Question about Lexmark Office Equipment & Supplies
I have a lexmark x4550. It keeps saying "Cover OPen" and its closed
    Guru:
  • 1,342 Answers
Error 30 Top Cover Open or Print Cartridge Missing Make sure the spring-mounted pin on the print head shroud is installed properly and that it is detected by the ramp on the print cartridge as the cover closes. The pin should enter the tower on the HVPS and depress the cover switch.
Different printer, similar issue. May help.
Posted on Jun 02, 2008
Lexmark x4550 installed new cartridge a lexmark cartridge I keep getting alignment error. Take the tape off. There is no tape to take off since I already took it off. How can I fix this problem?
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Mar 12, 2012 | Lexmark X4550 InkJet Printer
The printer (Lexmark X5340) display "cover open"
Short of slamming the cover closed there is a small tab that tells if it is open or closed. It should be located on the lower right hand corner. Once you find it just put a small piece of paper there or plastic and you should have no more problems.
Mar 30, 2011 | Lexmark Office Equipment & Supplies
Hi, my printer keeps saying 'clear carrier jam, then press tick' everytime i press the tick, it moves the cartridges across with a bang and returns to the same msg. pls help if you can ta jas
It is require servicing if you can open the cover and apply some lubricant oil on the steel rod it will fix the problem otherwise show it service center.
Jan 26, 2010 | Lexmark X4550 InkJet Printer
Installation of x4550 printer without installation d.v.d
open link and download driver .....
http://support.lexmark.com/index?locale=en&segment=SUPPORTproductCode%3D&startover=y&userlocale=EN_US&question=Lexmark_X4550&productCode=LEXMARK_X4550&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X4550&searchid=1255948371824#2
Oct 19, 2009 | Lexmark X4550 Multifunction Wireless Color...
My power supply is dead how do I order a new one.
You can get one from lexmark, or off of ebay. Your power supply will say how many volts it outputs.
Match this up with new one
You also get one from
www.newegg.com
www.argecy.com
or others. Just type in your model #
Aug 04, 2009 | Lexmark X4550 InkJet Printer
My lexmark x4550 will not load paper at all
hello
u have to need chak your printer gare box or roller u have to change the roller becose of due furicsion roller has been damged its cant pick up papaer so u nyour printer roller eed to change
Jan 09, 2009 | Lexmark X4550 InkJet Printer
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
App4R.exe
you can go online and get the right software delete out the old software and do the install from scratch
Nov 10, 2008 | Lexmark X4550 InkJet Printer
Lexmark P3150 says cover is open
May be the cartridge not fitted properly.
Also try to unplug the printer during PC on. and then replug it.
Try to power off printer, restart PC and disconnect USB, then connect after restart PC.
Let me know if you need further help.
Oct 04, 2008 | Lexmark P3150 All-In-One InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
