Question about Zenith A27A11D 27" TV
I can not set video on the tv when i change from channel 00 there is no video
  • 1,557 Answers
Does it have an av button
Posted on Oct 14, 2010
How can I go to av mode without remote control in samsung hitron tv
Yes, you change your channel to '00' or go up to '101' and then press up button on tv then it will automatically comes to '00'
Nov 08, 2012 | Samsung Televison & Video
Can't change input to play Xbox without clicker. With tv clicker I could access channel 00, which allowed me to play xbox. now the clicker is broke and I can't access channel 00. can i do this through...
The only way is with the remote. Try to find a GE or RCA universal remote. These remotes are designed around GE and RCA tv's and generally don't have to be programmed. (GE and RCA are both THOMSON made sets). Thanks
Oct 13, 2009 | GE 31GT660 TV
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
RCA Colortrak Stereo Monitor won't play DVD/Nintendo
The way you describe having your TV/DVD connected you wont see the picture in the regular channel line-up.
You will have to tell the TV to to switch to the video input. This is usually done by navigating the menu to the "input" and selecting video 1, video 2 etc
Failing that try changing to channel 00 ( just type 00 in remote)
Some sets will allow you to type in 02 and then hit the channel down button on the remote.
If you have the user manual it will give you the exact steps you need to take.
Mar 13, 2009 | RCA F26317 TV
RCA model F27252GY TV has no Video button or AUX channel for DVD
try putting the tv on channel 00, that is where this tv apparently shows the input from at least one on the video channels.
Nancy
Feb 11, 2009 | RCA F27252GY 27" TV
RCA tv with FiOs
my fiance fixed it. he has this really expensive remote that he programmed via a USB port and some fancy fingerwork that I can't even begin to explain :D and I was able to change the channel back to 00
Jan 20, 2009 | Televison & Video
Timer programming problem
Check to see that you have not changed the default choice for input on power up of the box the "timeshift default device". If you have it set to front or rear CVBS or S-video input, it may ignore the channel choice you make when setting up the recording.
tom
Feb 13, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
Cannot get DVD to Play on TV
Try the old RCA/GE channels of 90/91 or 92 to get to the inputs. Or try entering channel 00. Let me know if that works.
Feb 21, 2007 | RCA F32649 32" TV
Cannot set Cable Default Channel
I believe you are getting mixed up between channels and programs. Normally program 00 is used for VHS as it has slightly different parameters for colour and brightness. If the TV has about 39 or more programs which can be programmed in from the on screen menu, try using program 20 for the video and 30 for the cable. For this to work you must do the on screen frequency scanning from channels 22 to 69 (UK) and select VCR, CATV, VHF, UHF, etc. I have used program 00 and 20 for two VHS recorders, working on channel 33 and 35 for example, but you must tune them to 33 and 35 on the `Tune' screwdriver hole by the aerial input sockets of the recorders. I expect if your cable unit plugs into your aerial socket of the TV that it has an adjustment for what channel it is on. The TV on screen menu may be different in some countries, so it would help if I knew where you are.
Oct 21, 2006 | RCA F32632SB 32" TV
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
