Question about Dell 5650 Computer Speakers
My left side speaker is not working. I plugged in another speaker to the sub output (the plug not working) and got nothing, which proved to me that the speaker wire and speaker itself is not faulty. could my sound card have one channel bad...also it doesn't seem like my center speaker (under the monitor) is working either....help!!!!
  • Dell Master
  • 629 Answers
Could be the sound card or its driver. Check your sound properties and make sure the correct set up is selected like 2.1, 5.1 adn 7.1. Verify that the volume levels are balanced, and if nothing helps, reinstall the video driver first. If this does not resolve it, might be a good idea to test the speakers on another system just to confirm they are all ok. If that works, you may need to get a new sound card, or test the card on another computer if possible to confirm if it is at fault. Hope this would be helpful to you.
Posted on Oct 14, 2010
How do i connect my subwoofer to my home theater
Easy. Your home theatre amp will have a sub or LFE output ( RCA plug ). You simply connect this output to the input ( usually the left side, or use a Y splitter and use left and right inputs, or the LFE input if your sub has it ). Then, you must turn the sub on in your recievers setup menu, and your sub should work.
Mar 03, 2013 | Sunfire True Sub MK II Subwoofer
I have a stock stereo and two subs with an amp in the trunk. Also two alpine speakers in the rear. Whenever I turn my balance to the left my subs don't play. What's wrong?
Hello.... I am sorry to hear you are having problems. The reason for this is that since you have a stock stereo, the shop (or person) whom installed the amp and subs used a line out converter. What this part does is allows the connection of RCA cables to the factory head unit. Almost all bass signals are always in stereo, so since you were only hooking an amplifier for just subs, you can actually just connect to just one of the rear speakers instead of connecting to the right and left. Just makes the install a little quicker. There is nothing wrong with this as I usually do the same thing in our shop. However, if you are going to be using the balance control, then you will need to go back to the shop and have them hook the converter up in stereo (to both rear speakers). Hope this helps!
20 year car audio/video installer
Bay manager
Mar 15, 2011 | Alpine Car Audio & Video
I have a Boston Acoustics VR-500 Subwoofer with a problem. As soon as anything is plugged into the line level RCA jacks, the subwoofer produces a loud buzz/hum. I have tried connecting it to the subwoofer...
I'm thinking you have an open shield ground on the RCA input side. Connecting speaker inputs possibly restores the ground. Try connecting the high level inputs then disconnect the remote end of the cables (floating the grounds).
Then get out an ohmmeter and find that open circuitor or bad solder joint between RCA ground and real ground in the speaker's amplifier. Or.... if speaker ground kills the hum and you want to use RCA Line Level input to the sub, just connect one minus speaker output on your source amp to one minus on the sub's amp.
Mar 01, 2011 | Audio Players & Recorders
RIght speaker not working in speaker system. Switching the left with right speaker make the right speaker work (not speaker) Plugging the 2 RCA into a different input changes nothing. 2 rear speakers...
Let's name the product and use FM for troubleshooting. Are you saying you have the Right Front and both rear amp channels/speakers not working? What DOES work?
Jan 17, 2011 | JVC Audio Players & Recorders
I am trying to hook up a powered sub woofer to a yamaha rx-v461 and i dont know what cables go where on the back of the sub there are two speaker ports and there are two plug ins but each speaker port has...
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Sep 28, 2009 | Yamaha RX-V461 AV Receiver
RXV 995 SUB output is DEAD
If there is a real failure in the Sub Output it would indeed be unusual. I'd still sift carefully through all of the settings. The Sub Out is very likely to be its own unique channel so I would try something that bypasses multichannel decoding entirely, like plug in something low-bass-rich to the Subwoofer (IN) at the External Decoder area on the left rear of the unit. Press Ext. Decoder and see what comes out of the Sub output. This bypasses all DSP and could prove if the Sub Out really does work.
Does it not work in speaker level setup either? That at least would eliminate any source issues.
Apr 14, 2009 | Yamaha RX-V995 Receiver
Logitech x-530 rear speakers and Center speaker not working
you have to go to your audio output setup (try to look for an audio-related icon on your taskbar - next to time display)
setup your audio output for 6 channel or 5.1channel output (depending on software)
follow on-screen description of where to plug in your speaker jacks - green, peach and black.
enjoy...
Dec 02, 2008 | Logitech X-530 Computer Speakers
Amp works but no sound from sub
Some older Pioneer radios require you to connect the Subwoofer RCA to the rear output on the back of the radio and then you have to turn on the subwoofer in the menu on the radio. What model Pioneer radio is it? Also, make sure that the RCA plugged into the amp is on the input side, not the output side.
Jul 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Right speaker doesnt have sound
1ST.-The right jack could be damaged!!
Usually, there is a [+} posaitve & [-] negative input\output to speaker connections. Not all [-]neg. is ground.Sometimes the [+] pos. is grounded. [The exception to the rule is that u SEE the black wire going to ground] the reason I am letting u know this is that u can test the INSIDES of the sound system.
If u can get inside of the unit. Cut the left speaker output [+] posative from both outputs. criss\cross wires.Place left speaker output to right speaker jack[ that does not work!!] & visa versa.If the [LEFT Output] stops working after u plug in the speakers,the internal RIGHT output is damaged. NEEDS TO BE TESTED
If nothing nothing changes.The left still works & the right still does not work, then it is the jack (shorted ?, opened internally ?)
Jun 11, 2008 | Logitech Z-2300 Computer Speakers
TEAC - CD-X9 - No sound in left speaker
the speaker wire itself could be grounding out. look for small knicks in the wire and make sure the plug is not faulty. RCA plugs can go bad which would account for intermitent troubles some times
Dec 28, 2007 | Teac CD-X9 Shelf System
Dell 5650 Computer Speakers Logo
156 people viewed this question
Top Dell Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
