Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Contamination of the yellow ink tank from below
  • neil_rose85 Oct 14, 2010
    OK. The printer is a canon image class MP730 Printer, copier, fax and scanner.
    The yellow ink cartridge is being contaminated while in the printer. It looks as though someone has injected black or blue through the outlet hole of the ink tank. By pushing a tissue up into the hole it soaks up the dark ink and the cartridge works for a short while, but the next time I use the printer the problem is back! I had a look where the cartridges park on the right side of the printer and there seems to be wet ink spread all over that shouldn't be there. If that is the cause of the problem, then how do I get the mess cleaned up?
    What I thought was wrong has been confirmed Thanks.
  • Canon Master
  • 13,433 Answers
Hi, sorry I don't understand the question?
Please repost your question in full detail, include the brand and model of your device, and anything else that you feel might be relevant to the problem. With the current details you have provided I'm unable to offer you any assistance.
Posted on Oct 14, 2010
  • Ekse Oct 14, 2010
    It seems like the waste ink container is full, have you performed a waste ink counter reset previously without emptiying or replaceing the waste ink pads?
    If you have, the printer is overflowing with excess ink and needs to get those pads replaced from the bottom, in the area where the carrier moves.
Why does my printer not recognise ink cartridges
there is a reset for that that comes with some carts or you can just order the reset mabye
Jul 25, 2014 | Cannon Office Equipment & Supplies
Yellow is printing dark muddy colour, tank content same colour.
Has the printer printed a good yellow using this ink tank at all?
Dec 12, 2013 | Brother Office Equipment & Supplies
Why does my Yellow ink print with a deep green tint on my Epson R220?
The symptoms point to some kind of contamination between the cyan and yellow. Most likely is that the yellow nozzles are picking up a small amount of cyan in the cleaning/resting pad when the printer is waiting to print... it's also possible the printhead has started failing and is allowing ink to mix somewhere before the nozzles...
The former is more likely however, especially if you are able to print a few pages of yellow where the greenish tint/lines fade out to become pure yellow.. but then re-appear after the printhead has rested.
Causes of this problem tend to be a backed up waste ink tube or failed pump.. Again it's more likely the former, especially if you've been resetting the waste ink counter and ignoring pad replacement or redirection of the waste ink.
Simplest solution is to locate the waste ink tube (accessible via the access hatch in the back of the printer) and then flush the tube through using a syringe of warm water (don't use excess pressure). Then fit an external waste tank so that the pad ink doesn't back up again (and solve the waste ink issue at the same time).
Obviously if the printhead or waste pump are failing then you have no other options beyond a new printhead, reconditioned model or new printer.
Hope that helps...
Martin
Dec 01, 2012 | Epson Stylus Photo R220 InkJet Printer
I think I put in a wrong colored toner cartridge. Pages printing in wrong colors. Can't find a list of the cartridges I should be using.
The make and type of cartridge is generally given in the users handbook/manual provided with the printer. If you do not have that ,you can log on to Canon web site and then go to support. Select your printer model and you can find the the specification of cartridge to be used with your printer. The list of the cartridges is given below: BCI-3eBk Black ink tank, BCI-6Bk Black ink tank, BCI-6C Cyan ink tank, BCI-6M Magenta ink tank, BCI-6Y Yellow ink tank You can also go the this link and download the manual if you do not have the same http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip4000#Overview
Nov 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
All of the sudden the color does not print properly on my canon I850 - its washed out and orangish
Check the color cartridges, especially the yellow. If the yellow looks llike orange or brown then the ink is contaminated. It happens when the printhead goes bad. A membrane between the colors breaks allowing the inks to contaminate each other.
Nov 25, 2009 | Canon i850 InkJet Photo Printer
Anything we print with yellow comes out muddy at best but generally closer to black.
Look at your yellow ink cart. if it looks dark or almost black then the membrane in the printhead is bad allowing contamination of the yellow ink. Otherwise the nozzle check print will tell you if colors are missing, clogged or burned out nozzles means you need a new printhead also...
Oct 22, 2009 | Canon i950 InkJet Photo Printer
R1800 yellow ink out light on constantly
Do replacemen procedure from status monitor (How to..). When asked to replace ink tank, unplug and plug again all of ink tank.
Aug 18, 2009 | Epson Stylus Photo R200 InkJet Printer
Some ink tanks can't be recognised
please remove the cartridge and printer of after smoth cloths is in water and clean the cartridge cerkit and opp sid in cartridge ( onder of printer) please clean and after 10minuts will you chaked.
Jul 28, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Replaced Yellow Cartridge, Red light on, close lid, not working,
Hi ...
I would suggest that you follow the below stesp to install the ink tank ..
. Ensure that the printer is on, and then open the Top Cover.
The Print Head Holder moves to the center.
Note: If the Top Cover is left open for more than 10 minutes, the Print Head Holder moves to the right. Close and reopen the Top Cover to return the holder to the center.
2. Open the Paper Output Tray.
Put your fingers in the notches in either side of the Paper Output Tray and pull down to open it, and then pull down the Inner Cover forward to open it.
3. Remove the ink tank whose lamp is flashing fast or is off.
Push the tab and remove the ink tank.
Do not touch the print head lock lever; remove only the ink tank.
Caution: Handle ink tanks carefully to avoid staining clothing or the surrounding area. Discard empty ink tanks according to the local laws and regulations regarding disposal of consumables.
Note: Be sure to replace ink tanks one by one when replacing more than one ink tank.
4. Prepare a replacement tank.
* Do not touch the electrical contacts on the ink tank. Doing so can cause the printer to malfunction or become unable to print.
Unpack the new ink tank and completely pull off the orange tape. Then, remove the film. Remove the orange protective cap from the bottom of the ink tank and discard it.
Important:
  • Be sure to remove the clear film from the ink tank in the exact order shown in step 4, as failure to follow this step may cause the ink to leak and stain your clothes and hands.
  • Do not squeeze the side of ink tanks as this may cause the ink to leak out and stain your clothes and hands.
  • Do not re-attach the protective cap once you have removed it.
  • Do not touch the open ink port once the protective cap is removed, as this may prevent the ink from being ejected properly.
  • Ink on the removed protective cap may stain your clothes and hands.
  • Ensure that all the orange tape has been peeled off along the perforation. If there remains a part of the orange tape, ink may not be output correctly.
5. Install the ink tank.
(1) Insert the ink tank into the Print Head.
(2) Press on the 'PUSH' mark on the ink tank until the ink tank snaps firmly into place.
(3) Ensure that the ink tank lamp lights red.
Important: Ensure that all the ink tanks are installed in the order directed by the label. The printer cannot be used unless all the ink tanks are installed.
6. Close the Inner Cover.
Note: Ensure that the Inner Cover is closed. Printing will not occur if the Inner Cover is open.
7. Close the Top Cover.
The Print Head Holder moves to the right. The ink tank installation process is now complete.
  • The ALARM lamp still flashes orange after the Top Cover is closed if an ink tank is not installed properly. Open the Top Cover and make sure that all the ink tanks are installed in the correct order directed on the label.
  • To maintain optimal print quality, use an ink tank within six months of first use.
  • Once an ink tank has been used, do not remove it from the printer and leave it out in the open. This will cause the ink tank to dry out and the printer may not operate properly when it is reinstalled.
  • Color ink consumption may occur even when black-and-white or gray scale printing is specified.
    Color ink is consumed in the head cleaning and deep cleaning, which are necessary to maintain the printer.
  • When you start printing after replacing the ink tank, Print Head Cleaning is performed automatically. Do not perform any other operations until the Print Head Cleaning finishes. The POWER lamp flashes green during cleaning.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Magenta/yellow ink not loading
try replacing with a new cartridge (sealed)
Jul 23, 2008 | Ricoh Aficio GX3050 GelSprinter
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
218 people viewed this question
old marine
old marine
