Question about Whirlpool Ovens
Electric oven RB260PYBX. Not heating at desired setting. Replaced element, still not heating. Set temp at 400 and the digital readout rises to 400 but the food is not cooking. Turned off/on and the digital temp readout displays 320. What do I do next. Thanks
  • trobb1229 Oct 14, 2010
    Where is the oven temp sensor probe on the parts diagram and what am I looking for when I check it? Thanks
    I will order/replace the temp sensor. Wait and see. Thanks.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with check the oven temp. sensor (probe) if that's fine then the issue is with the clock going bad and should be replaced however, from what you have described the issue is with the oven temp. sensor. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 14, 2010
    Genius:
  • 1,098 Answers
Here what you can do to troubleshoot and fix the over,
Click this link: http://fixitnow.com/wp/2007/11/26/how-to-troubleshoot-an-electric-oven-that-doesnt-heat-up/
Frigidaire oven temperature unreliable.
Is this an electric oven? Sound like a bad breaker to me if it is.
Dec 22, 2016 | Frigidaire Ovens
Bottom oven isn't heating to desired temp. Considering swapping the heating elements to see if one is faulty - thoughts?
try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
Sep 20, 2015 | Thermador PODC302 30" Double Electric Wall...
Temp shows 400 but oven is at 300
Is it continues to heat up then its working fine...if it continues to heat pass 400 then your have a thermostat problem and the oven is out of control. I do believe that the display is not an actual reading of the oven temperature, instead it is a reading of where the operator has set the temperature to . I have yet to see an oven with a actual reading temperature display.
Dec 01, 2013 | GE Profile JTP18 Electric Single Oven
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
GE free-standing electric range Pre-heat oven temp is about 50 degrees less than what is set (i.e. set digital display to 400 and over only reaches about 350). Is there an adjustment that can be made to...
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
Nov 08, 2010 | GE JKS05 Electric Single Oven
Kitchenaid oven KEBC107KSS03 won't heat after cleaning cycle.
I have a kitchenaid oven # KEBC107KSS03. When I set the temp to 400 the buzzer goes off saying the temp has reached the desired temp, the temp is only 250 and will take another 20-30min to reach 400.
thanks for your reply
Aug 25, 2009 | KitchenAid KEBC107 Electric Single Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
Apr 20, 2009 | Viking 30" Professional Select Built-in...
240V wall oven,digital readout and oven light come on but no heat
Bad clock assembly although the clock works the solid state switches internally typically go bad even on brand new ovens,does broil work,the top elements should work?
Jan 21, 2009 | Ovens
GE Profile JT952 Double Wall Oven doesn't heat up adequately
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 29, 2008 | GE Profile JT952 Electric Double Oven
Ovens Logo
159 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
