Question about Roper RAS8445KQ Top Load Washer
The tub will not fill up with water, it appears that a valve is stuck open allowing the water to flow right through, where can I find that valve to either clean or replace it?
    Problem Solver:
  • 87 Answers
Valve is stuck open. get new valve.
Posted on Oct 14, 2010
Kenmore washer frontloader model 417.41122410 code E11
An E11 error indicates a problem with the incoming water. The error will occur if the tub doesn't fill normally in about 8 minutes. This could be related to closed shut-off valves, failing anti-flood hoses, or debris in filters in the hoses or at the inlet valve on the washer. It could also come from a fault with the sensor that detects the weight of the washer tub, a problem with the reed switch that tracks water flow into the washer, the air tube that goes to the reed switch or a failure of the inlet valve. It can even indicate that the end of the drain hose is below the water level in the washer and is siphoning water out as the tub fills.
If no water or a trickle of water is reaching the tub, first make sure that the shut-off valves are open. Next close the valves and disconnect the hoses. Place the hoses into a bucket and check the water flow by opening the shut-off valves. Shut off the valves. Clean the filters, including those in the inlet of the washer. Reconnect the hoses or replace them with new ones if there was low flow. (Check the flow at the shut-off valves themselves with a similar bucket under the valve opening, if you can.) If these steps don't work, you need to replace the inlet valve assembly. It failed in the closed position.
If water is filling the tub normally and flowing out the drain, check the drain hose position. If the tub is filling and is held in the tub, then the washer isn't correctly measuring the water flow. Check the reed switch and that tubing by blowing into the tube. Replace a faulty switch and remove any blockages from the tubing. Check the wiring harness to ensure that the message got to the control board.
See http://www.searspartsdirect.com/model-number/41741122310/0582/0153200.html for parts diagrams and price lists. You need the control panel diagram.
I hope this helps.
Aug 15, 2017 | Kenmore Washing Machines
Ftf2140fs1 water fills up tub and over flows with door open when not using it
Hi Greg Meigs - If your washer will not stop filling up with water and overflows the tub, check for one of these problems:
1) Turn off the electricity to the washer. If the water *stopped* filling when power was disconnected, the problem would usually be in the control system of the machine. If the water still continues, then the plunger in the water valve is either stuck open or slow to close. Try turning the water faucets off and on a few times. This small joltmight unstick the water valve. If not, it will need replacing.
2) There could be a problem with the water level switch. Call in a professional.
3) There is a pressure switch hose that is attached to an air dome. This switch tells the washer that there is water in the tub and allows the agitator to start.
- Remove the control panel and you will notice a small hose. See if it popped off of the air dome. If it did, secure it with a zip tie.
If water flow continues, but drains out immediately, then raise the drain hose above the highest water level line of the tub. Do not seal the drain hose to the discharge pipe. This could cause a siphoning action.
Nov 13, 2012 | Frigidaire GLTF2940ES Front Load Washer
Machine keeps filling up, replace pressure switch, still nohting, keeps filling up?
Hello dwl770 - If your washer won't stop filling up with water and overflows the tub, check for one of these problems:
Sep 30, 2012 | Frigidaire FEX831CS Top Load Stacked...
1) Turn off the electricity to the washer. If the water *stopped* filling when power was disconnected, the problem would usually be in the control system of the machine. If the water still continues, then the plunger in the water valve is either stuck open or slow to close. Try turning the water faucets off an on a few times. This small joltmight unstick the water valve. If not, it will need replacing.
I put in a load. The machine filled up but did not stop filling. The dial did not proceede to next step, it stayed at the 10. Overflowing EVERYWHERE. When we moved the dial manually to spin, it drained...
your fill switch is either bad or "gllitched" and the timer cannot move until this switch senses the right amount of water for the load unless its an electronically sensed water/load capacity filled machine,when it starts,the water fills the unit and the pressure switch shuts the water fill off when at selected water level and powers the timer to continue the wash cycle,it works off a "bellows" on air pressure to change a switch by air pressure to operate the machine when full of water
Dec 27, 2010 | Kenmore 22622 Top Load Washer
Rinse cycle water flow slow
This problem is commonly attributed to a water inlet valve (also known as a "mixing valve") that is going bad. The water may appear to flow better during the intial fill cycle, because BOTH solenoids (HOT and COLD) are typically used during the initial FILL cycle. However, nearly all washers use a cold water RINSE. This means only one solenoid is energeized during the rinse cycle which reduces the water volume even more.
If you live in an area that has hard water, or if you use well water, the inlet valve and/or fill hose sediment screens can become clogged with sediment, calcified deposits and rust resulting in a restriction of water flow. You can try cleaning the sediment screens and the water inlet valve in a 50/50 solution of distilled vinegar and hot water to see if you can dissolve any sediment or deposits. Removing the valve from the washer and allowing it to soak in the solution for about 30 minutes, then flushing it with clean water can sometimes return an inlet valve to normal operation. If cleaning the valve does not work, however, you will need to replace it. The following link explains how:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
Replacement parts (if required) can be purchased at any of the following web sites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices will vary between sites so shop and compare. The first three sites on the list have helpful exploded view diagrams to assist you with locating and properly identifing any parts you may need. If the model number you listed this question under is correct, the Water Inlet Valve number is 285805 and is listed as item 18 under the "Controls and Rear Panel" parts listing. The average price is less than $20.
If you have any questions, or if your model number is different, please post back and let me know. I hope this helps you.
Jul 14, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer keeps filling with water even after the cycle is going. I put it on small load, it fills to the right level for a small load, the cycle begins and soon the washer is overflowing. Even after final...
hi there......wow !! your using a lot of water...sounds like you have a failed inlet valve resulting in water flowing continually into the machine.....remedy relace the inlet water valve
regards Sir Galahad
Aug 12, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Washer not filling
Hello yamamanot
Welcome to Fixya
My name is Huum,
You said, You did several loads of laundry yesterday but will not fill today or run.
Here are a common thing that cause this problem.
Washer will not fill!
Faulty Water Inlet Valve
The water inlet valve is the device that meters water from the supply lines into your wash tub. On domestic washers, there are two lines, one hot the other cold. These valves are susceptible to mineral build-up and sediment deposits. There are two common failure modes:
Failure Mode One: Valve will not open.
If you can verify that the solenoid on the valve body is receiving the requisite voltage and the valve will not open, then it is faulty. Since the solenoids operate independently, it is likely that one side of the valve will work and the other will not. This can produce strand results such as a very hot wash when warm is selected (due to no cold water). Or the reverse in that the wash water is cold when warm is selected. If mineral or hard water deposits are a problem, you may witness a substantial increase in the time required for the tub to fill. This is caused be a decrease in the flow ware of the valve.
Failure Mode Two: Valve opens but will not close.
This is verified by a valve that allows water to flow into the tub even though no power is being supplied to the solenoid. This one is usually quickly diagnosed when the machine begins to overflow and the power plug for the washer is disconnected from the wall. However, this will not stop the water from flowing into the machine. The water must be shut off at the wall. As with the previous failure mode, the variant of this failure mode is that it may take the valve a while to completely bridge the flow of water after the power has been removed from the solenoid.
How to Diagnose?
There are a couple of ways to diagnose a faulty valve. However, there is a simple test that one can perform that will usually let you know if the water inlet valve is faulty.
Scenario:
When set to cold wash and rinse, the unit will not fill. When set to warm wash and cold rinse the washer will fill with hot water only and will fail to rinse. This is a common scenario where the cold water side of the valve does not appear to be contributing to the fill, but the hot water side does. This symptom could be easily reversed where cold water is being supplied, but never hot water.
So, how can the problem be determined? It is as simple as switching the wire harness plugs on the hot and cold side. In the example above where the cold water is never being supplied, the symptoms would be the opposite when the wiring harnesses were switched. So the machine would produce only produce cold when warm or hot is selected. No water should be present when you select cold. This verifies that the timer, wiring and switches are all in working order. Assuming this tests checks out, you simply need to replace the water inlet valve.
Thank You For trusting us with your guestion
Please remember to leave a rating before you leave!
Dec 15, 2008 | Maytag PAV2300 Top Load Washer
Water fill not working properly
theres a over flow/check valve in either the left or right corner of the inner tub (looks like a mushroom sotr of,) perhaps this float is getting stuck, or perhaps something has gotten under it i.e. pasta chicken bone.
Nov 30, 2008 | Kenmore Dishwashers
Maytag washer PAV2300 water over flow
from what I am reading on-line, it is the mix valve, aka water valve. Unplug the washer, then see if it still fills. If so, it's most likely stuck open, and needs to be replaced. about $22.00
Feb 21, 2008 | Washing Machines
Roper RAS8445KQ Top Load Washer Logo
22 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
