Question about Belkin F5D7234-4 Router
-Unable to access the router's webpage. -The router is 'trying' connect to modem (modem light flashing, internet light off) despite the fact it's already connected.
    Problem Solver:
  • 4 Answers
Have to unplug router and modem to reset both for approx. 2 min. Then plug in modem first let that reset and all lights come back on (except router light) then when that has finished booting do the same with the router. It should work.
Posted on Oct 16, 2010
My internet modems wifi light wont turn on : WRT100 Linksys
to access page you need to connect it to a pc with an ethernet cable and in web browser address bar type 192.168.1.1 user and password is admin
Jul 31, 2012 | Linksys RangePlus WRT100 Wireless Router
My router is connected, but there is no internet connection.
Actually, Linksys WRT160N is meant to be used as a router not an access point. It can be but with at
Jul 26, 2011 | Linksys WRT160N Wireless Router
Unable to access internet thru router
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 15, 2010 | D-Link Computers & Internet
I'm unable to get wireless connection to the internet after i replaced a new modem. Directy connection from modem to laptop is fine. Both my laptop and PC are able to detect the wireless network but are...
disconnect all the connections from the router. connect only the computer to the port 1 on the router. check the lights on the router. Reset the router for 30 seconds . unplug the power to the router. plug it back in. wait for 1 minute.now check the IP address on the computer. Win XP = click start ==> run ==> type cmd in run box and click ok. you will see the command prompt. in the black window type ipconfig and hit enter. now you will get the IP address and the Default gateway. Default gateway will be the number of your router. This will open the roputer set up. not check the settings on the router. If you connect the modem to the router, it works. now reconfigure the router as per ISP. Click Here for more info about how to set up router
Nov 18, 2009 | Linksys EtherFast Cable/DSL Router
Unable to connect internet
hi,
theres a possiblity that the modem is set to bridge mode,in that way,you will not be able to connect to the internet direclty to the modem,192.168.1.1 is usually the deault gatewayy address for almost all verizon modem and username is admin and password is admin as well,if admin didnt take for the password,try using password as the password
thanks and God Bless
Dec 10, 2008 | Toshiba WRC 1000 Wireless...
My problem is about router configuration. I have 4 computers that i want to connect using a router. When i directly connect the modem to my single computer, i can access to internet but when it connects to...
Can you get into the router setup page? Connect the modem to the WAN port of the router. Then connect one pc (to start do not connect to a switch port beside the WAN port). Get into the setup page (usually http://192.168.1.1), and ensure that your modem is connected (to internet), that you have internet access enabled, and that DHCP is turned on. If all of this is ok, try turning the power off to modem and router; then power on modem, and when it has reset, turn on the router.
Nov 26, 2008 | Computers & Internet
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Cant get to internet thru linksys etherfast cable/dsl router
Reset the modem while the router is plugged into it. Do this by disconnecting the power to the modem and then reconnecting.
Nov 09, 2008 | Linksys EtherFast Cable/DSL Router
Belkin F5D7234-4 Router Logo
108 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
