Question about LG Washing Machines
My LG WF-T700 water dint go in when my water from wter tape.
3 Suggested Answers
canbruce75
  • 1776 Answers
SOURCE: LG WF-T700 Troubleeshooting DE blinking
The "DE" code indicates a door open error. This can be caused by the door not closing all the way (this could be because of bent door/hinges or the door gasket bunching up and not permitting the door to close properly), loose electrical connections at the door switch or powerboard assembly, or the door switch itself is faulty. It can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity would mean a bad switch. Also check the door gasket for "bunching" and you can unplug and reseat electrical connections. These are some areas to look at. Be sure to disconnect unit from power before attempting any repair/troubleshooting. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 28, 2009
blueextc3221
  • 15935 Answers
SOURCE: LG wont run through cycle
You cannot turn it off in diagnostic mode - but you can jumper the 2 wires at the sensor for a TEMPORARY fix.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 16, 2010
My lg intellowasher wf t8501tp won't go into a
Check the pressure switch and hose. Pressure switch is what turns the pump on and off. Trouble is usually in the hose so check it first. Look for the hose to be unattached or clogged.
Jan 13, 2013 | Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
I have a WF-T700 automatic washing machine. My problem is that when I start it up, it automatically fills up the tub with water to a selected level and starts to wash but after about 4 - 5 seconds, it...
'DE' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 10, 2011 | LG Washing Machines
I have a WF-T556 top loader with a de error. Should there be a magnet on the lid of the machine??
There sure should be....why, because mine stopped working as well. Found magnet inside machine after getting rid of water on spin cycle (thankfully it still allows the water drain to occur). Put magnet back on and hey presto, all good.....if only I had taped it on as 5-6 washes later and it has fallen off and I can't find it - hopefully a standard magnet will be enough to fix from shops - I am sure LG or proper repair place sells them for a fortune :(
Jul 04, 2010 | LG WFT1071TP Top Load Washer
WF-F7061DN NO WATER FLOW IN TO THE MACHINE, UPTO
Water inlet valves tend to fail from time to time. This the most likely source of your problem..........Nomess
Apr 18, 2010 | LG Washing Machines
LG WF T6517TC Washing Machine does not fill water
sir
my washing machine WF-T6517TC
when it start to wash get Alarm "dE" beep and stop machine.
what need to do.
call me 91080843
Apr 10, 2010 | LG Washing Machines
Jan 22, 2009 | Washing Machines
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
