Question about Iomega Computers & Internet
I have an Iomega travel drive with dual plug. The plug has a short in it. How can I find a replacement plug. I tried a regular cord but it doesn't recognize drive with single plug. It is 31625101 R a 60 gig drive.
SOURCE: Iomega 500 gb hard drive: large file transfers
The default format for the IOMega drive is FAT32. This format will work on all versions of Windows, as well as Mac OS9 and above. Unfortunately, FAT32 can't handle files larger than 4gigs. If you want to use larger files, you're going to have to remove all the files from your IOMega drive and use your computer to format it to NTFS (Windows 2000/XP/Vista) or HFS+ (Mac OS9/X).
Consult your owner's manual for specific details.
Posted on Nov 26, 2008
  • 303 Answers
SOURCE: Kawasaki portable dual screen DVD Player
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for KAWASAKI PVS-2970s
Posted on Jun 02, 2009
  • 164 Answers
SOURCE: computer doesn' t recognize iomega eGo portable
a windows update may have run and killed the drivers...try rolling the system back to before the problem started, then if updates run again..and set them to download but dont install..install them yourself..run updates and see if the problem re-appears.
Posted on Jul 24, 2009
Crankstart
  • 696 Answers
SOURCE: Iomega Prestige 1TB External Hard Drive (34275) adapter
Hi LeoChen,
Most of the Iomega drive adapters do but not all. There's no information on Iomega's site regarding the voltage but if you look carefully at the fine print on the adapter, it should have a Input Voltage Range listing, normally 100-240, if this is the case then as long as you have a cord that fits from the wall to the adapter the adapter will adjust itself to voltage within this range. If you have one of the few that staes only 90-120V for range then the answer is no, but Targus sells a universal adapter for laptops that comes with an appropriate tip for your drive that does support 90-240V.
Hope this helps FixYa,
Chris
Posted on Aug 09, 2009
SOURCE: My HP Lightscribe 1040p does not recognize
solve the problem for because i want to copy cd.it has not be workink since 3 days.
Posted on Aug 21, 2009
My Iomega LDHD250U 250 GB USB External Hard Drive's Power and Usb ports WILLNOT CONNECT!!!!!!! Please help ive been trying to figure out why all day.
Dear Friend, Your I-Omega case might be bad or the controller inside that connects everything. I suggest you to get: http://www.walmart.com/ip/Apricorn-Universal-Hard-Drive-Adapter/10811435. and pulled your hard drive enclosure apart, then removed your hard drive and connect with the external adapter. Usually comes with a SATA or IDE connector for data and power adapter. After connecting everything plug into your PC and it should be able to recognize.
Good Luck#
Jan 13, 2014 | Iomega (33215) 250 GB Hard Drive
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
I have a mac and a new iogmega external drive, 500g. I cannot move any files onto the iomega or save them. I get messages such as "that file does not exist" to iomega can't be modified,...
With the drive plugged in, going into your Applications ' Utilities ' Disk Utility Select the drive and press Verify Disk, Repair Disk and Repair Permissions. If you don't have anything on the drive right now, try formatting it with the Mac OS Extended (Journaled) file system from the Disk Utility.
If that doesn't work the drive may be damaged. If you have another PC / Mac, trying plugging it in and see if it works there. If the drive is under 1 year old it should still be under warrantee, in which you could return it / RMA and get a new one sent back from the manufacture.
Regards, Chris
May 31, 2011 | Iomega (33090) 250 GB Hard Drive
I have an iomega minimax device that I cannot seem to connect to my imac. when i plug the device in nothing happens on the desktop.
try getting a new power cord from iomega, If that doesn;t work, the drive is probably corrupted. They are under a year warranty. You ship yours to them and they will send you a new one. Try the free chat on Iomega
Jan 17, 2011 | Iomega MiniMax Desktop - Hard drive - 500...
Iomega Burner loads as Sunplus Bridge
Hi,I had the same problem,its most likely the upper and lower filters.go to my post run number 11. hope I helped
Please rate my sollution
Jun 01, 2010 | Iomega Super DVD QuikTouch Video Burner...
Vista driver for 16x quiktouch iomega super dvd download
Try this link, this may help:
http://www.downloadaces.com/drivers/Other-Tools-Drivers/Others-101/
Apr 24, 2010 | Iomega Super DVD QuikTouch Video Burner...
Hi LeoChen,
Chris
Aug 08, 2009 | Iomega Computers & Internet
Not accesible
hi there, i to have an iomega external drive, have you tried to disconnect the cable, i.e.. the usb cord and restarting the computer and pluging in the hard drive itself back into the usb slot.....if yes i am thinking, another thing is, wha operating system are you using, if it is vista and you restarted the computer with it pluged in you must restart it without the iomega plugged into the computer, when an external drive is plugged in and the system resatrts vista recognizes it as an internal drive and tries to reboot from it....i am not sure why vista does this, it happens to me and microsoft says it's a protection thing, from hacker hardware components......so all usb things should be replugged into the computer after vista has started with just the regular things...microphones and such are ok....just things with mass storage are what need to be unplugged and replugged into the computer after reboot....hope this helps....shia
May 11, 2009 | Computers & Internet
Computers & Internet Logo
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
