Question about Harman Kardon HK206 Computer Speakers
My speekers hum at first when i turn them, on and then mak a poing sound but then play fine
My KLH powered sub maks e a humming sound when i plug it in but it only hums when the speaker is hooked up i tried others but did the same eventually speaker started smoking would wrong fuse do that
Wrap a wire around the outside Metal of your rca jack in back of your radio and ground the other end of that wire to the back of your radio and the noise goes away
May 09, 2015 | KLH Audio Players & Recorders
My Home Music System with CD Player shows that it is playing my MP3 CD yet it isn't going through the speekers. I put in a regular CD in and it plays through the speekers. I am bafled on how to resulve...
Does the home music system have the capability to play MP3? If it does not then its simply reading a "silent audio file", therefore you will get no sound from it. To me it does not seem to have the MP3 capability.
Jul 20, 2011 | Audio Players & Recorders
When my polaroid flat screen tv is turned on humming
Check to see that you're not in SAP mode, (Separate Audio Program) in the audio portion of your menu. Could also be filtering via a bad cap or two in the audio circuit the the hum is a 60 cycle hum because of it. If you have a cap analyzer you could check those also.
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Aug 22, 2009 | Polaroid TLX-01911C LCD TV
I have a 2000 Z3 and there is a thump that comes from the speaker
Check to see if at the amp there is a strand of wire crossing over. i had a friend onetime who had the same problem and they just didn't twist the wire all the way before connecting it.
Aug 20, 2009 | Car Audio & Video
My LG cookie's AUDIO does not work.
I had the exact same problem, i downloaded some mp3's onto my phone from my MAC using the usb cable included with the phone and when i played them they only worked on the headset but then i quickly realised it was the speeker that had gone. I checked every setting just to be sure but no luck, anyway i opened it up got to the speeker, i kept the power on and a song playing to see if i tweeked the conection from the circuit to the speeker maybe i could see if the wires were the problem and re-solder but no luck. SOLUTION i then got frustrated and played a song flicking the phone near the speeker to see if it would work, THEN i decided to try a magnet but no change so i turned it off and ten mins later i turned it back on and heard a partial sound i flicked it turned it on and off and it now works! don't know if it was the flicking or the magnet but when i opened it up and moved it around nothing happened so i say try the magnet and turn it off and on giving it a 10 min break between and hope for the best.
I realise this is probably not the answer you are looking for but worth a try it can't get worse
Apr 12, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Play cd and dvd but no sound
this is a simple problem in u r speeker so first remove u r speeker and chek the connections are perfect r not if the connectinons r fre fect then the problem will be in speker,i hope so the emiter is lost so once u see the connections and if u find nothin in it change the speeker then u r problem will be solved
Feb 25, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Speekers
hello
okay i think your base is too full.
turn off the base of your speekers and then try to play a song or a sound...
if not go to control panel and then sounds and lower down the base volume bar
Dec 10, 2007 | Audio Players & Recorders
No Sound
go to your local car audio stor and buy a rca to speeker wire converter or buy an equalizer and use your speekers
Aug 18, 2007 | Panasonic CQ-VD7001U Car DVD Player
Harman Kardon HK206 Computer Speakers Logo
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
