Question about LG Televison & Video
I have lg dsi855p dvd player in remote i selected VGA Mode now i am not able to view the video on tv screen. plz give a solution to change the VGA option
  • 1,557 Answers
In this case you need to reset the unit to factory i have serched the net but can not find the reset function i will contact lg australia and get back to you . another way of fixing this is plug your computer monitor into the vga plug on dvd player and set the output back to rca
Posted on Oct 14, 2010
How do I go from TV mode to the DVD screen with my remote
My TV remote has a 'TV/Video' button that when pressed, toggles the TV's screen back n' forth between watching TV or viewing your DVD/VHS. Pressing the button once displays a video-1 screen, twice, a video-2 screen, and third, back to watching TV programs (having two video option screens allows for another DVD or VHS player to be assessed, as long as the TV has another rear connection for a second unit). As long as the DVD player is plugged into the back of the TV, the TV's remote (not the DVD's remote) should accomplish the function.
Nov 11, 2016 | Televison & Video
I just purchased this DVD LG I'm trying to find out what channel to put it on to watch my DVDs on and I'm on DirecTV
There is usually a switch on the back of the DVD player to choose either channel 3 or 4. You will need to use the TV's remote not the direct TV remote. To change the source or input to the correct inpit mode on the remote select input then select the input mode that you plugged your DVD into ( tie. HDMI 1 or 2 ) then turn on DVD that should do it
Jul 26, 2015 | LG Televison & Video
How do I put my tv in video mode so I can watch a dvd?
Hi Anonymous,
Please press SOURCE key on the remote, source menu will appear on the screen. Select the source like AV1 or AV2 to which you have connected the DVD player through AV cords.
Happy viewing.
May 31, 2015 | Televison & Video
Hook up to view dvd's to tv video cables with yellow white and red plug ins.
Hello, here is a sample for auxilary connection for the chdvd300: . Use the AV (Audio/Video) cable
provided to connect the DVD player to
your TV as shown in the diagram.
. Your TV must be equipped with AV
inputs like those pictured to the right in
order to connect this unit.
. If your TV does not have AV inputs, you
will need a RF Modulator to connect this
player to your TV's antenna/cable input.
RF Modulators are available at major
electronics retailers.
Connect the DVD Player to
your TV
CH-DVD 300 Quick Setup Guide
. The goal is to see the DVD player's splash screen on your
TV. To do this, select the Video Input channel on your TV
that corresponds with the input the player is plugged into.
This procedure differs among TVs, but is normally done by
pressing the VIDEO IN or INPUT button on the TV's remote
control to select the Video Input.
. When the DVD player's splash screen appears on your TV,
you're ready to go!
4 Select the VIDEO INPUT on your TV
TM
Pr/Cr
PROGRESSIVE SCAN
COMPONENT VIDEO OUT
Y Pb/Cb
VIDEO
S-VIDEO
L
R
COAXIAL
TV
ANTENNA / CABLE IN
CH-DVD 300
VIDEO R - AUDIO - L
. Plug the DVD player's electrical
plug into a wall socket or power
strip.
2 Plug-in the Power Cord
3 Turn on the DVD Player and your TV
. Press the POWER BUTTON on the front panel to turn the
DVD player on. The POWER LED should now change
from RED (STANDBY MODE) to GREEN (ON).
POWER LED
You can find an quick install wiring schematic at retrevo.com, just type your model number in the search window.
Aug 11, 2010 | Cyberhome CH-DVD 300 DVD Player
I turned on my TV and for the first time in 3 years, you can't play DVD's from the BOSE on the LG TV screen. Usually I select the AV1 or AV2 option shown, but neither is working and informing me that there...
first you've got to check the cable if they are good.and you DVD player may be in progressive screen mode. change it to normal mode with your remote or in the front or in the rear of the DVD player there is a botton for that.
Sep 04, 2009 | LG 42LC2D 42 in. LCD HDTV
I have tried to connect my SD 6100 and am getting no picture. I get sound.
You must use the remote to toggle the player OUT of HDMI output mode to use the non-HDMI outputs (like standard RCA-jack VGA or s-video or component video output). The device displays black screen by default unless you're using HDMI, so it's not possible to see the menu if using s-video. The manual states to press the 'Progressive' button to change modes. Unfortunately, you can't see what mode you're toggling through until you hit the right one (Toshiba blew it here!!). Power on the device WITHOUT a disk in (you can't change modes during DVD playback mode). There are four output modes, so press the 'Progressive' button on the remote and wait for 3 to 5 seconds for the player to switch output modes. Repeat this up to four times to cycle through the available modes. During one of the modes, you should see output to your screen through the cable hookup you've physically attached. You will also notice the led's on the front panel go on and off during the process at times. If you ARE using HDMI, then you have to select a mode your TV or monitor can handle. When in HDMI mode, you'll notice the front panel HDMI led's will light up. There are five modes here - 480P, 720P, 1080i, 1080P and AUTO (when all four leds are lit). Select the HDMI mode that your TV works with. Good luck ~ and don't bother calling Toshiba support ... friggin waste of time talking to a recording that's dumber than Sh#@!!
Jul 09, 2009 | Toshiba SD6100 DVD Player
How to reset the default value for the toshiba sd 6100 dvd player
If you want HDMI 'Auto' mode (the factory default), you need a combination of selecting the proper output mode (use the remote's 'Progressive' button to toggle between the four output modes: HDMI, RCA VGA, component video out and s-video. Once you're in HDMI mode (the led's on the front of the box are a dead give-away!), then you can press the front panel 'HDMI Select' button to move through the five available HDMI settings: 480P, 720P, 1080i, 1080P and 'Auto'. You're in 'Auto' mode when all four led's are lit.
Jan 25, 2009 | Toshiba SD6100 DVD Player
Is there an input select?
I can view channels but cannot view a DVD from the TV/DVD Disney Princess Combo. Only see static on the screen with no sound. I wonder if I need to change the input select to view a movie but cannot find a button on the TV or remote control. I have a 6 button remote which I am sure operates the DVD and another remote with 39 buttons I thought would operate the player as well as the TV. However, so far only the player functions from it. The buttons only have small pictures without words which sometimes leaves some question about purpose. This is a second hand unit. I do not have a manual. It did play movies at first. I think the trouble may have started when I programed cable channels. Any help will be greatly appreciated
Apr 24, 2008 | Disney DT1300-P 13" TV
LG DK 8621P DVD Player only play the audio (no video out)
how can off the progressive scan in my LG DVD player model 8680?
Nov 22, 2007 | LG DK 9411P DVD Player
Televison & Video Logo
74 people viewed this question
Computer Repairing
Computer Repairing
