Question about Dell Inspiron 1420 Laptop
My inspiron 1420 does not turn on.when i push the power button the light comes on then goes off. can someone tell me where i should check first?
    President:
  • 1,768 Answers
1. your battery has been depleted and the power adapter is possibly faulty.
2. the first thing is to get a charged battery in the unit this will tell you if the battery smart
circuit is OK.
3. A new power adapter may be the issue and you may have to purchase a new one.
Usually eBay has them for "buy it now" purchase for about 12 - 25 dollars. You will have to
check the site to get the best deal.
I have purchased several from reputable Ebay store and they are still working.
4. Make sure that you get proper voltage/ current specification from your power adapter
you have now.
5. If these two things do not remedy the issue then this is a power contact/ mother board
issue at the power input connector and or the regulator circuit on the mother board.
this means that the mother board may need repair of replacement.
I hope this helps. Have a great day!
Posted on Oct 14, 2010
  • 755 Answers
Power supply and or battery. Take the battery out and try to start it with the ac supply only.
If you can find one try another power supply too. Sometimes when your power supply goes bad you just run the battery down till the day it wont restart.
If you have a volt meter you can read the output of the power supply and make sure it is putting out the right voltage.
The battery light flashes alternately blue and amber everytime i turn on my inspiron 1420 (even when cool). I've done a health check using the check button on the battery. Indicates battery status fine and...
Hi justlai33
Not to worry, it is a normal process when any laptop is started. It first check if it is connected to power and starts charging if connected to power.
As far as battery life status is good and fine, you can continue working on your laptop.
You will get a pop of notification when the battery life about to end, till then you can work with out any tension.
Thank you
gowtam1402@live.com
091-9916828137
Jan 02, 2011 | Dell Inspiron 1420 Notebook
When I turn on my Dell Inspiron 1420 and the password screen comes up, I put in my password and it says it is wrong. I haven't changed it and now it is wanting me to reset password. Is there anyway to do...
The problem with these kinds of questions is that passwords are there for a reason, and we can't know the validity of that it's your computer OR your password. There are easy work arounds, but you will have to google them as they could be unethical, so I can not in good faith tell you how to bypass someone's password.
You'll need to know your OS and you'll probably need access to a 2nd computer to burn a CD, or at least you'll need a USB stick.
For anyone who runs into this problem, and you've MADE CERTAIN you're entering your user name, if asked, AND you've tried logging in in safe mode (usually hitting the "f8" button while booting on windows OS's gets you a safe-mode menu) with no luck or results, make sure when you DO figure out the solution, that you WRITE DOWN your password somewhere.
Passwords don't change, unless YOU change them.
Or it's not your computer.
Aug 29, 2010 | Dell Inspiron 1420 Notebook
Dropped my inspiron 1420 and now will not come on at all.
If it is still under warranty, send it to the manufacturer, but if you tell them you dropped it they may not fix it and might charge you, if you just tell them it stopped working they will look at it for you, otherwise buy some hardware waranty first, then wait maybe 2 weeks and call it in and they will look at it. If they look at it and can determine still that things are broken inside other than just being dislodged due to the drop, they may not repair it but its worth a chance. There is a chance that the power suply was affected because no lights canme on, but there might be many other things wrong due to the fact. You have to decide and not delay.
Aug 18, 2010 | Dell Inspiron 1420 Laptop
When i start up my dell inspiron 1521 it goes into startup mode then screen goes black.took the power cord out n it will start up plug it back in the screen will go blank again.it will run on battery n the...
I have a Dell Inspiron 1525 and had the same exact problem. I finally called Dell and they sent a tech out. They replaced my power cord and all the software. The reason for this is because Dell Inspirons has a default in the AC cords. Sounds like the AC power cord is the problem. You could find someone who has this cord and test your Inspiron with it or try calling Dell! It worked for me.
Jan 28, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
My dell Inspiron 1420 will not power on. when the power button is pushed the power light comes on for about 3-5 seconds followed by the battery light for about 1 second and thats it. nothing else comes on...
a dell inspiron 1420 is a laptop you have put it under printers
im assuming your talking about a laptop
try charging your laptop or turning it on with the charger still attched to the laptop
if laptop does not turn on with the charger attached then either that the battery is dead and you need a new one or your laptop itself is gone
Dec 30, 2009 | Office Equipment & Supplies
I purchased a dell inspiron 1420 off e-bay. can someone please tell me how to get a wireless connection
There is a picture of two little monitors on the bottom right hand side of your screen, on the toolbar. click on that, then click connect to a network, then pick a connection if there is one and then you should hane a internet connection. I hope I helped you out.
Dec 15, 2009 | Dell Inspiron 1420 Notebook
I owned a Dell(inspiron 1420) touchpad is not functioning at all!
Try going into Control Panel, Mouse, Tapping and turn it all off.
Set the sensitivity to as low as you can.
The key combination should be Fn & F9, look for a button on the function row that has a finger pointing at a box :)
Jul 30, 2009 | Dell Inspiron 1420 Notebook
The screen is very, very dark. Someone told me the backlighting might be broken, but I don't know. I can just barely make out things on my desktop. The lighting can't be turned up.
make sure your wire is connected to the main power, cuz it could be loose, my laptop goes dim if its not connected to the main power, but im not sure about very very dark
Jul 04, 2009 | Dell Inspiron 1420 Laptop
Dell Inspiron 1420 Laptop Logo
287 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
