Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
My refrigerator is a bottom freezer 16.5 a month ago the freezer defrosted on its own but the refer stayed cold neither of the units are cooling , the fan is working and there is a metallic buzz every couple of minutes
    President:
  • 1,891 Answers
The buzz you hear is the compressor trying to start . i would think that the start device ( relay located on the side of compressor has failed and will not start it . this is a common service . it will have to be replaced . . it has been failing or not always starting like it should for several week and it has now give up.. its not a tuff repair but should be done by a tech that can do it properly .. mm also make sure the coil is clean and fan is working . mm
Posted on Oct 14, 2010
Fridge does not stay cold but the freezer works
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 19, 2010 | Sub-Zero 650 / O Bottom Freezer...
As of six months ago, my GE fridge starting leaking from where the air blows into the refrigerator part of the machine. I was getting a 16 oz cup of water out of it every 36 hours or so. Now the freezer...
If this is a top freezer model,remove the bottom and back freezer panels. You will find the defrost drain line frozen over.
It must be defrosted manually. A hair dryer will help melt the ice.
May 25, 2010 | GE Refrigerators
The refrigerator and the freezer is not working properly, the food is thawing in the freezer and the refrigerator is not staying cold. The compessor is running and blowing cool air. It just started...
Possible defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air.Since you've already replaced the motherboard Checkdefrost heater, defrost thermostat
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Fridge not staying cool, freezer still freezing
Try defrosting freezer, sometimes when the defrost thermostat fails it causes ice too build up behind the walls of the freezer then it restricts the air flow to the refer side. If it works after defrosting then you probably need to get a new defrost thermostat.
Mar 14, 2009 | Maytag MBB1956GES Bottom Freezer...
Freezer cold, but Fridge only a little cool
Sounds like you have a defrost problem either the Timer /Heater or Bi-metal stat is bad. you can unthaw and the unit will work fine for about a week until it frosts up again Where was this screw they said was loose?? have them check the defrost system.
Aug 28, 2008 | Haier HRF10 Top Freezer Refrigerator
Refrigerator warm, freezer cold
Totally Unreasonable if you don't mind me saying so. The person who told you that story was thinking of an absorption unit more than likely.
Your proble is related to the defrost system of your refrigerator. There is a timer that automatically starts the defrost. It energizes the heaters that defrost the cooling coil. After the coil reaches a preset temperature a defrost terminator turns the heater off for the remaining time on the timer cycle. You could have a bad timer (stalled) which would not start the defrost. Locate the timer and turn the clutch head screw clockwise very SLOWLY until you hear one audible click. The defrost should take place and will be indicated by water in the drain pan under the refrigerator. If after 25 minutes it does not restart in the cooling mode turn the screw once again to the second click and replace the timer.
If the refrigerator restarts after 18-22 minutes and defrost does not take place your problem is in the heater circuit. Open heater or thermostat (termination switch)
Jul 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
50 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
