My printer claims the cover is open and its not,,, I have a lwxmark x4550
  • yoderdance Jun 02, 2008
    replaced ink cartridge and since then says cover is open but it isn't. was looking for place to put paper as suggested to trick the printer but don't know where to look.
I too have this issue only with the scanner. After it scans I open the lid to put in another picture and it thinks I opened the cover and it takes a minute to cycle the cartridges and warm up the scanner again. What gives?
Posted on Aug 18, 2008
Lexmark x4550 installed new cartridge a lexmark cartridge I keep getting alignment error. Take the tape off. There is no tape to take off since I already took it off. How can I fix this problem?
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Mar 12, 2012 | Lexmark X4550 InkJet Printer
Please instal my lwxmark printer
You need to download the user manual which is available from support.lexmark.com website. The user manual will give instructions on how to install the printer to your computer.
For further assistance, please contact Lexmark Technical Support.
May 11, 2011 | Lexmark E120n Laser Printer
I have a paper jam in the printer lexmark x4550 and don't know how to get to it
If you're having trouble getting the paper jam from the feeder, you can open the cartridge area. You should be able to get a better hold of jammed paper out from there.
Apr 11, 2011 | Lexmark X4550 InkJet Printer
Lost cd to reinstall printer
You can download the installation driver from manufacturer's site by clicking this link
  • On the page which opens, select the operating system of your computer (Windows Xp/ Vista..) from the drop-down menu and download the required driver.
Hope this solves your problem. Thanks for using FixYa.
May 13, 2010 | Lexmark X4550 Multifunction Wireless Color...
Hi, my printer keeps saying 'clear carrier jam, then press tick' everytime i press the tick, it moves the cartridges across with a bang and returns to the same msg. pls help if you can ta jas
It is require servicing if you can open the cover and apply some lubricant oil on the steel rod it will fix the problem otherwise show it service center.
Jan 26, 2010 | Lexmark X4550 InkJet Printer
Paper does not feed into printer
Printer Lexmark X4550 not taking paper, (Quick Fix)
Hi, yes my printer had the same problem with the pick up rollers not taking paper,
and thought it would be a simple job to adjust the springs inside the printer? But no, I could not find to open the printer. So I devised a simple modification using a
thin flat spring I had taken from an old windscreen wiper blade. see instructions
Good luck, bigvern
Jan 10, 2010 | Lexmark X4550 Multifunction Wireless Color...
Installation of x4550 printer without installation d.v.d
open link and download driver .....
http://support.lexmark.com/index?locale=en&segment=SUPPORTproductCode%3D&startover=y&userlocale=EN_US&question=Lexmark_X4550&productCode=LEXMARK_X4550&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X4550&searchid=1255948371824#2
Oct 19, 2009 | Lexmark X4550 Multifunction Wireless Color...
I had to take pc back to factor settings and can't get printer ..
You can download the user manual and the driver from this link.
X4550 Lexmark
Hope this helps.
Sep 25, 2009 | Lexmark X4550 Multifunction Wireless Color...
Paper jam.
many people misunderstand this term ....or its the wrong term to describe the problem . the printer could actually have a carrier jam . (carts getting struck to a corner) . open the cover to make sure the carrier is in the ,middle .
Jul 20, 2009 | Lexmark X4550 Multifunction Wireless Color...
I have a lexmark x4550. It keeps saying "Cover OPen" and its closed
Error 30 Top Cover Open or Print Cartridge Missing Make sure the spring-mounted pin on the print head shroud is installed properly and that it is detected by the ramp on the print cartridge as the cover closes. The pin should enter the tower on the HVPS and depress the cover switch.
Different printer, similar issue. May help.
Jun 02, 2008 | Lexmark Office Equipment & Supplies
70 people viewed this question
jasbo
jasbo
