Question about Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television
My power button broke to my mitsubishi hd 1080 and I lost the remote control is there any other way to turn it on?
    Genius:
  • 1,030 Answers
Is the button pysically broke... the unit does have a keyboard lockout feature press and hold menu for 10 seconds... maybe if not then the power button will need repair or a universal remote may be used
Posted on Oct 14, 2010
It won't turn on and we don't have a remote control. What can we do ? Mitsubishi Medallion HD 1080
not knowing model number I will suggest a few things: if green power light comes on for a few seconds and goes out:
On front of set press and hold both the Menu and Input (device) buttons at same time for at least 5 seconds and release both.
Power light should blink a two digit error code like 2 blinks,,2 blinks,, a pause and repeat it several times.
This is a error code that indicates what area problem is in, let me know what error code you find and I will tell you what it means----if set has been unplugged you will have to try to turn it on and let it fail before you go for the error code.
SD TECH
Mar 31, 2011 | Mitsubishi Televison & Video
Have a Mitsubishi Medallion HD 1080 Model WS-48413 which won't turn on. When I push the power button on the remote or on the tv itself, a green light comes on for a moment and a clicking sound is heard to...
~ Check the lamp hours ~ Normally it is 200-400 hours lamp life ~ BASIC USAGE: 8 hours/day ~ Reseat the lamp~ Consider replacing the lamp or it could be an Internal Problem
Jul 06, 2010 | Mitsubishi WS-65413 65" Rear Projection...
Can not turn off the vchip channel lock on hd 1080
hello try this Bypassing the V-Chip Lock
After you set the lock, you need your
passcode to view a V-Chip locked program,
view the locked TV, cancel the lock, or enter
the V-Chip lock menus.
If you forget your passcode, you can
view the locked TV without entering your
passcode. This is done by pressing the
number 9 and QV buttons on the remote
TV control at the same time, when your
password is requested. This process
temporarily unlocks the TV.
When entering the V-Chip Lock menu, this
process deletes your old passcode and
prompts you to enter a new passcode. good luck
regards
shaun
May 14, 2010 | Mitsubishi VS-50111 50" Rear Projection...
It say 480 stretch on the screen how do I turn it to 1080 for my Hd tv
Make it sure that you have a 1080 signal from your source(eg. HD receiver, bluray player etc.). Try pressing format button on the remote until you get full picture . Or try changing the format or aspect ration in your satellite or cable box.
Dec 29, 2009 | Mitsubishi WS-65511 65" Rear Projection...
I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Aug 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
How do I reset big screen tv to 1080 on remote
You don't.
It should automatically switch to 1080 when and only when there is a HD signal present. Otherwise it will be in 480 and you will need to use the format button on the remote to change the picture size. If it does not switch to 1080 and you know for sure you have a true HD signal present, there is a problem with the unit.
Hope this helps,
Skyassoc
Jun 28, 2009 | Mitsubishi WD-62531 Projection Television
I need a remote control code for a Mistsubishi HD 1080 TV
need to know what remote you have to help do you have a model # or if you go to this site you will hind the 2 remotes S I sells. Click on the pic. then you can download the manual. Hope this helps. If the remote is not there Get me the model # and I will find the codes for you.
http://mscustomercare.com/
Good Luck
Dec 30, 2008 | One For All URC-4330 Remote Control
HD setup, 480 to 1080 not working.
I had this same problem, got my HD installed yesterday w/ Direct TV, have had this TV since '02. The fact that is wasn't working, and Google, led me to your post in search of answers. I even went to a local retailer that sells the Mitsubishi TV's and they were as helpful as if I had gone to a drug store seeking the answer. So, between browsing other posts, and then going to the manual (who'd of thunk) I got my, and your, answer. You need to do the following, nothing magic: 1)Connect the component video output of the Direct TV HD Receiver to the DTV inputs on your TV. The COMP 1/2 inputs are NOT 1080 compatible, only the DTV input. As another poster said, you must use component video cables, not the old red/yellow/white cables. you can lose too much signal quality w/ the old R/Y/W cables and your TV still won't recognize the 1080. 2)Set your receiver to a HD Channel, which are in the 70's. 3)Use the format selection on your remote and select until you get the 1080i Standard (or whatever your preference is) format. 4)Enjoy Bottom line is the COMP inputs are not HD. Page 64 of the manual (at least the one i downloaded from mitsubishi-tv.com) is what gave me the final piece of the picture. Good Luck!
Sep 20, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television Logo
101 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
