Question about Panasonic Televison & Video
Can I leave my HDTV in freezing conditions over the winter? I have a cover but it won't insulate the unit. Thank you.
  • 1,557 Answers
Most people will tell you it will harm it but consider the following we wash tvs in water then dry them out and they work fine the only part i would be concerned about would be the screen but there well sealed just make sure before its next used put it out in the sun and get all the moister out of it before plugging it in
Posted on Oct 14, 2010
Can I leave a dehumidifier in an unheated cottage for the winter? Where will my answer appear?
you can leave it turned off emptied in the unheated cottage. but i would not reccomend letting it run or stay with water in the tank. as water expand when it freezes. and will break the tank. also . dehumidifiers do nothing in freezing condition other than waste energy. so empty the tank and store it for the winter.
and your answer will appear right here :)
Nov 08, 2016 | Dehumidifiers
If i insulate my pipes, will it stop them from freezing the water? This problem has been happening a lot this winter, it is colder than usual where I live.
Insulating your pipes won't stop the water from freezing but it will take a much longer time for the water to freeze, so it defintely helps a lot. I would do it if I were you.
Jan 31, 2013 | Insulation
How do I leave the water heater when I go away for the winter
if you leave the heating on low to stop freezing is fine . Not sure how you water works but I would leave it on to stop freezing Also get some one to pop in once a week to check things are ok .
Mar 19, 2017 | Beretta Water Heaters
Winter closing instructions
Winterizing your Spa or extended period shutdown If you don't have plans to use your spa during the winter months, you should drain it completely well before the temperatures get low enough to produce a hard freeze.
Hot tubs that are heavily used by bathers should be drained every 3 - 4 months. When it's time to drain, either drain to a sanitary sewer or use the water for lawn irrigation. Make sure no chemicals have been added for at least 48 hours before draining.
Water in spas filled with sprayed foam insulation will still freeze if not heated. Finding and fixing leaks in that foam is a nightmare! These recommendations could potentially save you a lot of money!
These basic steps will ensure safe, effective shutdown of your spa for the winter months or any other extended period with out use. Factors such as spa installation, location, type will affect the steps and procedures.
Use these recommendations as a guide.
  • Disconnect the spa from the power supply.
  • Open the drain valve (if installed) or pump out all water.
  • Remove the filter cartridge(s). Clean & store in a dry place. (FILTER FLOSSER)
  • If possible attach a wet/dry (shop) vacuum (capable of blowing air as well as vacuuming) to the hole in the bottom of the filter housing.
  • Using the blower function, blow out any excess water through the plumbing system - allow a good 5 minutes of blowing time.
  • Use the shop vac to remove any water blown through the jets into the tub or towel dry any remaining water from the spa, until it is completely dry.
  • Leave drain & gate valves open, if you have rodent issues we recommend MOUSE AWAY.
  • Close the spa cover and fasten with tie down safety locks.
This is not a job you want to do in freezing conditions, give yourself enough time. Make every effort to ensure ALL of the water is removed - including remnants in the pump lines and jets.
These are common sense steps always be safe around water and electricity.
Sep 20, 2012 | Pool & Spa
How do i winterize it
They recommend using plumbers antifreeze or RV's antifreeze, flush it down the toilet and let it sit in the drain pipe so the pipe won't freeze. Also is a good idea to insulate the piping, this will also prevent it from freezing.
Sep 21, 2011 | Saniflo 002/005/007 Saniplus Toilet with...
My A/C blowing air, but it is not cool. It has started freezing up. We just replaced the air filters and since then it is freezing up. We even gently cleaned the a/c coils before replacing the filters. ...
Hello, sounds like it is either a low charge or lack of airflow, what type of filter are you using? sometimes those filters that claim to be super effecient will actually cut down on your airflow and cause the ac to freeze up.
Jul 15, 2011 | Intertherm Heating & Cooling
I am a builder. I installed my Bosch dishwasher.
Hello Gerry, There are two (2) ways to accomplish this. The easiest is to get some RV anti-freeze (enviromentally safe version) and put that into the bottom of the dishwasher as per the instructions. Then when you return in the Spring, just run an empty rinse cycle to purge the dishwasher of the anti-freeze solution.
The other method will require you to remove (pull out from under the cabinet) the dishwasher and (with power turned off!) disconnect the sump pump boot to drain the residual water out of the unit. In some models, there is a small drain plug that you can remove to drain the water out of the bottom sump (pump) section of the dishwasher.
Good that you thought of this, as many folks forget that leaving water in their appliances in freezing conditions can cause some major headaches from burst pipes, pumps, etc. if they aren't properly winterized for the freezing temperatures they'll get in an unheated building.
Hope you find this Very Helpful and best regards!
Nov 17, 2009 | Bosch Dishwashers
Flat screen tv winter storage
HELLO
Your TV will be fine as long as it is kept at room temperature indoors and not inside a shed or similar outbuilding. Much warmer in a house, probably near freezing in a wooden shed.
Hope this helps you (:-)
Oct 17, 2009 | RCA L32HD31 32 in. LCD HDTV
Fan freezes up with ice in winter
They need air, do not cover it when in use.
If ti cools fine in summer then you just have a defrost problem.
Make sure the outdoor coil is clean.
If the coils are clean, then you have a bad defrost control.
In heat mode the unit should go into a timed or temp controlled defrost. If it is frosting up to the point of stopping the fan, in heat mode only, and otherwise operates properly, then its a bad defrost control.
It is reccomended that the defrost temp sensor be replaced at the same time the defrost control board is replaced. Some temp sensors are part of the board and not a seperate component, but not most.
Aug 19, 2009 | GE Zoneline AZ25E12D3B Air Conditioner
Televison & Video Logo
16 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
