Question about Kenmore 64992 Electric Dryer
My kenmore 64992 gets too hot even on the fluff setting with no heat. whats up?
    Problem Solver:
  • 87 Answers
Something must be rubbing.
Posted on Oct 14, 2010
Kenmore dryer overheating on airfluff
driers that over heat may have the lint filter blocked preventing free air flow
check / clean it regularly
Have an accredited electrician / service agent check ti out
Nov 04, 2015 | Kenmore Dryers
Is the top heating element inside the oven supposed to get hot even if not set on broil?
Yes the top element does get hot even on bake but it does not get red hot just hot. It will get hot enough to burn you so be very carful.
Apr 06, 2011 | Kenmore Ovens
Dryer will not start ., only get a click when you push the push to start button.model 110 6499 4301
Sounds like a failed thermal fuse and unit got too hot and this problem must be address to ensure that it will not happen again. Check you venting system to ensure proper air flow...
Apr 02, 2011 | Kenmore 64992 Electric Dryer
Heating element stays on, even at fluff air no heat setting. Replaced high limit thermostst and thermistor Air flow good
If your heating element is grounded (wire burnt in half and is touching metal) the heat will stay on forever, even in air fluff. This is your most likely problem.
Feb 18, 2011 | Dryers
The dryer stoped heating its like its only cold air
I will assume this is an electric dryer.
When asking for help, you should include the brand and model number to help get a great answer.
In my experience, these are the possible problems in order of how often they happen.
1) Thermal overheat sensor fails. This is a small electrical device that will turn off the heating element if it thinks the dryer is getting too hot. It will have 2 wires connected to it and a silver colored round metal piece that senses the heat. When this part fails, the heater will not turn on. Disconnect the wires from this sensor and verify that it has zero (0) ohms across the two connectors.
2) Heating element could be burned out. Disconnect the two wires from the heating element and verify that it has a low resistance. Replace it if there is no resistance.
3) The thermostat has failed. There is a part that monitors the heat in the oven and turns the heating element on and off. You test it the same way you test item #1 above.
4) Some dryers have a FLUFF setting where the dryer only blows cold air. The switch that selects the heat settings could be broken. You will need to test this switch by looking at the electrical schematic for the dryer and testing the switch as indicated.
5) The knob on the switch that chooses the heat setting could be pushed onto the shaft in the wrong position so it points to "hot" when it is actually set to "fluff." The simplest way to test this is to choose a heat setting one click, either direction, from the one it is on now. If you get heat, the knob is pointing to the wrong place.
Jan 14, 2011 | Kenmore Dryers
My dryer (kenmore elite model 110.64992300) wont heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 26, 2010 | Kenmore 64992 Electric Dryer
NO HEAT ON KENMORE ELEC. DRYER MOD. 110.64992300
There could be a number of problems with your dryer causing it not to heat. Here is a tip that I wrote about your problem...
Heatman101
Mar 10, 2010 | Kenmore 64992 Electric Dryer
Dryer not heating everything else works fine had heating element tested and it is okay
Just a general troubleshooting guide for your washer! hope this helps!! PS don't forget to give me a rating if this helped!! Thank you!!
http://fixitnow.com/2005/09/washing-machine-diagnostic-and-repair.htm
May 07, 2009 | Kenmore 64992 Electric Dryer
Kenmore 64992 Electric Dryer Logo
41 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
