samsung ML-2551N Laser Printer
Printer has ''internal error''
PREM
Mar 12, 2009 | Samsung ML 2151N Laser Printer
I have printer ml-2551n whent I turn on no display work ?and no connectivity
Replace all electrolytic capacitors in power supply section on mainboard. caused by poor quality lower voltage lower temp caps being used in powersupply and being put right beside a heatsink (Der are we clever or what) . Problem will reoccur every 2 to 3 years if 105oC caps are not used. If mainboard is replaced with new mainboard problem will reoccur within same timeframe. Fix old mainboard using higher voltage and higher temp caps and problem will be gone for good.
Dec 29, 2008 | Samsung ML-2551N Laser Printer
Samsung ml-2551N - Keeps flashing and a noise
hi!!!!
ok try to remove the drum first
and put it back properly!!!!
Sep 18, 2008 | Samsung ML-2551N Laser Printer
Constant paper jam
Replace all electrolytic capacitors in power supply section on mainboard. caused by poor quality lower voltage caps being used in powersupply. Problem will reoccur every 2 to 3 years if 105oC caps are not used. If mainboard is replaced with new mainboard problem will reoccur within same timeframe. Fix old mainboard using higher voltage and higher temp caps and problem will be gone for good.
Apr 04, 2008 | Samsung ML-2551N Laser Printer
Printer installation
If you can not load from the CD try going to the this website and download the drivers to your C: Drive. This should work.
http://www.dirfile.com/lexmark_printer_optra_color_1200.htm
Feb 18, 2008 | Samsung ML-2551N Laser Printer
Ml 2551n printer
contact problem between toner & printer. clean contact point in printer to solve this problem
Jan 15, 2008 | Samsung ML-2551N Laser Printer
Maintenance list + common problems
The most common problems come from uneducated users. Please make sure you read and understand the user's manual, it provides even troubleshooting guides. As with all laser printers, you will eventually need to replace the following: 1. On paper trays and bypass: pickup rollers and separation pads. 2. On printer: fuser unit and transfer roller.
May 18, 2007 | Samsung ML-2551N Laser Printer
Samsung ML-2551N Laser Printer Logo
1,453 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
