Question about Samsung B3410 Cell Phone
I cant connect my samsung b3410w on wifi. Every time i have message no response from access point. Second how can i put appointmen widget or simillar on my passiv screen?
I have B3410 but i do not know how can i connect wifi
Posted on Nov 13, 2010
  • helldestroye Dec 15, 2010
    how can you get it, if it is not provided with it...........
  • koolgal01133 Aug 28, 2011
    how to make it work when it says no response from AP?
Weak wifi signal?
you have 2 possible solutions:
the easiest (but suboptimal) is to put buy a wireless repeater and install it half way between your access point and the point where you experience low coverage.
Amazon com NETGEAR N300 Wi Fi Range Extender Essentials Edition EX2700...
the best solutions is to buy a power line kit like this:
Amazon com NETGEAR PowerLINE 1000 Mbps WiFi 802 11ac 1 Gigabit Port...
you can plug the one without the wifi to a power outlet near your wireless router, and connect the two devices by a network cable. then you can plug the second powerline (the one with the antennas) in a power outlet near the place where you need wifi signal. the second device needs a little configuration (just put same network name and password of your old access point).
this way you will have your a new wifi access point, that will connect to your internet connection by power wires in your house.
Aug 01, 2017 | Advance Computers & Internet
Tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
on Apr 17, 2010 | Samsung Jet S8000 Cell Phone
Hi, how do I tun the automatic GPRS connection off from my Samsung GT-b3410w? I only want to access my mails or surf the net via wifi and would like to set this as default. Any help would be great as its...
You have to go to the "Settings" menu, then "Application Settings", then pick "Internet" and finally choose "Internet profile". In this menu, you can set your WiFi network as default.
Cheers
Oct 21, 2010 | Samsung Cell Phones
No wifi connection cant connect to wireless wifi always disconnected
Usually, you just have to do a soft reset (Turn your phone off and back on) to make your wifi active again.
In the widgets look for your wifi then press search and it will locate any wifi hot spot near you then choose then connect. then go to your communication and choose which site you want to go.
Apr 08, 2010 | Samsung Star GT-S5233 Cell Phone
How to connect samsung 3g to bsnl wifi?????
check your access point settings maybe you entered a wrong configuration, or ask the right configuration from you network provider. no response means, either there is something wrong with your configuration or there your ip have too much traffic.
Feb 11, 2010 | Samsung Jet S8000 Cell Phone
Samsung s5560 cant connect tto wifi, phone comes
go to 'Settings'
then 'Reset Settings'
tick 'Phone Settings'
The phone will say its going to reboot......then
after reboot...turn your WIFI on...put in your WEP password...
JOB DONE !...regards to all, Narn
Jan 30, 2010 | Samsung Star GT-S5233 Cell Phone
I cant open or send texts from my samsung star.. when i click on the widget or the icon in the menu it says "initializing" and disappears... all my other widgets and apps are working fine
I got the same problem. :))
you must reset your phone.
here is the code ..
*2767*3855# but it will delete your contacts and other files. :))
Dec 08, 2009 | Samsung Star GT-S5233 Cell Phone
Cant get my unit to connect at wifi hotspots
Have you connect/pair your laptop with hotspot/access point ?
Before going into internet explorer, you should connect to the access point first.
Nov 03, 2008 | Toshiba P25-S526 Notebook
Samsung B3410 Cell Phone Logo
538 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
