Question about Dayton Audio Dayton 4YG31 Horizontal Band Saw
Dear sir I am looking at Buying A Dayton 4YG31 Horizontal Band Saw. I am trying to find the blades to fit this unit and the part numbers. Would you also be able to send me a Mauuel that give a break down off this unit. I would like to be able to see how the blade is changed out. Thank you Thomas
  • 4 Answers
I found a website that has a manual for such band saw. I think it was... bandsawmanual.com. Hope this helps
Posted on Mar 13, 2012
What is the length of the blade?
If you are replacing the blade just use a tape measure around the two wheels. This will give you the measurement you need. GOOD LUCK FRIEND.
Apr 14, 2015 | Dayton Audio Dayton 4YG31 Horizontal Band...
Blade length ?
Please refer to this website Horizontal Band Saw Wet 1 1 2 HP
If you'd like to purchase blades , check sawblade.com
The blade length for your band saw is 119-1/2" .
What is the blade size
This is your blade dimension 119-1/2" long x 1" wide x 0.035" thickness . You can purchase blades on sawblade.com .
Amada HA-250 horizontal band saw troubleshooting guide.
You can download free Amada manual on bandsawmanuals.com .
May 30, 2014 | Saws
Looking for a 11"sychronizing belt from a 9" 2 speed band saw from another bandsaw fit a bandsaw of another make
Try to find a local auto shop. They might a have a belt available for your bandsaw. If you need band saw blade, I suggest you visit sawblade.com .
Apr 26, 2014 | Delta BS100 Shopmaster 9 Inch Bench Top...
Mt 18 inch horizontal band saw is not cutting square
Thicker metal shows greater blade / saw adjustment errors. A simple 1/64 or 1/32 wont show much on an 1/8 thick piece of metal when cut.
Those numbers will double quickly as the cutting blade travels through thick metal.
Metal band saws seem to be trickier to adjust and fine tune because the blade seems to be twisted into the roller guides.
The downloaded manual for the saw that looked most like mine at grizzly.com helped my adjustments a lot.
The saw quality is also a factor.
Dec 18, 2010 | Saws
Saw blade jumpes off at motor pulley on horizontal band saw
It is probably not tracking. you need to back off the guides, get the blade to track in the center of the tire by hand. Then torque it up a bit till it twangs, Then pull the guides up the blade and just touch it, don't push it at all, the bearings too. This should track and not jump off. If it does, then one of your wheels is out of whack, check them with a straight edge with the blade set. See if they are in line. One of the bearings could be bad. Check it out.
Apr 15, 2010 | Wilton 5" X 8" Dry Horizontal Bandsaw Band...
I HAVE THE JET 414458 HVBS SAW.THE SAW CUTS ROUND STOCK CROOKED.IT LOOKS LIKE THEBLADE IS IN CONTACT WITH THE STOCK AT THE START OF THE CUT AND ABOUT .250 AT THE END OF THE CUT THE STOCK IS 1" IN DIAMETER
There are two possible reasons for your band saw to cut crooked.
1 is the set on one side of the saw blade has worn down and you need to change your blade, or
2 your band saw blade is not square to the bed of your band saw.
If the blade is brand new and it still cuts crooked then you need to square the blade to the bed. To check if the blade is square to the bed, lift the head of the saw up a couple of inches and take a square and set it on the bed. Slide the square up to the blade and to see if there is a gap between the edge of the square and the blade. Try to pick a spot on the blade where the tooth is straight or bent away from the square. If there is a gap you'll need to move both blade supports in or out until there is no gap between the edge of the square and the blade.
If you are unable get it squared yourself, contact the place you bought the saw from. They maybe willing to send a service tech out to do it for you. Some band saw blade makers are also willing to send a service tech out to correct any problems that you may have. Lennox is one such company that may send a service tech if you are using their blades.
Hope this helps you,
Hatter1
Mar 06, 2009 | Jet 414458 HVBS - 56M Horizontal/Vertical...
Dayton Audio Dayton 4YG31 Horizontal Band Saw Logo
164 people viewed this question
Top Dayton Audio Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Dayton Audio Saw Expert? Answer questions, earn points and help others
