Question about Canon i80 InkJet Printer
Canon iP4500 Most peculiar that this beaut Printer. has a paper jam that I just can't see why or figure out what is going wrong. Iv'e got the torch out & the little mirror & cannot see any obstructions. What happens is that just after the paper goes thru the print head rail it goes crooked & then jams. I'm just about 1/2 way thru the first new print tanks. I only bought it on the 4th of May 08 Any clues would be great. Thanks Phil in Byron
    Champion:
  • 207 Answers
  1. If the paper came part way through the front of the printer, gently pull the paper toward you to remove it.
  2. If the paper did not come part way through the front of the printer, try removing it from the back of the printer:
    1. Remove the paper from the tray and then pull down on the tray to open it to a horizontal position.
    2. Gently pull the jammed paper to remove it from the back of the printer.
    3. Lift the tray up until it snaps back into the paper-loading position.
  3. If you cannot grasp the edge of the jammed paper to remove it, try the following:
    1. Turn off the printer.
    2. If the optional Internal Battery is not installed in the printer, unplug the printer power cord. Wait about 10 seconds and then plug the power cord back in.
    3. If the optional Internal Battery is installed in the printer and the printer is plugged in, unplug the printer power cord. Open the battery compartment cover and remove the battery. Wait about 10 seconds and then reinstall the battery. If desired, plug in the power cord.
    4. Turn on the printer. The printer checks for paper in the paper path and will automatically eject the jammed paper.
  4. Press OK to continue.
  5. *****************************************even after this u face any error mesg pls let me know if there is
Posted on Jun 02, 2008
    President:
  • 2,712 Answers
Looks like either a roller/feeder problem. Since it is under warranty, the best solution would be to simply replace it , instead of trying various fixes..
  • Swilin Sampson
    Swilin Sampson Jun 02, 2008
    @Varungrover: The issue for the gentleman here is not how to remove the jam, but why its happening...
  • Swilin Sampson
    Swilin Sampson Jun 03, 2008
    If the paper feed rollers become dirty, they may not be able to properly
    feed paper due to the feed roller's slippage.
    If paper does not feed correctly, perform the following to clean the paper
    feed rollers:
    1. Confirm that the printer is
      powered on.
    2. Remove any paper from the
      printer.
    3. Select the Paper Feed Roller
      of the Sheet Feeder or Cassette by pressing the
      on the printer.
    4. Press and hold the
      button.
    5. Release the
      button after the Power lamp blinks three
      times.
      Note: The Power lamp will blink and the
      paper feed roller starts cleaning itself by revolving.
    6. When the Power lamp lights in
      green, repeat Steps 4 and 5 up to two additional times. (Please wait
      approx. 30 seconds for paper feed roller cleaning to complete.)
    7. To confirm whether cleaning
      has been performed properly, set a blank sheet of plain paper (8 1/2 x 11
      Letter size) in the sheet feeder or cassette.
    8. Press and hold the
      button and release it when the Power lamp blinks
      three times. (The paper set in the printer is picked up and
      fed.)
    9. Repeat the process as
      necessary.
    10. Note: If
      repeating this procedure three times or more does not solve the
      problem, a printer service error may have occurred. Please contact your
      local Service Center.
    Also ensure that you have selected the correct paper type in the printer properties.
Paper jams after pulled in skew
Mine did this ages ago. I found a staple had accidentally fallen into the printer and jammed on one side causing the paper to go in skewed and then jam up. Get a torch and have a really close look inside where the rollers are for staples, paper clips or bits of paper stuck on the rollers.
Aug 28, 2015 | Canon Pixma MP250 All-in-One Color InkJet...
Service error 6A00
Hello thanks for using fixya.
The 6A00 is a Canon generic code for paper path jam.Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.As a Canon technology,I usually find the code almost 90% of the time it is related to the purge unit being jammed with something and not being able to move.Moving the print head assembly will not clear a purge unit if its jammed with paper,paper clips,push pins,screws,cookie crisp,flower bud pods etc.
I have found all those things in a purge unit.The offending item needs to be removed or the purge unit needs replacement.A
Canon Pixma iP4500 InkJet Printer would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model & its always a paper path error or purge unit
I forget myself so here goes, the purge unit,called a spittoon assembly in an HP,lexmark & other ink jet printers,is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.That is why you 'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow
See my this "Solution" same as your's & 3 people thought that it was helpful for them
I hope this solution will also helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Jan 14, 2011 | Canon Pixma iP4500 InkJet Printer
The paper enters the printer crooked, causing a paper jam every single page.
REMOVE THE INK CARTRIDGE TURN PRINTER UP SIDEDOWN AND SHAKE THIS WILL REMOVE ANYTHING THATS FALLEN DOWN THE PAPER PATH
Oct 21, 2010 | Canon Pixma iP4500 InkJet Printer
Unable to feed paper
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Sep 06, 2009 | Canon Pixma iP4500 InkJet Printer
Error 6a00
I found numerous suggestions on FIXYA for other Canon printer models with the same 6A00 error message. The isuggestions mainly zero in on the purge station where the printer head parks and possible cause being bits of jammed paper at the two pieces of sponge material. There were several reports of cleaning the two sponges at the purge station and the problem going away after. I checked my printer but did not finad any jammed bits of paper. But I found the purge station was a bit up and could be pressed down - probably a bit sticky due to the soaked sponges and not returning to its original position. After that I didn't get the error message anymore. The two sponges on my printer purge station were black and possibly soaked with ink and I am thinking of cleaning these the next time.
ur flashing lights also seem to be a cnsequence of this....
hope it helps.... good luck
have a nice day
Jul 08, 2009 | Canon iP4500 Photo Printer
Canon Pixma iP4500 error 5100
Hi You can Try
Another old posting
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Oct 17, 2008 | Canon Pixma iP4500 InkJet Printer
Paper jams
try this
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Sep 22, 2008 | Canon Pixma iP4500 InkJet Printer
Canon iP4200
Paper jam!!! UJO's in sight (unidentified jamming objects. At least thats where i would start. Get a torch, tweezers and go on a little itty bitty paper hunt, i am willing to bet you will find a jam of some size or sort. ook everywhere, it doesn't have to be big to cause probs.
Aug 24, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Paper jam
OK, first try resetting th printer. This sometimes works the first time and corrects a lot of issues. Switch it off, take out all paper, check for jams with a torch right down back and open cover and check ther too. Once you are sure there are no paper jams (look really carefully they can be tiny!) unplug all cords and cables. Plug all back in turn it on, and try printing again. Post back if no luck and i will further assist.
Mar 16, 2007 | Canon BubbleJet i560 InkJet Printer
Canon i80 InkJet Printer Logo
461 people viewed this question
old marine
old marine
