Question about Sony NWZB135F MP3 Player
It says boot error and wont pick up on my pc neither will it turn on
  • 64 Answers
Try to press the power button while it is connected to your computer. See if it will show up charging. If it is not, then you may need to contact Sony Support.
Posted on Oct 14, 2010
Pc
start pc press F2 or Delete enter Bios, check boot priority is dvd-rw od hdd set to suit, change ide/sata cable to hdd they do burn out... make sure sata 1 hdd / or ide 1 master, for C drive. hope this helps. I/O errors can occur usually swapping order of boot can fix this...
May 30, 2013 | Acer Aspire Computers & Internet
How to open compaq presario sr1420nx computer
You have a virus in your computer. Boot the computer, immediately hit the delete key until you can get to the setup screen and it will allow you to format your drive.
Nov 28, 2012 | HP Compaq Presario SR1420nx...
My laptop has power but wont boot...please help
hi,
Try to boot you computer to safemode, turn off computer then turn it back on then keep on tapping F8, then choose safemode, if youre able to boot to safemode, do system restore going back to the time that its properly working, click start > all programs > accesories> system tools > system restore then pick a date when you think that its properly working..
If its not able to boot to safemode, you will need to reinstall the operating system using the recovery disc that came with the computer.
Hope this will help... Please rate...
Jan 20, 2011 | Acer Computers & Internet
My laptop wont boot up. it only goes to the IBM screen and on the top it says error 1805 turn off and remove pci card. and if i go intothe diagnostic boot it says internal pci card shadowed and also says...
The POST error code 1805 for the ThinkPad is as follows :-
1805
Unauthorized Wireless USB card is plugged in—Power off and remove the Wireless USB card.
  1. Remove the Wireless USB card that you installed.
  2. System board.
Please click on this link for further POST error codes and explainations
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=ibm&lndocid=MIGR-42321&velxr-layout=print
Jul 03, 2010 | IBM ThinkPad T30 2366 Notebook
Xp wont turned on it will not boot to the desk top it frezers
This should fix your problem. Even w/o your installation disk. I have used this program to fix Pc's I have picked up off the side of the road. I would hit the power button, it would show the BIOS then it would stop and shutdown. This fixed 99% of them I have picked up.
Go here
using a torrent program ie (utorrent, shareaza, etc) download SPINRITE.exe.
Burn this on a disk, the program is written with freedos included, but this will not work with 100% of laptops.
if the program stops and shows you a red screen with an error, use a program such as PowerISO to burn the disk and make it a bootable image by adding a .bif
after burning the program to disk-
  • insert disk and reboot
  • press any key to boot from cd if asked
  • when you see Prompt, change to your default cd drive.
  • type SPINRITE to start program
  • use recovery option 5
this may take a few hours or a few days depending on the condition of the HDD.
I have used this program to fix computers I've picked up on the side of the road. I would power it on, start to load then go into a loop. after running this program overnight I was able to reboot (after removing disk) and the pc started right up.
Make sure you run a program like Ccleaner (you can get at www.fileippo.com) to clean your registry2.gif and junk files after completion. ^_^
Sep 17, 2009 | Gateway MX6030 Notebook
Hp Laptop Wont Boot
Hey dear,
Your operating system got crash. Use backup CD.
Turn on yr lappy. manually open the cd rom from right side of leptop. Put CD in. then wait for few seconds. u will see the screen then follow the instruction and re install the entire windows.
Sep 13, 2009 | HP Pavilion dv6000z Notebook
My computer wont boot anymore
Try going into safe mode by hitting F8 upon startup. If it lets you get into safe mode then choose "Last Known Good Configuration" on the menu. If that does not work then let me know, there are a couple of other choices.
Mar 19, 2009 | HP Compaq Presario SR1303wm PC Desktop
Disc reading error
this is a little something i picked up a while ago turn on the ps3 wait for boot up if possible as far as the boot will go
if dont boot up theres a thing called a cold boot
pull plug while on or connect to surge protector with on off switch the cold boot should reset last best boot up
May 05, 2008 | Sony Playstation 3 (PS3) Console
Worked first then boot error now comp wont pick it up
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (moz-screenshot.jpgmoz-screenshot-1.jpghttp://support.rcaaudiovideo.com/downloads.aspx?product=187), the firmware it's the second app listed.
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Jan 31, 2008 | RCA OPAL M4001 MP3 Player
Booting up to windows or cdrom
please try to boot with window server 2003 Cd .If that boot from server then error is with the OS which you installed
Dec 26, 2007 | AOpen AK77-600n Motherboard
Sony NWZB135F  MP3 Player Logo
78 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
