Question about HP Photosmart C4250 Multifunction Photo Color Inkjet Printer
My HP 4250 printer keeps saying printer jam, there is NO paper currently in it, and no paper jam.
  • 1,557 Answers
The problem is that there are around 4 tiny sensours in the printer if just one of them has a tiny peace of paper stuck under it the unit will read paper jam so have a good look around at the sensours and make sure there all clear
Posted on Oct 14, 2010
HP 4250 SKEWING PAPER
Yes, it is possible to be the problem. Most of the time you would replace the whole fixing unit, it could also be the paper feed rollers in the paper tray or the manual feed tray. Good Luck
Sep 04, 2012 | HP LJ 4250 Printer
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
Paper jam
Try taking out the toner cartridge and seeing if you see any more bits of paper. Also open up the back panel and see if you see anything there.
Jun 12, 2009 | HP LaserJet 4250n Printer
Paper jam on a laserjet 4250
Is the paper tray set to the proper size? and are the tray guides snug against the paper?
Apr 14, 2009 | HP Office Equipment & Supplies
HP 4250 down (paper jam without paper)
hi,
the fuser of that unit is in the back, you can saw it by sliding out the back cover. you can pull it by unlocking the 2 lock on side of it..
try to locate the sensor of the fuser assembly.and also try to see if they pick up very well both tray 1 and tray 2..
hope it would help you..
Aug 05, 2008 | HP 4250 Monochrome LaserJet Printer
Paper jam in HP 4255 office jet all in one printer
the paper path may have some jam. It may have some solid particle or paper that's causing disturbance.
If not the paper moving mechanism is having problem.
Better get your printer serviced.....
Jul 17, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Hp 4250 paper jam erro
Is it a new or refurbished fuser? Where exactly does it jam. By trays, registration or before fuser? Problem can be with various sections. Need to know more.
Feb 12, 2008 | HP LaserJet 4250dtn Printer
Hp printer problems
Error codes starting with 13 usually indicate paper jams. Open all the doors on the printer and remove any removable modules and check for stuck paper.
Jan 11, 2008 | HP Color LaserJet 2600n Printer
HP Photosmart C4250 Multifunction Photo Color Inkjet Printer Logo
311 people viewed this question
Seeker5211
Seeker5211
