Question about Soundstorm CR4000.1 Car Amp
Is the ssl 4000.1 a good buy - Soundstorm CR4000.1 Car Amp
Does CISCO1921/K9 support VPN?
It depends, if you want to setup IPSec VPN, you will need to add SL-19-SEC-K9 or L-SL-19-SEC-K9 license; if you want to use SSL VPN, you will need to buy one of these lincense: FL-SSLVPN10-K9(10 Clientless Users), FL-SSLVPN25-K9(25 Clientless Users), or FL-SSLVPN100-K9(100 Clientless Users), the exact number is up to your SSL users quantity. SL 19 SEC K9 Price Buy Cisco 1900 Series Routers License SL 19 SEC K9...
Mar 26, 2015 | Computers & Internet
I tried to install NetExtender client from SSL-VPN website to Windows XP (x64) with IE8 but getting "Failed to install NetExtender, the installation has been rolled back!" message. I already...
In Windows your security settings need to be set to accommodating this installation you can find the security settings for IE8 by going to tools then internet options set your security to low from your question it reads that you have done this already my research bring me to this option please read below.
Article Applies To:
SonicWALL SMB SSL-VPN Appliances and Software: SMB SSL-VPN 2000, SMB SSL-VPN 4000, NetExtender
Firmware/Software Version: 2.5 or higher
Problem Definition:
When installing NetExtender on any supported Windows operating system, the error "Failed to install NetExtender, the installation has been rolled back" may be observed, especially when the operating system is installed on a drive other than the default. This issue is resolved by upgrading the SSL VPN 2000 or 4000 appliance to firmware version 2.5 or higher and making another installation attempt.
Resolution or Workaround:
For each of the following possible causes of this behavior, an explanation, workaround, or solution is provided:
  • User does not have administrative privileges. With 2.5.x.x firmware and above, administrative privileges are required for initial installation only, previous versions require administrative privileges for each update.
  • Browser security settings. Add https://IP-or-DomainName to trusted sites, and set trusted sites security level to LOW.
  • Popup blocker. Disable all third party popup blockers.
  • Anti-virus or anti-spyware. Temporarily disable all third party anti-virus or anti-spyware solutions.
Source: SSL VPN 2000/4000 2.5 Release Notes this has been copied from doing my research this is not my material but a help post from another source. Thanks for using FixYa! do not forget to vote for me. John
Mar 12, 2011 | SonicWALL SSL-VPN NetExtender Adapter
When i try to buy sykpe credit it says ssl commounication error can not be perfromaned
This is likely a problem on skype's behalf. The SSL connection is the secure route they have to use in order to receive your payment. In this case, it is likely that Skype's SSL server is currently shut down. Try waiting until tomorrow and try again.
Feb 27, 2011 | Video Game Consoles & Games
How to setup a domain
You need to buy a SSL certificate to from a company to make your line secure. Usually GoDaddy has Secure lines for a very good price, here is the link:
http://www.godaddy.com/ssl/ssl-certificates.aspx?ci=8979
Depending on what kind of SSL certificate you need, Go Daddy has it.
Jun 04, 2010 | HP Pavilion dv6000z Notebook
I can't tell if my magellan maestro 4000 gps is charging.
this could be happening for a few reasons but the most common is that its probably not charging.
before checking anything else, plug your 4000 in to a known good charger, then press and hold the power button for up to ten seconds till it starts.
if that fails, its likely not charging
this is very common problem with this and many model magellans.
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get help to repaired it, here
or buy the port here
if you need further help, just let me know.
Nov 09, 2009 | Magellan Maestro 4000 GPS
Need to find a power/battery charger board for Acer Ferrari 4000.
Hi there.
You will be able to get the laptop powerboard from ebay or Sony themselves, although if you get from Sony it will be considerably more expensive.
Good luck and thanks for choosing FixYa!!
May 28, 2009 | Acer Computers & Internet
I got the right info about toshiba portege 4000 battery on http://www.adapterlist.com/toshiba/portege-4000.htm toshiba portege 4000 battery but i not sure whether it will fit my notebook or not.
TOSHIBA Portege 4000 Series replacement Notebook Batteries, buy Portege 4000 Series battery and other goods are brand new and one year warranty! ship to most countries http://www.power-tool-battery.com/notebook-battery/toshiba-portege%204000%20series-1001022.htm
Feb 18, 2009 | Toshiba Portege 4000 Notebook
Setting up existing e-mail onto new pc.
wel smtp is your outgoing mail provider.
example.
email account kpn
internet account kpn
correct settings:
pop.kpn.nl
smtp.kpn.nl
email account kpn
internet acount xs4all.
this is the correct settings:
pop.kpn.nl with correct username and password
smtp.xs4all.nl
as you see you have to take the smtp address of your internet ADSL provider.
good luck.
Dec 06, 2007 | Computers & Internet
Magellan maestro 4000, 4040, 4050 vs mio c220,c230,
Don't buy a Magellan. There is little to no support, and their web based support redirects to no where useful for upgrades. I'd sell you my 4040, but can't in good conscience sell it to anyone.
Nov 13, 2007 | Magellan Maestro 4040 GPS Receiver
Soundstorm CR4000.1 Car Amp Logo
120 people viewed this question
Top Soundstorm Car Audio & Video Experts
Coss
Jim Goldsmith
Jim Goldsmith
Are you a Soundstorm Car Audio and Video Expert? Answer questions, earn points and help others
