Question about Keurig B70 Coffee Maker
My Keurig will not dispense any water at all. If it does its only a drop of water and it's not even hot. Could the pump be out? Or can this be an easy fix?
SOURCE: My Keurig dispenses about 3oz of water on next to largest setting
I JUST fixed (I Hope!) my 11 month old B60 by taking a paper clip and a straightened safety pin to the top of the coffee maker (where the top pin punctures the top of the cup) and the BOTTOM pin which punctures the bottom of the cup. (remove the bottom dark brown holder by pushing up on it).
After one or two attempts, I ran water through it without the coffee cup, then used a decaf cup and brewed it just fine....
Posted on Aug 26, 2009
  • 28 Answers
SOURCE: my keurig will not dispense right amt of water
Try brewing a cup without a K-cup in it on the largest cup button (will brew just hot water). This will help clean it out in the event it is clogged. If that doesn't work, completely remove the K-cup holder where the needles are (careful not to get **** ) by pushing up from the bottom and rinse using hot water, preferably with a sink sprayer if you have one. Sometimes the needle can get clogged, especially if you ever use the hot cocoa K-cups, so the manufacturer recommends brewing a "blank" cup of just hot water after each hot cocoa K-cup brewed. Hope that helps...Best of luck!
Posted on Feb 07, 2010
  • 60 Answers
SOURCE: I have had my Keurig B60 coffee maker for over a
Valve is not bad that is not the issue you need to contact keurig to help you Call Keurig 1800 Cup Brew
Posted on Mar 23, 2010
cmccune04
  • 213 Answers
SOURCE: Just bought a secondhand Keurig. It will dispense
Do you have this part to insert the k-cup into? There has to be an exit needle and this part has the exit needle inside of it.
http://iwantsweetdeals.com/Keurig-Breville-Replacement-K-cup-Holder-Assembly-P1208231.aspx
Posted on Jun 14, 2010
  • 60 Answers
SOURCE: My Keurig coffee maker will not pump out the hot
How do I get my keurig off the hot water setting back to brew
try inserting a K cup instead and see if it reads that and automatically returns to brew.
Nov 23, 2014 | Keurig 2.0 K550 Brewing System
My mr.coffee keurig model VBMC KG5 single cup coffee maker will not run a whole cup during cycle
The Keurig machine operates by pumping air into the glass boiler to drive the hot water through your coffee cartridge. When you have put a new cartridge into the dispenser, you select a size of cup. When you press the go button, you should hear the machine pump water into the boiler to the requested cup size (test by selecting large size to hear the pumping work). Next the machine operates an air pump to force the specific amount of hot water through the cartridge and make the cup of coffee. The problem encountered with these machine is that a small amount of water can drip internally onto the air pump and it will either not operate or work intermittantly. There is a great 'how to fix' video on utube concerning the Keurig-taking apart and fixing.
Honestly, I don't know whether this is your problem, but I do know this happened to a machine I had. You should hear the tiny air pump working when the cup of coffee should be brewing. You can laboriously take apart and replace, and given the price of these units it may be practicle to do the repair. Watch video on utube--its like three or four parts and very instructive. Sorry I don't have the link.
Jan 09, 2014 | Keurig Platinum B70 Coffee Maker
The Keurig is not dispensing any water when I hit the brew button. We have always been descaling the unit since we received this second keurig machine. Please help in solving the Keurig problems with...
the air pump in the machine might be locked up. if it is you will have to take the machine apart, not fun, and locate the air pump behind the water tank. take the pump apart and try to turn the pump manually until it moves freely. good luck
Dec 30, 2010 | Keurig B70 Coffee Maker
Just got a new Keurig mini. Plugged it in, put in the water, closed the lid, put a cup on the plate, pushed the power button, pushed the "coffee cup" button and nothing is happening.
My wife's mini single cup B31 quit dispensing hot water into the K-cup. It would go through every stage and the pump came on but no water, no coffee. Try this: unplug the unit, take the drip tray off and lay the Keurig on its back, with the top opened so you can see the dispensing probe and the rubber ring that seals to the top of the K-cup. The dispensing probe is sharp, with two small channels, one on each side. (Be sure you can spill a little water when you try this) With a kid's water blaster, or a rubber bulb, squirt water up the channels on each side of the probe. Do this a few times, then try to run it normally.
That worked for me, and loosened the few coffee grounds that were plugging the outlet.
Mar 14, 2010 | Keurig Coffee Makers & Espresso Machines
Jan 14, 2010 | Keurig B70 Coffee Maker
My keurig will not dispense right amt of water
Jan 02, 2010 | Keurig Special Edition B60 Coffee Maker
Keurig B70 Coffee Maker Logo
4,222 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
